Old 07-06-2013, 08:08 AM   #1
pannell77
Member#: 165214
Default Viper Alarm System Help - 2011 WRX
So I just purchased a 2011 WRX from a dealer here and there is a Viper RPN 7153V remote on the keychain but the dealer has no knowledge of there being a viper alarm system on the car and nothing happens when you hit the buttons on the fob. I am assuming that it needs to be paired with the system again.
How do I find out what Viper system is installed so that I can get a manual and find out some more information about this system. Where is the main alarm located at typically when installed in the car?
I have never dealt with aftermarket alarms before.
Thanks for the help.
pannell77 is offline   Reply With Quote
Old 07-06-2013, 01:56 PM   #2
wrxeter
Member#: 134734
2013 WRX SE
Tangerine Orange Peel
First, go to the battery and look for an inline fuse tapped off the hot side. Check that fuse (dealer may have just pulled it). If it does not have this, check the fuse box (sign of a shoddy install) for an expansion circuit. They may have also tapped it at the ignition circuit (also not a good install idea, but I've seen it done).
You can either trace that lead off the battery or unscrew the steering column cover and trace the ignition lead for the starter kill.
Other likely locations are the BIU under the steering column or the driver's side/passenger side kick panels - look for taps for the door pins and lock switches - they will likely be butt splices, heat shrinked, or (ewwww) t-taps. Failing that, trace the lead for the aftermarket LED or the pin switch under the hood somewhere. If the car does not have an LED, it likely doesn't have an alarm anymore.
The brain can basically be anywhere inside the cabin (weathertight) or possibly even the trunk. You will have to trace wires. Usually they are well above the steering column or behind the glovebox.
If you got it at a Subaru dealership, they may have cut it dead and returned it to the factory keyless. Alarms are usually a rats nest of wires going every which way.
wrxeter is offline   Reply With Quote
Old 07-06-2013, 02:10 PM   #3
pannell77
Member#: 165214
Awesome info, thanks. I bought from a lexus dealer and have emailed them to see if they have any record of what was or is there.
