Old 07-10-2013, 09:15 PM   #501
jdrummer88
Member#: 319326
2012 STI
Will this work on the newer models with the carbon fiber looking badge?
jdrummer88 is offline   Reply With Quote
Old 07-25-2013, 10:01 AM   #502
subiFKNpowers
Member#: 361942
06 TR VF39/E85
Graphite & Carbonfiber
Lightbulb
yes it will....im getting rdy to do mine!!
subiFKNpowers is offline   Reply With Quote
Old 07-28-2013, 11:46 PM   #503
Gr3asy
Member#: 347099
2013 STI Hatch
WR Blue Pearl
This is such a badass write-up!!!
Gr3asy is offline   Reply With Quote
Old 07-29-2013, 09:17 AM   #504
subiFKNpowers
Member#: 361942
06 TR VF39/E85
Thumbs up
Just completed mine....color matched the background and kept the chrome stars
Old 08-02-2013, 02:28 PM   #505
ludakris
Member#: 342133
2013 WRX
I may have missed this earlier.. but is there a trick to keeping the chrome intact?
ludakris is offline   Reply With Quote
Old 08-02-2013, 03:34 PM   #506
subiFKNpowers
Member#: 361942
06 TR VF39/E85
Thumbs up
Yes... just don't remove the background layers where the chrome is located. I used several grits of sand paper to remove the blueish carbonfiber background. No worries because once the badging is removed and you have access to the back you'll notice where the stars are located they are actually inset so you basically can sand down the back to remove the background without harming them. I sanded several grits and finalized with a stage 4 1500 grit.
I did five coats on paint after taping the front off.. then reapplied new 3m auto two way taping just as it was from factory.
Just take your time and be patient it will turn out topnotch... goodluck
Old 08-20-2013, 01:07 PM   #507
ludakris
Member#: 342133
2013 WRX
thanks, I have to get out and pop mine off and get to sanding...
Old 08-21-2013, 11:58 AM   #508
Mommymissile_wrx
Member#: 362530
didnt know how simple it was to do this, my badge is starting to crack on the inside hmm got to try it out.
Mommymissile_wrx is offline   Reply With Quote
Old 03-20-2014, 09:19 PM   #509
The04of518
Member#: 269322
2011 sti
goof off did slightly haze the emblem so be prepared to wet sand and buff i personally on the second one taped off the front with electrical tape the tape started to dissolve slightly yes but it prevented the front from hazing. I used a toothbrush also worked better than qtips. girlfriend/wife's seems to work best.
The04of518 is offline   Reply With Quote
Old 03-21-2014, 01:19 PM   #510
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
The only thing I would suggest for painting the stars (and ring if applicable) is to use a pipette instead of a brush. Just make sure the badge is level to keep the paint from running out of the recessed areas. It makes painting so much easier and lessens any mistake cleanups. I did this for a set of Honda center caps and they came out great.
Preludicrous is offline   Reply With Quote
Old 03-22-2014, 04:15 AM   #511
Wrbboost
Member#: 362505
well im lost, exactly how do you get the front badge off on a 2013 sedan and the rear one off?
Wrbboost is offline   Reply With Quote
Old 03-22-2014, 07:13 AM   #512
MrP206
Member#: 353275
2013 WRX
For the front I removed the bumper completely then took the grill out and heated it up with a heat gun "blow dryer" and slowly pried it off I didn't bend or break anything so that worked for me...I have not done the rear but I think by heating it up and pushing it out from the inside of the trunk would work or atleast get enough space to get under it
MrP206 is offline   Reply With Quote
Old 03-29-2014, 04:24 AM   #513
Wrbboost
Member#: 362505
so really there is no reason to take off the bumper you could just take the badge off with it on?
Old 03-29-2014, 05:35 AM   #514
MrP206
Member#: 353275
2013 WRX
Probably yay...I just wanted less bumper to work around
Old 04-06-2014, 08:39 PM   #515
Fairlaner
Member#: 271222
My attempt ...
Fairlaner is offline   Reply With Quote
Old 04-06-2014, 08:55 PM   #516
Jesse25463
Member#: 386933
That loos awesome. Are the 2014 badges the same way, where you can just rub off the old paint and reveal the clear plastic underneath? I'd love to do this if the badge is still made that way
Jesse25463 is offline   Reply With Quote
Old 04-06-2014, 09:58 PM   #517
MrP206
Member#: 353275
2013 WRX
Ya they should be I highly doubt it's changed
Old 04-06-2014, 10:06 PM   #518
Wrbboost
Member#: 362505
I have a 13 and tried this, tried sanding, goo gone, and goof off, the goof off worked but ate away at the plastic and the badge became all hazy, had to spend $60 on a new badge never tryin this again
Old 04-07-2014, 04:49 AM   #519
MrP206
Member#: 353275
2013 WRX
Ya that's pretty much what mine did so I have to order a new one too...eventually I will try again but I will just order a second badge so I have an original one to go back to
Old 04-07-2014, 02:16 PM   #520
sleeperfxt
Member#: 359223
Def need to do this
sleeperfxt is offline   Reply With Quote
Old 04-07-2014, 07:23 PM   #521
Jesse25463
Member#: 386933
Can you just buy a decent black badge that you can stick on in place of the blue one? I painted the badges on my Toyota, but they are a bit different than the subaru badge. It wouldn't quite work the same.
Old 04-07-2014, 07:31 PM   #522
TheyCallMeMike
Member#: 378937
2014 WRX
Same thing happened with mine! After 2 failed attempts I went with vinyl overlays lol
TheyCallMeMike is offline   Reply With Quote
Old 04-07-2014, 07:58 PM   #523
easterbran
Member#: 307359
'05 STi Stage II
You probably could, but it won't look very clean. Painting is an easy process, I'd just paint it I were you.
Old 04-07-2014, 08:38 PM   #524
rosedaleny806
Member#: 202070
2012 WRX GR LSB/Gold
2002 WRX GDB PSM
watching
rosedaleny806 is offline   Reply With Quote
Old 04-08-2014, 11:59 PM   #525
Double A-ron2.5i
Member#: 382906
2007 FXT Sports
Anyone try it with green paint!
Double A-ron2.5i is offline   Reply With Quote
How to paint your stock wheels criscross79 Interior & Exterior Modification 545 04-10-2012 05:10 PM
Video Intruction of how to debadge your SUBARU minx1225 Interior & Exterior Modification 15 03-21-2006 05:30 PM
How To Keep Your Subaru Alive (V2 Manual) NewDriverOlderRide Private 'For Sale' Classifieds 0 01-20-2006 11:43 PM
How to paint your seats reconracer Interior & Exterior Modification 62 08-26-2005 01:23 PM
How to paint your aftermarket rims? o2sys Interior & Exterior Modification 2 06-29-2005 04:51 PM
