Old 07-08-2013, 01:34 AM   #1
BURNING4ORCE
Member#: 356215
Default 04 Sti Stage 2
Car: 04 STI
Tuner: Myself
Dyno: Road tuned-Virtual Dyno
Trans: 07 sti 6 speed
Gear: 3rd gear pull
Baseline: 250whp
Peak HP at RPM: [email protected] rpm
Peak Torque at RPM: 322lbft @ 3598 rpm
Target boost: 19psi-14psi
Fuel: pump Cali 91
Target afr: 10.8
Timing: 13 peak load - 24.5 up top
Temp: Ambient 80
Mods:
- Stock vf39
- Whinebro 255 pump
- Turboback
- Hallman pro rx mbc
- K&N Drop in Filter
- DW 850cc
Consistent power all around even in higher gears with no hint of knock but motor has very high miles in it so it's maybe down in power. I've made more power with more timing added but I get knock at higher gears that's not showing on knock free 3rd gear pulls. Just want to see what other people are making on the virtual dyno on pump 91 as I'm fairly new to the forums and to subies as I've seen different versions of this program. I'm planning to switch to e85 soon so I'll update along with maybe aps 70mm CAI, external wastegate, and new clutch before going bigger. Then on to a fp green sitting in the garage with bigger pump and injectors.
Base line pull was done by just myself in the car and the final tune with me and a friend in the car.
Proper tire and rim combo 235/45/17
BURNING4ORCE is offline   Reply With Quote
