Old 03-27-2013, 08:17 PM   #2726
JonnyV2889
Member#: 197384
2006 WRX Ltd
Scotty.
Read through the first 10pgs not doing all 273 right now on the mobile. Did you swap to heavyweight to increase change intervals or was the lightweight still to slick? Been running straight lightweight for the last ~35k w/o any complaints on a tranny w 140k.
JonnyV2889 is offline   Reply With Quote
Old 03-28-2013, 03:10 AM   #2727
Originally Posted by JonnyV2889 View Post
Scotty.
The lightweight wears out....the heavyweight does not....at least at any rweasonable interval that i can discern
im going to be using ~50k mile trans lube change intervals(up from 20k) and it likely can go a lot longer under more casual use
no reason to use something that is gonna wear out if you can use something that wont....right???
i have found NOTHING that leads me to believe that the lightweight shockproof should be used AT ALL, if the heavyweight is available
i wont be using the lightweight again
Old 03-28-2013, 12:58 PM   #2728
BBY_Hero
Member#: 234236
06 STI
AW
Didn't see anything on age of transmissions I have 180k would this be good to use? I have just put Castrol SYNTRAX LIMITED SLIP 75W-90 in my rear diff.
Thanks in advance
BBY_Hero is offline   Reply With Quote
Old 04-05-2013, 05:41 PM   #2729
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
I appreciate that the OP has been updated with new findings regarding the cocktail. Ive been running it for years, and its never done me wrong.
Also appreciate the typical nasioc banter found on the preceeding pages. Though it seems that the newer groups are getting worse and worse.
RallyImprezive is offline   Reply With Quote
Old 04-05-2013, 05:45 PM   #2730
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
Thanks in advance
In my experience, on a trans from a 1995 Impreza with 235k miles, it was better than whatever black water it replaced. The trans went through severe driving conditions and none of the drivers complained.
Just my experience though. I dunno what kind of shape your trans is in.
Old 04-07-2013, 02:59 AM   #2731
Thanks in advance
you do not want and do not need any sort of limited slip gear oil in the rear end of your(or any usdm) wrx
Old 04-07-2013, 03:03 AM   #2732
the OP is out of the picture....I wrote that addendum to the first post and 'ole uncle Ron stitched it in there for us
Old 04-09-2013, 12:28 PM   #2733
puro
Member#: 352533
2004 WRX
Platinum Silver
I've read through most of the thread. Thanks Scotty for the mix. I've located redline heavyweight shockproof and syncromesh but I'm having problems finding the castrol 80w-90 gear oil close to me.
Does anyone know anywhere besides amazon (12pk 2week wait), oreilly's (nowhere near me), or pepboys (an hour away) where I can get this stuff? I found one bottle on ebay... but I need two..
puro is offline   Reply With Quote
Old 04-26-2013, 12:29 AM   #2734
awesomedick
Member#: 218360
Default Scotty's cocktail (confusion)
I am just about to change the oil in my trans and accessed the site to find the . quantities. I purchased all of the ingredients about a year ago and find that I have the Redline Lightweight shockproof. I was sure it was right at the time. Reading several forums in here I see that a lot of owners are using the lightweight. However the answer and instructions to the question very clearly state the use of the heavyweight oil. Help, which one is it?
Thanks,
Rick
awesomedick is offline   Reply With Quote
Old 04-26-2013, 01:44 AM   #2735
JonnyV2889
Member#: 197384
2006 WRX Ltd
Thanks,
Rick
Scotty changed it to hw because of breakdown/ intervals. However redlines website discourages hw in syncro applications...
Old 04-26-2013, 12:36 PM   #2736
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
That's what the Synchromesh is for
Superorb is offline   Reply With Quote
Old 04-27-2013, 11:02 AM   #2737
and subaru transmissions arent ordinary transmissions, either
Old 06-04-2013, 06:49 PM   #2738
MoRex
Member#: 231966
Pure Silver Metallic
Hey Scotty, is Grimmspeed referring to your cocktail here?
grimmspeed
edit: i think... that's the old version, with lightweight shockproof instead of heavyweight, is that correct?
I'd like to try the cocktail in my 5mt ('03, 70k miles).
Thanks in advance
MoRex is online now   Reply With Quote
Old 06-04-2013, 08:04 PM   #2739
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
grimmspeed
Thanks in advance
You only have 70k miles on your 03? I have 106k on my 02 and I thought that was low.
Old 06-04-2013, 09:00 PM   #2740
MoRex
Member#: 231966
68,350 to be exact (110,000kms)
Old 06-05-2013, 01:49 AM   #2741
grimmspeed
Thanks in advance
just buy the heavyweight and substitute it for the lightweight and all good
Old 06-24-2013, 08:12 PM   #2742
Swagon_Wagon
Member#: 294424
1999 RSti
white as ****.
Just put the heavyweight version in and I love it. Secound time with it and its awsome. Running in a jdm ra 5mt with dccd
Swagon_Wagon is offline   Reply With Quote
Old 07-08-2013, 10:11 AM   #2743
slaythebad
Member#: 353093
2002 WRX Wagon
Has anyone had any luck at all finding the redline heavy anywhere brick and mortar in NYS? Or should I just order it online and wait?
slaythebad is offline   Reply With Quote
Old 07-10-2013, 06:07 PM   #2744
RHD 93 STi
Member#: 241290
2004 Forester
JBP
grimmspeed has it
RHD 93 STi is offline   Reply With Quote
Old 07-10-2013, 10:02 PM   #2745
tallgeese33
Member#: 361980
i have heard that some 4x4 aftermarket truck shops carry redline , might wanna try calling
tallgeese33 is offline   Reply With Quote
Old 07-19-2013, 11:51 PM   #2746
bicycle repairman
Member#: 341344
2004 wrx hybrid
Just changed to the cocktail @ 274,000 miles on a '04 wrx wagon. Dino 75w90 before. Solved the 4th gear grind that was getting annoying and the shifting in general is just better. Getting into reverse still takes some coaxing sometimes, but it too has become better, just not solved.
bicycle repairman is offline   Reply With Quote
Old 07-20-2013, 01:12 AM   #2747
MoRex
Member#: 231966
whoa, that's a LOT of miles!
Old 07-20-2013, 05:30 PM   #2748
Ryder0724
Member#: 362819
2007 Impreza 2.5i
Sorry if its already been said but 275 pages is too much looking for me but what is a cocktail? And dccd?
Ryder0724 is offline   Reply With Quote
Old 07-20-2013, 11:46 PM   #2749
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
cock·tail (kktl)
n.
1. Any of various mixed alcoholic drinks consisting usually of brandy, whiskey, vodka, or gin combined with fruit juices or other liquors and often served chilled.
DCCD Explained
Old 07-21-2013, 12:48 AM   #2750
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
from post number 1
2qt 80w90 Castrol HypoyC(NOW labeled Axle Limited Slip 80W-90 by Castrol in North America) NO stupid PM's on this either
1qt Redline HEAVYWEIGHT SHOCKPROOF....NOT the LIGHTWEIGHT!!!
1qt Penzoil 'SYNCHROMESH' transmission fluid....the GM synchromesh fluid PN 12345349 is available at any GM dealer and can be used if the Penzoil product is not available....the Penzoil one IS better.
__________________________________________________ _________
1) FOR BEST RESULTS DRAIN THE TRANSMISSION FOR AT LEAST 30 MINUTES...REMOVE the trans dipstick and use a funnel(see below) with a long spout....
Pour the WHOLE BOTTLE of the HEAVYWEIGHT SHOCKPROOF(NOT THE LIGHTWEIGHT) into the trans....
2) Pour EXACTLY 1/2 of ONE of the bottles of CASTROL into the now empty shockproof bottle and shake it gently.....and pour THAT into the trans
3) Pour ALL REMAINING CASTROL PRODUCT into the trans.
4) Pour EXACTLY 1/3 of the 'synchromesh' into the trans and replace the dipstick
5) Drive car in a NORMAL AND RATIONAL AND REASONAL MANNER using ALL the gears INCLUDING REVERSE.....
6) Park car on LEVEL surface....wait at least 20 minutes and check trans fluid level.....top up with the synchromesh product.
THE 5MT TRANSMISSION DOES NOT LIKE TO BE AT ALL UNDER FILLED....A BIT OVER FILLED IS BETTER THAN ANY UNDERFILL AMOUNT.
OVERFILLING THE TRANSMISSION S L I G H T L Y IS NO BIG DEAL.....DO NOT WORRY ABOUT IT. NO stuid pm's or posts on this please
ALWAYS POUR S L O W L Y.....or ya may end up with it all over UNDER the car and NOT in the trans where ya want it
these funnels work great...and no need to take the IC off
http://www.tools2parts.com/Blitz-606..._7c2023_d_0355
POUR SLOWLY....think glacial, here.
1 Lucky Texan is offline   Reply With Quote
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 08:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
