Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 06-26-2013, 10:42 PM   #1
gumby1976
Member#: 26248
2016 WRX
Lapis Blue
Default 2012 Impreza\2013 Crosstrek Bluetooth auto-connect issue with Galaxy S3
My wife and both have Galaxy S3s and neither are able to get the bluetooth to auto-connect with our car radios (CZ624u1, the base model). We have to go the manual route and even that take several attempts before it connects.
Anyone have this issue or know how to fix it.
gumby1976 is offline   Reply With Quote
Old 07-03-2013, 11:00 AM   #2
CNUSubie07
Member#: 283958
2011 WRX 5-Door Base
Dark Gray Metallic
This won't really help your issue, as I have no idea how to fix it, but I also have this problem in my 2011 WRX with my Galaxy Nexus. It won't auto-connect. I have to connect manually and it usually takes multiple tries. Sometimes it will connect fully, other times it will connect without phone. Basically a giant PIA.
CNUSubie07 is offline   Reply With Quote
Old 07-05-2013, 03:35 PM   #3
peekeesh
Member#: 316476
12 WRX
Gumy and CNUsubie07, how did you initially set up your bluetooth connection?
Try clearing existing connections and set it up using the BT steering wheel control and voice commands. See if that helps.
peekeesh is online now   Reply With Quote
Old 07-05-2013, 04:00 PM   #4
hrkahn
Member#: 343711
2013 STI
my galaxy s4 is weird about the bluetooth connection. i find that if i turn the bluetooth off on the phone and turn it on once the car is on. it will autoconnect and work well.
hrkahn is offline   Reply With Quote
Old 07-18-2013, 08:49 PM   #5
AsianBajan
Member#: 311331
Does anyone have more input on this ? I am at a lost as well.... 2013 STI with factory radio / no nav.
Galaxy S4 and always have problems auto connecting. I even downloaded an app called autoconnect and still have issues.
Anyone previously in this thread get any more info on this ?
AsianBajan is offline   Reply With Quote
Old 07-19-2013, 11:37 AM   #6
Giamilton
Member#: 8002
2013 WRX 5dr/Abarth
WR Blue/Nero
I heard that you want to use the voice commands and not the buttons on the radio. I have a Galaxy and a 2013 with no Nav.
Giamilton is offline   Reply With Quote
Old 07-19-2013, 12:13 PM   #7
gumby1976
Member#: 26248
2016 WRX
Lapis Blue
Exactly, I ended up getting both cars connected using the voice commands. Just make sure that you unpair your phone and car on both devices first (the S3 likes to remember pairings) and you should be good.
Both of ours work perfectly now.
Old 04-22-2014, 11:36 PM   #8
shotz86
Member#: 253506
2014 WRX
I have this same problem with my S3. Did any of you have luck pairing with the voice commands?
shotz86 is offline   Reply With Quote
Old 04-23-2014, 09:02 AM   #9
dharel0bs11
Member#: 258998
2011 Outback Sport
Blue Pearl/Steel Silver
Yes. You have to use the voice commands.
dharel0bs11 is offline   Reply With Quote
Old 04-23-2014, 11:42 PM   #10
goxxy
Member#: 340068
2013 WRXSedan Lifted
World Rally Blue/Mud
I've had the same issue with my S4/S5.. I frequently have to delete the phone and once the car is turned off and back on again have to force it to reconnect. Has anyone contacted Subaru on this at all?
goxxy is offline   Reply With Quote
Old 04-24-2014, 09:48 AM   #11
dharel0bs11
Member#: 258998
2011 Outback Sport
No, because the solution is in the post above yours. I have an S4 and it connects automatically without issue. Delete all phones from the radio (in the phone section and audio section). Delete all bluetooth connections to your car on the phone. Use the voice prompts to pair your phone.
Old 04-25-2014, 07:39 AM   #12
kbluie
Member#: 263271
2013 wrx
wrb
Same problem with an S5, and using verbal commands as mentioned got it to work correctly.
kbluie is offline   Reply With Quote
Old 04-25-2014, 08:03 AM   #13
thunderbucks
Member#: 365131
2013 WRX Limited 4dr
Crystal Black Silica
+1 on pairing through voice commands. I have an S4, and it seems like button pairing is only for music and required me to me to manually connect every time I turned my car on. 5 months of that horse manure and I figured out the voice connect and thank God it auto connects. I use BT for music 90% of the time, so it's great that it auto connects.
thunderbucks is offline   Reply With Quote
Old 04-26-2014, 03:49 PM   #14
goxxy
Member#: 340068
I had it paired with voice commands previously and was still acting up.
Edit: at this point I have given up and just plug it in through the aux
Old 04-29-2014, 09:18 PM   #15
TurboRush
Member#: 131648
+1... Fixed it for me too
TurboRush is offline   Reply With Quote
Old 05-02-2014, 08:37 AM   #16
mezdup
Member#: 384257
2014 ISM WRX Sedan
thanks everyone. this was driving me nuts haha
mezdup is offline   Reply With Quote
