Old 11-30-2008, 04:07 PM   #351
BlueSTI4Me
Member#: 34361
04.7 STI
Post to subscribe.....it's time
BlueSTI4Me is offline   Reply With Quote
Old 09-09-2009, 01:00 PM   #352
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
subscribed, so i can read it later
Dirty25RS is offline   Reply With Quote
Old 11-20-2009, 04:51 AM   #353
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I'm sorry for asking what seems to be a simple question but I have been searching for twenty minutes and have not found a definitive answer to this question -
Say you have a stock 2004 STI. When you convert the front to the new bearing style using stock 05 hubs/knuckles/rotors/struts why is there an issue with the abs sensor? I assume the tone ring is attached to a part that isn't being converted? What factory part would be needed to get the ABS working?
ciper is offline   Reply With Quote
Old 11-20-2009, 08:29 AM   #354
red5001
Member#: 33942
04.5 STI
wrb
The tone ring is attached to the driveshaft (cv joint). The tone ring is in a different location on the 2005 cv joints. So you have to move it on the 2004 axles in order for it to line up with the sensor location on the 2005 knuckles.
red5001 is offline   Reply With Quote
Old 11-20-2009, 10:25 AM   #355
ej20ajk
Member#: 113223
08 WRX NB R180
I'll be doing 5X114.3 on my STi wagon. I have a late model 04 STi axles/tranny (male axles) .Will 05 STi axles bolt up to the tranny or splines are different?
ej20ajk is offline   Reply With Quote
Old 11-20-2009, 10:34 AM   #356
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Bingo.
crystalhelix is offline   Reply With Quote
Old 11-20-2009, 02:18 PM   #357
red5001
Member#: 33942
04.5 STI
wrb
If you have the later style axles you should be able to swap to the 05 axles.
Old 11-20-2009, 06:34 PM   #358
ciper
Member#: 15543
90BJ Legacy LS ABS
That was my next question. Couldn't I just swap the seals on the transmission and use 2005 style axles for a complete conversion?
Old 11-21-2009, 08:27 PM   #359
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Its not the seals, its the stub shafts on the trans. Early 04 sti has a male style trans with female shafts, the later years have female trans with male shafts. I have early 04 sti axles on my 5mt though, cheap and easy upgrade.
scby rex is offline   Reply With Quote
Old 11-21-2009, 08:44 PM   #360
ciper
Member#: 15543
90BJ Legacy LS ABS
But aren't the stubs on the 04 trans held in with circlips just like on the 4eat? From what I know the 5mt was the only one with "permanently attached" stubs.
I swear you could convert a male 6 speed to female and vice versa with the correct seals...
edit: Yeah I was right. From the The end all of 6 speed swap information thread
If you choose a male axle 6mt and you have a female front axle car you will need these:
806730042 Oil Seal LH x1
806730041 Oil Seal RH x1
38415AA110 Axle Stub x2
805329010 C-Clip x2
If you have a Female 6mt and a male front axle car you will need the following:
806735230 Oil Seal x1
806735240 Oil Seal x1
Which also means you shouldn't need to remove the roll pin on your 2004 STI since the axle stubs will slide right out in the same style as the rear differential.
Old 11-22-2009, 01:45 AM   #361
scby rex
Member#: 104878
02 wrxbastardchild
Not on the early 04 STi (later in the year they changed) They use the roll pin just like the 5mt, but have the better cv joint instead of the tripod ones. I have them on my 5mt right now with 06 sti hubs and the 6gun tone ring adapters.
2004- Part# 32000AG880
Ratios= 3.636 / 2.375 / 1.761 / 1.346 / 0.971 / 0.756
3.90 final drive (front and rear)/has both male and female front axles (check production date, changes mid year). LSD Front diff/DCCD Center (36F/64R Bias Open)
Old 07-19-2010, 04:12 PM   #362
bcjp11
Member#: 249983
Very informative thread.
bcjp11 is offline   Reply With Quote
Old 03-10-2013, 04:53 PM   #363
exige
Member#: 197729
Ive been doing research about the 5x100 to 5x114.3 conversion. Seems I'll need a lot of parts from the later 5x114.3 cars.
My question is, I have a GC8 STI type RA V5. I wonder if its the same as coverting a normal WRX?
exige is offline   Reply With Quote
Old 03-10-2013, 06:52 PM   #364
scby rex
Member#: 104878
02 wrxbastardchild
depends if you have a r180 rear.
Old 03-11-2013, 02:35 AM   #365
exige
Member#: 197729
I think i do have the R180 rear diff. Its difference from normal WRX GC8
Old 03-11-2013, 06:53 PM   #366
scby rex
Member#: 104878
02 wrxbastardchild
If you have a r180 then its pretty straight forward. Its like a bearing replacement for the rear but you would use 5x114.3 hubs. The front would be just like everyone elses swap.
Old 07-07-2013, 10:45 AM   #367
meat_WRX
Member#: 96919
2004 sti
black
so I have an 04 STI and of course Im here because I want 5x114. So I bought this, and from what I can tell, the only thing left is new coils (need them anyway) and wheels.
i was reading about rear axles being different lengths, but then i read where they were not, and I can retain my rear axles. So I'm pretty sure I have everything Needed.
Im loving the fresh black calipers, looking forward to the Aluminum Rear arm upgrade, and I can replace some of these bushings while everything is sitting off the car in the garage.
can everyone see the pictures?
meat_WRX is offline   Reply With Quote
Old 07-08-2013, 11:31 AM   #368
meat_WRX
Member#: 96919
2004 sti
black
anyone?
Old 07-09-2013, 11:46 AM   #369
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Yes we can see the pics.
Bikelok is offline   Reply With Quote
Old 07-09-2013, 05:46 PM   #370
javid
Member#: 54304
04 STi
TopSpeed-dAng!
your 04 rear axles will work fine.
javid is offline   Reply With Quote
04 sti to 05 sti axle/hub swap questions mesa50w Transmission (AT/MT) & Driveline 0 03-23-2009 05:46 PM
04 STi to 05 STi bumper swap? Admission_Regret Interior & Exterior Modification 10 09-23-2008 11:19 AM
04 STi to 05 STi Center console swap Drake13 Interior & Exterior Modification 4 12-28-2007 06:25 PM
04 sti to 05 sti climate control swap LUKEWMC Electrical & Lighting 6 01-18-2007 05:41 PM
04 wrx to 05 STi, alittle srt left out StealthfishWRX Newbies & FAQs 2 10-05-2004 01:58 AM
