Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 07-07-2013, 12:15 AM   #3651
SRP02WRX
Member#: 292138
2005 STi
Originally Posted by eddie-mondo View Post
So. Gonna be buying a lip for my wrx. Looking for people's input on which one you think would look best. . ver 1, 2, or the pro drive. Or How bout the pro d with the v limited???
Prodrive!
SRP02WRX is offline   Reply With Quote
Old 07-07-2013, 12:22 AM   #3652
eddie-mondo
Member#: 282086
2003 wrx
blue
I really like the pro d. I also really like it with the v limited. But thinking that might put the front a little lower than I would like.
eddie-mondo is offline   Reply With Quote
Old 07-07-2013, 12:26 AM   #3653
eddie-mondo
Member#: 282086
2003 wrx
blue
How about the Griffin style body kit for bug eye wrx. I kinda like it too actually. Lol
Old 07-07-2013, 02:33 AM   #3654
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
I'm a bit biased. I like the v2 on the bugeyes...
neko is offline   Reply With Quote
Old 07-07-2013, 12:28 PM   #3655
wayward167
Member#: 253998
13 BRZ
Questions for the autoX guys.....
what is your opinion on the 595's? also going with slightly smaller sidewalls to help with the lack of torque the brz has. confirmed 2nd gear redlines at 58mph. the 215/40's would be lowering that to ~56.
wayward167 is offline   Reply With Quote
Old 07-07-2013, 02:41 PM   #3656
neko
Member#: 46500
Now with 200% more
2 questions.
1. are these for auto-x only? or will they be your street driven tires?
2. Are you running in stock class or other? (i assume stock, which is why you're shooting for the 140TW?)
Other ideas:
- You could also switch to 235/40's on your stock rims (24.4" vs 24.6" @215/45) without going any taller.
- If you're not staying in stock class, you could drop to some lightweight 16x8's or something? Course 16" rubber is getting harder to find. Stupid stock cars these days all running 19's n 20's.... etc. Wonder what brakes the br-z actually has? will 15's clear... (and this just leads me off into brake-upgrade-land thoughts...)
Old 07-07-2013, 04:24 PM   #3657
Subaru_junkie
Member#: 235870
2011 WRX LRP
Owner of IDSubaruClub.com
7 days til satisfying my caveman urge. riiiiiibs mmmm.....
Subaru_junkie is offline   Reply With Quote
Old 07-07-2013, 07:11 PM   #3658
wayward167
Member#: 253998
13 BRZ
Stock and then STX which is a 140TW class.
autoX only 17x7 @14lbs and 215/40's for gearing and weight. i'll probably run 225/45 for DD since they are cheaper, wider and fit better on the 7.5 wide sparcos..
Old 07-07-2013, 07:24 PM   #3659
RedCelicaTRD
Member#: 212731
You need wider then 215.
RedCelicaTRD is offline   Reply With Quote
Old 07-07-2013, 08:53 PM   #3660
XdanoX
Member#: 272369
1999 Fozzy
Green
Widest and stickiest as possible.
XdanoX is offline   Reply With Quote
Old 07-07-2013, 11:23 PM   #3661
wayward167
Member#: 253998
13 BRZ
Pretty sure 17x8's are the largest wheels that'll fit... So 235/40 I think are the biggest that fit those wheels and gear it down a little.
Does that sound better?
Old 07-08-2013, 12:01 AM   #3662
wayward167
Member#: 253998
13 BRZ
BRZ has the 08+wrx front brakes and H6 legacy rears... Pretty sure 16's fit not sure about 15's.....
Yeah not much in the way of tires for that size
Old 07-08-2013, 02:39 AM   #3663
XdanoX
Member#: 272369
1999 Fozzy
Green
Not true take look at Brian's BRZ owner of BK Ind. He's slammed on 19s
Old 07-08-2013, 03:06 AM   #3664
neko
Member#: 46500
Now with 200% more
I chatted it up with lots of suby owners today then went home for BBQ ribs. Just didn't have to drive a suby anywhere to do it... In fact I drove a Evo and mr2 all day.
Kinda feel like Im missing out by not going to twin, but I'm probably already loaded up on work for that weekend.
Schmidt, you can run 235's on 7's... Also, what are 14lbs?
And yes, 16's are getting harder to find, but still. 225/45, and 245/45 wide a avail.
Old 07-08-2013, 03:18 AM   #3665
SRP02WRX
Member#: 292138
2005 STi
Brian's car is sick!
There are a lot of brz's on wheels bigger than 17" wheels.
Old 07-08-2013, 03:19 AM   #3666
SRP02WRX
Member#: 292138
2005 STi
Wheels wheels... It's late haha!
Old 07-08-2013, 10:54 AM   #3667
neko
Member#: 46500
Now with 200% more
What will fit easily within the real of normal suspension parts/geometry and alignment, and what can be fit with some work... often have nothing in common...
Old 07-08-2013, 11:31 AM   #3668
wayward167
Member#: 253998
13 BRZ
Yes but it's not a dedicated track car...and none of the wider tires than 235 give me the gearing advantage I want....
The again I might just autoX on some cheap max performance tires instead of needing 3 sets of wheels
Old 07-08-2013, 11:32 AM   #3669
XdanoX
Member#: 272369
1999 Fozzy
Green
Stock fit easily just stay that way and be boring
I'd try and stagger if it was me I'd go crazy, for you I'd do 17x9 rear 17x8 front.
Old 07-08-2013, 11:37 AM   #3670
wayward167
Member#: 253998
13 BRZ
19's and lowered is definitely not an autocross setup.... Just saying
Old 07-08-2013, 12:23 PM   #3671
XdanoX
Member#: 272369
1999 Fozzy
Green
Full coilovers and lots of other suspension parts I do believe he's done auto x and track days with it. Just saying
I believe Chris Wold is also on 18 or 19s for his race wheels.
Old 07-08-2013, 01:10 PM   #3672
neko
Member#: 46500
Now with 200% more
For auto-x i see several issues tho. Aside from getting kicked out of stock classing.
1st problem: 17's and 215/40/17's vs 19's and lets say 225/35-ish something. I would lay money that unless you're going to spend super, super $$$ on that 19" setup, you've gained a ton of (unsprung) weight. So, traveling in the wrong direction. Might look good, but bad for performance. So there's -1
2nd: Like he said, trying to reduce overall diameter to add low end grunt is not benefited by 19's. -1 again.
Lastly you'll go faster by adding more rubber (bigger contact patch) or sticker rubber. You'll increase your traction for acceleration, cornering, and braking. And since cramming huge wheels under cars usually requires using stretched tiny tires, that's not gonna help either. -1 yet again.
Again, not to say that you can't auto-x on some good looking, bigger wheels n tires. I'm all about enjoying auto-x without being overly competitive (takes all the fun out of it). But that does not make for a faster car.
Hmm. my thoughts on auto-x'ing BRZ if i had one: swap to 4pot/2pot setup, get 15x8 Slips's with 225/45/15 RS-3's.
Fender gap much?
Old 07-08-2013, 01:14 PM   #3673
XdanoX
Member#: 272369
1999 Fozzy
Green
Well if you wanna stay stock then stay stock that easy, If you plan on being competative look at what they use in pro solo (which is 18-19s) so there must be a reason besides look.
https://www.facebook.com/photo.php?f...type=3&theater
Chris Wold
Forgestar F14 Wheels
Front: 18x9 +38
Rear: 18x9 +32
with 245 tires
Old 07-08-2013, 01:19 PM   #3674
XdanoX
Member#: 272369
1999 Fozzy
Green
Brian Krah
Buddy Club Racing SPEC coilovers
- Rays Gram Light 57xtreme wheels in "Winning Blue"- 19x8.5 front and 19x9.5 rear
- Rays Blue center caps
- Kics project Caliber blue lug nuts
- Falken FK452 tires - Front - 225/35/19 - Rear - 245/35/19
Stock - 21lbs
19x8.5 - 21lbs
19x9.5 - 22lbs
Old 07-08-2013, 01:22 PM   #3675
XdanoX
Member#: 272369
1999 Fozzy
Green
Its a very similar car to my s2000's and if I bought one and planned on auto xing competitively I'd go 17-18 and stuff a 245-275 under the car, Now if I was just DDing the car it would be a different story.
Eastern Idaho owners(or any ID really) Check-In!!! Local Get-togethers?? neko North West Impreza Club Forum -- NWIC 386 05-12-2010 07:01 PM
Tuners in Northern Wyoming/Eastern Idaho? bryancregger Rocky Mountains Impreza Club Forum -- RMIC 3 01-06-2010 12:05 PM
NWIC - Official "I saw it on Craigslist" Thread Dena North West Impreza Club Forum -- NWIC 4 11-02-2008 11:19 PM
