Old 11-02-2012, 11:07 AM   #26
kickflip4218
Member#: 237901
2005 Legacy GT
THAT^^ (anklebiter build) has got to be one of the greatest things ive ever seen. I read the whole thread the other day, and its amazing. The guy is one hell of a fabricator
kickflip4218 is offline   Reply With Quote
Old 11-13-2012, 03:33 PM   #27
Mishimoto
NASIOC Manufacturer
Member#: 207954
Awesome build you have going. Subscribed.
Mishimoto is offline   Reply With Quote
Old 11-14-2012, 03:36 AM   #28
ShaksSTI
Member#: 303232
1998 Impreza Type R
Great effort, cant wait to see it finished
ShaksSTI is offline   Reply With Quote
Old 11-22-2012, 02:04 PM   #29
SexyWRXy43
Member#: 311562
This is such an interesting build, I wonder what the Germans would have to say about this.
SexyWRXy43 is offline   Reply With Quote
Old 11-26-2012, 09:00 PM   #30
mduck
Member#: 338901
Crazy! nice project
mduck is offline   Reply With Quote
Old 11-28-2012, 04:40 PM   #31
ben_art
Member#: 172635
2003 WRX Wagon
bump?
ben_art is offline   Reply With Quote
Old 11-30-2012, 10:06 PM   #32
dan4g63
Member#: 72266
a lot of welding, looks good
dan4g63 is offline   Reply With Quote
Old 03-04-2013, 06:27 PM   #33
RuskeR
Member#: 5824
2005 STi Aspen White
1990 240sx "SR20"
This looks like it's going to be a great project!
RuskeR is offline   Reply With Quote
Old 07-04-2013, 10:00 PM   #34
onixbonilla
Member#: 66942
Great build! Subscribed!
onixbonilla is offline   Reply With Quote
Old 07-05-2013, 10:04 AM   #35
su-version
Member#: 330666
Yea, I've seen you at the world site.(I'm 76-914 over there)Dang, it's been almost a year since I posted here but a quick update. I've stripped a 2003 LL Bean of it's engine and wiring. Just cleaned her up and put new valve cover gaskets on it. Got it mounted to an engine stand and will start with making some motor mounts. Suspension and radiator are in. Looking for a late model Suby 5 speed to couple to it, now.
su-version is offline   Reply With Quote
Old 10-08-2013, 11:10 PM   #36
OneBadBird
Member#: 370476
Cool build
OneBadBird is offline   Reply With Quote
Old 10-10-2013, 12:12 PM   #37
Superaison
Member#: 257982
02 Impreza
Why the fuel tank in the front?
Superaison is offline   Reply With Quote
Old 10-10-2013, 12:56 PM   #38
ToneWrx02
Member#: 239095
2002 Wrx
Weight distribution?
ToneWrx02 is offline   Reply With Quote
Old 04-28-2014, 10:40 PM   #39
hsus2k
Member#: 229799
The stock fuel tank was also in front of the dash up above between the tires.
Yes weigh distribution, you don't want the front end to be too light- and "float", you want the front tire to grip and bite to the ground.
Actually I ditched the 15 gal Alum. Fuel cell (shown in first link below); I will be put in a 10 gal Poly cylinder tank low to the floor right behind the hood scoop, or might have to custom build a tank at the same location.
BTALground initial fuel tank position is right in the way of Porsche 914 thru body sway bar! (And I had ask them to clear that area for me specifically if I'm not using the 911 undercar sway bar.)
I aslo have few (7) Fiat 850 Spiders, the engine is at rear and fuel tank is right behind the seats, between the convertible top and the engine (above the transaxle).
There was really nothing at front except the battery and the spare. The whole car weighs at 1600 pounds!
When I drive above 70 MPH, the car seems light or float in the front.
Very scary, feel like I don't have much control - especially when I got that little 52 hp up to 90MPH!
This 914 not only have the fuel tank in the front, it's placed lower positioned than Stock right between the front tires.
The radiator and condenser are also at front of the car; also vented thru the hood to create more down force for the front end to stick to the ground......
hsus2k is offline   Reply With Quote
Old 04-28-2014, 10:47 PM   #40
hsus2k
Member#: 229799
The car is no longer at BATLground - ended around Summer 2012
http://s1293.photobucket.com/user/hs...m%20BATLground
I don't know what had happened to them? Tried to contact them, but nobody replays back???
The car has since moved to a body shop for a lot of body work - there are a lot of Fiberglass items: front and rear lids, both doors, and front and rear bumpers plus the front lower spoiler..........
http://s1293.photobucket.com/user/hs...%20from%20Paul
The body man had to redo almost 40% of the work from the previous shop; also dumped the engine and transaxle cradle and bought from coldwater914 - very nice engine cradle and transaxle hangers!
The car is now painted, body work (almost completely) done; suspension start to fit on to the car:
Old 04-29-2014, 07:40 AM   #41
05Scooby
Member#: 153216
2005 WRX stage 3
Really cool looking build man...
Theres a what looks to be an old German car service station for sale, on old Lincoln highway here in pa, I spotted a couple of 914's there as well as a wealth of german vehicles sitting on the lot. And when I say nothing, I mean nothing on the lot looks relatively newer in terms of Model years....
that being said, good luck with the build!
05Scooby is offline   Reply With Quote
Old 05-16-2014, 11:33 AM   #42
hsus2k
Member#: 229799
Motor is being preped and cleaned in another tuner shop, probably keeping is stock for now and just get the aftremarket (Haltech) ECU and Digital Dispay hooked up and running.
I can't decide to black out the door handles/mirror or wrap with this to match the body yellow?
[/url][/IMG]
More pictures to show wrapped door handle with matching colored wheel in different lighting.............
http://s1293.photobucket.com/user/hs...20Fiber%20Wrap
Running to a snag on front 911 suspension, need to add a Hub Blocking plates for cooling the brake rotor.
Made 3D CAD model and friendmade them in SS with laser cut, not sure if they fit yet? The hub and rotors are at teh bodyshop more than 2 hour drive away.
I just got the dimensions from here (some were not exactly fitting as the body man told me - I had to tweak a little)
http://www.dietersmotorsports.com/tech/2002/5-2002.htm
Here is the blocking Plates I made up, and some pictures of the Boxstrer calipers:
http://s1293.photobucket.com/user/hs...ter%20Calipers
[IMG][/IMG]
[IMG][/IMG]
I love this view, the car looks so Square from the top![IMG][/IMG]
The Targa top (bar) has not been painted, becasue initially I wanted to be matte or texture black to match the top
Now, I decided to painted body color - I can always use Plastic Dip (black) or Vinyl Wrap (with Black or Carbon Fiber black) - both can be removed easily if I don't like them.
[IMG][/IMG]
Old 08-03-2014, 11:52 PM   #43
Overboostedwrx
Member#: 385123
Beautiful car the Porsche 914 is my favorite model, a buddy of mine has one with a built small block 350 chevy.
Overboostedwrx is offline   Reply With Quote
Old 11-20-2014, 04:40 PM   #44
passerby
Member#: 406780
All I can say is wow!
passerby is offline   Reply With Quote
Old 01-19-2015, 09:52 AM   #45
axierjhtjz
Member#: 409695
Beautifull car project. Will keep an eye on this thread.
axierjhtjz is offline   Reply With Quote
Old 01-23-2015, 02:41 AM   #46
RX-78 Gundam
Member#: 378812
This is super cool. Awesome combination of 914 and Subaru.
RX-78 Gundam is offline   Reply With Quote
Old 02-22-2016, 01:11 PM   #47
stl_16wrx
Member#: 440169
nice!
stl_16wrx is offline   Reply With Quote
Old 03-18-2016, 04:44 PM   #48
mick2522
Member#: 399943
Awesome build, looking forward to seeing the end result.
mick2522 is offline   Reply With Quote
Old 05-10-2016, 11:38 AM   #49
sube buggy
Member#: 446122
this is a beast! i have the same 15 gal fuel tank for my old vw subie swap for my dune buggy i almost wish i would have went this route, excited to see how it turns out.
p.s are you using an old Porsche trans w/ adapter plate or are you adapting the Subaru trans?
sube buggy is offline   Reply With Quote
Buying a Porsche 914 sperry Off-Topic 12 12-10-2003 01:05 PM
My Porsche 914 Track Car soloracer Member's Car Gallery 19 06-25-2003 10:01 PM
EJ25 into Porsche 914!!! :) Clegg Mid West Subaru Owners Club Forum -- MWSOC 4 02-10-2002 12:39 PM
Project Porsche 914 Update tomrichardson Rocky Mountains Impreza Club Forum -- RMIC 14 06-19-2001 02:58 PM
Project Porsche 914 Update tomrichardson Rocky Mountains Impreza Club Forum -- RMIC 2 05-29-2001 07:42 PM
