Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 07-09-2013, 07:02 PM   #501
Vectors2Final
Member#: 15553
'15 F80 M3 YMB/SS
No Driving in Korea...
The new flight 214. Has to be a wake up call for the peers landing there.
Vectors2Final is offline   Reply With Quote
Old 07-09-2013, 07:06 PM   #502
Meat Supply
Member#: 137902
---- licking some
tasty ass yogurt lids!!
crazy, seems like they'd close the runway for a bit...
Meat Supply is offline   Reply With Quote
Old 07-09-2013, 07:06 PM   #503
Bryan T
Member#: 17948
Originally Posted by Counterfit View Post
"Ejected from the aircraft during the accident sequence"
That usually doesn't end well.
I had wondered how they had survived, given that the girls in the last row of seats didn't make it.
Bryan T is offline   Reply With Quote
Old 07-09-2013, 07:21 PM   #504
Indocti Discant
Member#: 138000
L Bo Hope you meet
the spirit in the sky
It is closed. that is 28R which is parallel to 28L.
Indocti Discant is offline   Reply With Quote
Old 07-09-2013, 07:22 PM   #505
Vostok 7
Member#: 30209
Do you need to
read this in Braille?
Forced perspective, how does it work?
Vostok 7 is offline   Reply With Quote
Old 07-09-2013, 07:24 PM   #506
Indocti Discant
Member#: 138000
L Bo Hope you meet
4 point harnesses? vs lap belts?
I had this precise discussion with a flight crew a few months ago. Oh they make you sit in these jump seats even when a empty regular seat is available right across from you.
first response was its needed b/c they are close to all the necessary communications and rescue equipment.
Then I told her about the four point harness and how crappy a lap belt is in restraining you. she was horrified.
On my other most recent flight (737-900) I asked about the strap across the rear door window. Basically there to safeguard the door opening prior to cross check (?) so that the slide doesn't inflate indoors. I wonder if the door popping led to the slide inflating indoors.
Old 07-09-2013, 07:27 PM   #507
Thumper23
Member#: 11571
Arming the doors (ie if you now open the door the slide deploys, outside of the aircraft). I'm sure the aft end of the aircraft was so much deformed it caused one of the doors to come inside.
Thumper23 is offline   Reply With Quote
Old 07-09-2013, 07:29 PM   #508
Indocti Discant
Member#: 138000
L Bo Hope you meet
yep. which is pretty standard. I have once had to tell the Virgin stewardess (back in the early 2000s) to check her co-workers cross check since I don't think she did it. She hadn't.
on the 737-900 the cabin crew was adamant that opening the rear door without disarming it would lead to the slide inflating on the inside.
anyone with better insight on this?
Old 07-09-2013, 07:34 PM   #509
Globerunner513
Member#: 188062
1975 Datsun 280z
Daytona Blue
Kind of. It is basically a simple indication to any outside personnel that the slide is armed, and opening the door will inflate the slide. Some aircraft have a different arming system which will only set off the slide if the door is opened from the inside, but it will still be up to the ground crews to understand which aircraft are safe to open from the outside.
The 'cross check' that is called for is for the flight attendants to check both service doors in their area and ensure the slides are armed, and is indicating as such to anyone outside the aircraft.
EDIT: dammit thumper. Way better explanation too.
Globerunner513 is offline   Reply With Quote
Old 07-09-2013, 07:34 PM   #510
Thumper23
Member#: 11571
I don't see how. The whole point is so that if the armed door opens the slide deploys outside of the aircraft.
Did this cabin crew pass their annual?
Old 07-09-2013, 07:36 PM   #511
BigWrecKs
Member#: 93830
11.5 New Balance
Shoes
Why would the slide open inside the cabin at all? This, to me, is a no-brainer for the engineers who designed the door/slide system.
BigWrecKs is offline   Reply With Quote
Old 07-09-2013, 07:41 PM   #512
Indocti Discant
Member#: 138000
L Bo Hope you meet
She was a very tall attractive blonde. the other was one was a modelish brunette.
soo... I donno. I did end up getting two free mini bottles of dewars out of them.
I know that an armed door, slide opens outward etc but wondering if there is a flaw in this design that if the door doesn't open outwards completely, will the slide inflate on the inside as it can't go outside?
Old 07-09-2013, 07:43 PM   #513
banman
Member#: 12408
2006 Legacy GT
I'm impressed that all of the doors (that we can see, anyway) opened at all. It probably wouldn't take much fuselage deformation to jam a door.
banman is offline   Reply With Quote
Old 07-09-2013, 07:48 PM   #514
Indocti Discant
Member#: 138000
L Bo Hope you meet
I don't think a fuselage operates the same way as a motorized vehicles (uni) body.
Old 07-09-2013, 07:50 PM   #515
Thumper23
Member#: 11571
What airline was this? I need to fly them more often.
Old 07-09-2013, 07:55 PM   #516
Indocti Discant
Member#: 138000
L Bo Hope you meet
United..
BUT... they might be unicorns. Amazingly enough I ran into them on my return leg as they were on my inbound.
looking at post crash shots the starboard aft door for oz214 was closed. The port was open.
Old 07-09-2013, 07:55 PM   #517
banman
Member#: 12408
2006 Legacy GT
If anything, it should be worse - in an aircraft, tolerances are much tighter and the door is designed to fit like a plug. Mind you, I'm sure they reinforce the hell out of the door frames.
Old 07-09-2013, 07:57 PM   #518
Indocti Discant
Member#: 138000
L Bo Hope you meet
I am going to guess precisely that. Plus the fuselage is meant to be springy and I'd imagine any give would take place around the reinforcement area.
Old 07-09-2013, 08:11 PM   #519
etothen
Member#: 221885
09 Ivory Tower
Ivory...duh
So that is where 777's come from?
etothen is offline   Reply With Quote
Old 07-09-2013, 08:13 PM   #520
Thumper23
Member#: 11571
Kinda. Necrophiliac 777.
Old 07-09-2013, 08:27 PM   #521
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
"As we make our final approach into San Fran International, please make sure you are seated with your seat belts securely fastened, seatbacks and tray tables are in the upright and locked position, and any personal items are stowed for the duration of the flight. Those of you seated on the left side of the aircraft, please look right."
Old 07-09-2013, 08:46 PM   #522
richy_21
Member#: 58670
2005 got muuuuu?
Lol! Nicely put! :ClapsContinuously:
richy_21 is offline   Reply With Quote
Old 07-09-2013, 09:03 PM   #523
banman
Member#: 12408
2006 Legacy GT
Paraphrased from an old e-mail forward.
http://www.snopes.com/photos/airplane/mandarin.asp
Old 07-09-2013, 09:10 PM   #524
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I had actually never seen that one, but now I feel lame.
Old 07-09-2013, 09:37 PM   #525
rogue
Meowstrosity
Super Moderator
Member#: 7977
100% Abuse
"As we make our final approach into San Francisco International, please make sure you are seated with your seat belt securely fastened, your tray table and seat back in the fully upright and locked position, and your personal items stowed. If you think we're kidding about all this, look to your left. I swear to GOD I will crash this plane if you don't settle down back there!!"
rogue is offline   Reply With Quote
