Old 07-11-2013, 07:25 PM   #1
splif180
Member#: 294817
95 Impreza
white
Impreza GC8 2.2 from 1.8 swap info needed
Ok so i pick up a 95 GC 1.8 awd 5speed two door and the body's id give it maybe a 7.5 . The engine has bad compression only good in #3....#1 and #4 about 50 -60% no compression in#2 So long story short new engine. Well i found a 2.2 from 95 legacy is it plug and play or do i need other parts. I know i read some where it dont take much. But that was probably 3years ago
If anyone knows of a thread explaining parts needed that would help a lot
splif180 is offline   Reply With Quote
Old 07-11-2013, 10:21 PM   #2
theolympiaguy
Member#: 228734
im sure theres a bunch of thread and people will flame lol. its a subaru forum.
But i did the same swap and use it in the rally car as well.
remove 1.8
install 2.2 use the 1.8 intae manifold complete injectors and all, it bolts right on. use the factory engine harness as well from the 1.8, you may need to change your exhaust manifolds depending on the style. also make sure that the ignition wheel (behind the crank pully) has the same count of teeth on it as the 1.8 if not just put the 1.8 wheel on. and tada it plugs and and runs. ;-) maf cars are easy to do lol
theolympiaguy is offline   Reply With Quote
Old 07-11-2013, 11:33 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
^^^ This is pretty much all you gotta do.
A leisurely afternoon of wrenching.
Jay
Old 07-12-2013, 12:40 AM   #4
splif180
Member#: 294817
95 Impreza
white
when you say ignition wheel with teeth do you mean the timing belt gear on the crank shaft
Old 07-12-2013, 02:06 AM   #5
theolympiaguy
Member#: 228734
correct, you can pm me I will give you my # if anyone has other questions
Old 07-12-2013, 09:22 AM   #6
86bratman
Member#: 349020
This particular swap will be completely plug and play.
86bratman is offline   Reply With Quote
Old 07-13-2013, 08:44 PM   #7
JoshP
Member#: 94350
You can do some swapping to use the 2.2 manifold, but I liked the 1.8 mani on the 2.2 better.
JoshP is offline   Reply With Quote
Old 11-17-2013, 05:58 PM   #8
dragonart777
Member#: 373859
what is the defrence with the 1.8 and 2.5 our a 2.2 is it just the bore size
dragonart777 is offline   Reply With Quote
