Old 07-11-2013, 06:49 PM   #1
Translucent
Member#: 296052
2005 wrb wrx
Default Ej20 rebuild kits?
Do such things exist? Where would I find one? Or do I just have to piece it all together?
Translucent is offline   Reply With Quote
Old 07-11-2013, 06:55 PM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
too many possibilities of things to go wrong which require a rebuild and replacement.
The most common things you typically have to get anyway is a master gasket kit and a timing belt kit while things are apart.
Old 07-11-2013, 07:01 PM   #3
Translucent
Member#: 296052
2005 wrb wrx
I'm just looking at building a fresh little ej20 internally. I didn't know if there was a whole kit I could buy with rods, pistons, bearings, heads, gaskets, and everything else. I know I'll have to get a crank separately but I didn't know if something like that existed.
Old 07-11-2013, 07:09 PM   #4
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
only kits like that that im aware of that include most on your list are stroker kits, if thats what you're looking for.
You can always contact the bigger vendors on this site, they might be able to piece a package deal if you ask.
Old 07-11-2013, 09:47 PM   #5
subaru_gc8
Member#: 29292
2004 WRX wagon
you can get one, but if you buy a oem short block, that is the most affordable way to go. But for what you are asking, here you go
http://6starspeed.com/suejenbuki.html
subaru_gc8 is online now   Reply With Quote
Old 07-12-2013, 09:12 AM   #6
Fordolet
Member#: 346268
04 WRX
I just paid $2000 for a brand new factory EJ20...IMHO that's the best way to go...All factory tolerances...no headaches...$300 for the heads to get rebuilt and I'm done. (while its all apart I'm replacing the oil pump, water pump, timing set, clutch, going with a catless up pipe, and other misc parts so total bill is going to be just north of $4k)
Fordolet is offline   Reply With Quote
Old 07-12-2013, 10:51 AM   #7
Translucent
Member#: 296052
2005 wrb wrx
Thank you all for your input. I'm going with a new short block.
Old 07-12-2013, 02:45 PM   #8
acqui
Member#: 153235
2005 Saab 9-2x Aero
As an aside, is there somewhere that sells a factory shortblock with upgraded internals or is this a case where you purchase the shortblock and have the shop do the upgraded internals if you plan on going with slightly elevated power levels (300-350 whp) range.
acqui is offline   Reply With Quote
Old 07-12-2013, 03:08 PM   #9
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
Pull out EJ205, drop in EJ207, profit.
96SubyImpreza is offline   Reply With Quote
