Old 06-27-2013, 08:30 AM   #26
Angelus911
Member#: 89967
2012 Impreza Sport
I've switched to the handle as well, but I haven't had the latch issue in about 3 weeks now, either
Old 06-27-2013, 09:49 AM   #27
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
The Subaru logo is on the middle of the hatch, so you get less leverage than the handle at the bottom.
MCarp22 is offline   Reply With Quote
Old 06-27-2013, 10:11 AM   #28
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I don't know that I agree with this. A user should be able to get more than enough leverage to close a hatch regardless of whether he's using the handle or anyplace on the exterior edge of the hatch.
The fact that many of the people complaining about this and saying that they're "slamming" their latches closed (and sometimes still not getting the hatch to latch properly) would suggest that this isn't a leverage problem.
Old 06-27-2013, 02:51 PM   #29
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
I agree with that.
/doesn't have problems with the hatch
Old 07-04-2013, 01:10 PM   #30
John451
Member#: 321966
2012 Impreza + XV 14
Black Pearl + White XV
After working out very quickly one reason for the hatch not closing was accidently touching the open button under the Subaru badge we still used to have the not shutting problem semi regularly on ours though it seems to have gone away since our last service, was wondering if they aligned it as a known issue ?
John451 is offline   Reply With Quote
Old 07-05-2013, 01:20 PM   #31
bruuster
Member#: 310131
2013 Impreza Limited
Satin White Hatchback
Default Quieting the hatch
I felt like I had to slam my hatch to close it consistently and it seemed very loud and hollow. I popped of the inner plastic of the hatch and added some 1 inch thick egg crate foam pieces. (The insulation from the factory is only about 1/4 inch) I also loosened and re-tightened the latch hook. Now I can close the hatch normally and the sound is muffled. Helps dampen the noise while driving as well.
bruuster is offline   Reply With Quote
Old 07-07-2013, 08:40 PM   #32
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
A very simple thing I did to improve the solidity of the sound when closing the hatch is to attach the rear license plate using four screws instead of just the two top screws as installed by the dealer. That right there gets rid of a huge rattling sound when closing the hatch!
