Old 07-09-2013, 06:52 PM   #1
Motion Lab Tuning
Member#: 228856
Default Motion Lab Tuned 2011WRXHatch Loads of torque with Perrin, Invidia, and MLT!!
Shop: Motion Lab Tuning
Dyno Type: DynoCom FX5000-AWD
Temp: 85F
Boost: 20psi ---> 15psi
Fuel: 93OCT
Target AFR: 11.5:1
SAE Corrections: Default Corrections
Peak HP at RPM: 313whp @ 5850 RPMs
Peak Torque at RPM: 372wtq @ 3600 RPMs
Transmission: Stock 5speed
Gear: 4th
Engine Management: Cobb Accessport Speed Density software
Engine/Power Modifications:
  • Invidia Q300
  • Invidia Catted downpipe
  • Perrin TMIC
  • EBCS
  • AEM CAI
The car came to us with the turbo back exhaust, Intercooler and intake running a cobb map stage 2 map. We installed a 3 port EBCS and the Moroso Dual catch cans. Then we got this silver hatch on the dyno for a new speed density tune. Overall the car feels great with some hard hitting torque out of this stock turbo set up. The Black TMIC with matching turbo heat shield really complemented the black Moroso catch cans making for one clean yet stock looking engine bay.
Follow whats going on at the shop on our Facebook page Motion Lab Tuning - Automotive - Charlotte, NC | Facebook
Thanks for looking!
Andrew J
Andrewj@motionlabtuning.com
www.instagram.com/Motionlabtuning
MotionLabTuning.com - Engineering Performance
Motion Lab Tuning is offline   Reply With Quote
Old 07-09-2013, 08:08 PM   #2
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Awesome numbers
subaru222 is offline   Reply With Quote
Old 07-09-2013, 08:15 PM   #3
besthaticouldo
Member#: 279660
Originally Posted by subaru222 View Post
Awesome numbers
they're good, but they're inflated. if you go look through the MLT dynos they are all extremely high also they run in 4th. it's hard to guess what the real world numbers would be, but my guess is they are about 15-18% high.
besthaticouldo is online now   Reply With Quote
Old 07-09-2013, 09:21 PM   #4
BroBroBroBroBro
Member#: 338211
2011 wrx
best curve ive ever seen for this car...not even E85
it holds out good till 6k thats all you ever need.
BroBroBroBroBro is offline   Reply With Quote
Old 07-10-2013, 11:24 AM   #5
Motion Lab Tuning
Member#: 228856
I don't think 313whp is too inflated. We have also made ~350-370wtq on the old DynoDynamics we used to use on stock turbo cars with similar mods. I will share a few graphs for reference.
http://forums.nasioc.com/forums/show....php?t=2123501
http://forums.nasioc.com/forums/show....php?t=2124194
http://forums.nasioc.com/forums/show....php?t=1881191
There are more that you can browse through as well if youd like.
Thanks,
Alex Goodwin
AlexG@motionlabtuning.com
Old 07-10-2013, 11:25 AM   #6
Motion Lab Tuning
Member#: 228856
Awesome numbers
Thanks guys! Feels surprisingly linear on the street too. Boost comes on nicely and the power is there for your normal shift point. Like you said no real reason to push these cars past 6500 with stock turbos.
Thanks,
Alex Goodwin
Old 07-10-2013, 12:58 PM   #7
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Stop before you look stupid. How far up your ass did you have to reach to pull out those percentages? Those numbers are only ~10% higher than what some friends put down locally on stg2 STi tunes on one of the lowest reading Mustang dynos I've ever used. Yet this means absolutely nothing as it's a different brand of dyno, sitting in a different state, at a different altitude, on a different day with different weather. It matters not whether the numbers are high. It matters that compared to stock or compared to baseline they managed to squeeze more power out of it. The ONLY thing that matters is that the owner of the car is happy with the result.
Cliff's Notes: Who cares?
Scooby921 is offline   Reply With Quote
Old 07-10-2013, 01:51 PM   #8
Motion Lab Tuning
Member#: 228856
Thank you for your input and, thanks for checking out our work
Thanks,
Alex Goodwin
Old 07-10-2013, 03:51 PM   #9
besthaticouldo
Member#: 279660
this is true...also this is not a locally tuned STG2 STi. this is a stg2 WRX. numbers usually range from 280whp-300whp and torque is between 290-320.
http://forums.nasioc.com/forums/show....php?t=2515949 (280/291 - 31whp less and 80wtq less)
http://forums.nasioc.com/forums/show....php?t=2492468
(93 numbers 289/315 - 22whp less and 57wtq less)
http://forums.nasioc.com/forums/show....php?t=2507844
(280/297 - 31whp less and 74wtq less)
now i'm not a mathematician like you apparently are, but thats 21.5%, 15.3%, & 19.8% respectively for the torque numbers and yes they are about 10% high for HP numbers. but that's not with mustangs, those are dynojets. those are also about 17% higher on the torque than the numbers seen on a stg2 on a mustang dyno on a 95* day with a VF52 and 91. and those are just 3, i could find more. granted there are a million different variables for the numbers they are getting. gear, air temp, etc. and they're good numbers and as long as he's happy that's all that matters.
it's not an attack, i'm just curious what the baseline is for MLT on a stock 09+ WRX with zero mods. that'd give you an idea of what the more realistic conversion to another dyno would be.
Old 07-10-2013, 04:39 PM   #10
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
I think everyone would like to see this. Especially since it is one of the items we generally require in the so-called "required format" for posting results in PPB. But we can't force MLT to go buy a car or hunt for a car just to appease the masses. If and when someone stops in with a bone stock, baseline car to put on their dyno I'm sure we'll get to see some useful numbers that put everything into perspective.
Old 07-10-2013, 04:41 PM   #11
Motion Lab Tuning
Member#: 228856
I posted up numbers from a different dyno that we used for the better part of 2years... is that irrelevant to you? Each one I posted made high torque on a DynoDynamics dyno. Are DynoDynamics not a valid dyno brand anymore?
This is just further proof that every dyno reads especially depending on conditions.
Thanks,
Alex Goodwin
Old 07-10-2013, 04:45 PM   #12
besthaticouldo
Member#: 279660
They are a valid dyno brand, however like with all dynos the numbers can be skewed and seem higher than they are.
I more want to see a bone stock car on your dyno currently.
Old 07-10-2013, 09:39 PM   #13
white240hatch
Member#: 95556
2012 WRX 5dr
what is the reason or benefit to the 4th gear pulls?
white240hatch is offline   Reply With Quote
Old 07-11-2013, 05:19 PM   #14
Motion Lab Tuning
Member#: 228856
Great question. It is normal practice to dyno vehicles in whichever gear is closest to a 1:1 ratio. For the average 5 speed transmission, 4th gear is closest to 1:1. With the average 6 speed transmission, 5th gear is selected.
The reason this has become regular practice is due to the method in which Dynojet dynometers calculate horsepower and torque. Dynojets calculate hp by reading mass (weight of rollers) and acceleration (rate of increasing velocity of said weight). So in order to not acquire skewed numbers you have to alleviate any acceleration advantage/disadvantage offered by the transmission's gearing. This is why in this case, as close to 1:1 as possible is ideal.
However when operating a roller based dyno the load cell calculates hp via roller speed and torque applied to the roller, and from there torque is figured by using vehicle rpm as a reference. So technically what gear you run the vehicle in does not matter on loaded style dynos.
However as far as engine load is concerned, you should keep load as high as possible to get a broad enough reading with the engine in-taking and expelling air at it's max efficiency without over working the engine and transmission unnecessarily. That way tuning will be more accurate and you will not run into a boosting issue in the higher gears that you were not prepared for possibly causing engine damage. You don't need to be in the highest gear to do this of course, but you will not reach maximum efficiency in the lower gears so the 1:1 gear works all around.
If I am incorrect in my understanding I don't mind being corrected of course. From the things I've researched and seen this is how I've come to understand the functionality of the two systems.
Thanks,
Steven Watson
StevenW@motionlabtuning.com
Old 07-11-2013, 07:58 PM   #15
Badler
Member#: 133597
Thanks,
Steven Watson
This thread has a lot of info on the 1:1 "myth."
http://forums.nasioc.com/forums/show....php?t=1478091
Old 07-11-2013, 09:37 PM   #16
Equilibrium Tuning
Member#: 26933
2006 STI
Ooo.... memories .
1:1 means absolutely nothing. If you're really shooting for 1:1, you would take the final drive into account and your wheels would be spinning at 7000RPM at the end of the pull!
-- Ed
