Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 07-07-2013, 06:34 PM   #9376
Mplvan
Member#: 319020
15 STI
04 Fozzy XT
Originally Posted by Travisty View Post
Get in touch with Darius Warne, he may be able to help you out.
Known good spark plugs, correct gap, and right heat code? Didn't you switch up the tune you were running? Have you been buying fuel from the same station the entire time, or are you switching things up? And you're still on 93, right? I know e85 will eventually clog your injectors, but pump doesn't cause that issue...
Can you swap the injectors around and see if the problem follows the injector? That shouldn't be too difficult, and if you take your time you won't need any new gaskets or o-rings.
New plugs, with correct gap, but stock heat range (wish I went a step colder) gas has been from same station. Maybe I should switch. No knock or knock learn, just misfire codes on high rpm first gear lite load. Maybe +4k to 4.7k. I know I should stay away from that for now. Also watching knock feedback on cylinder 4. It goes up under normal driving but everyone I ask says that's normal. I know I am over reacting but a car should not go into limp mode if you go 4k RPM in first gear. Running stock cobb map until I figure this out. I would love new injectors, rails, pump and a tune from P&L. That maybe the only way to fix the problem.
Mplvan is offline   Reply With Quote
Old 07-07-2013, 07:56 PM   #9377
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
fixed my code..... i love having an extra motor to pull parts and pieces off of.
this open source thing is a piece of cake!!!
acmarcus is offline   Reply With Quote
Old 07-08-2013, 06:42 AM   #9378
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Yeah it is. I'm glad you finally see the light, but now we need to convince the Louis' of that fact.
Louis: Air delivery doesn't seem like the issue. If it was, I'd expect it on at least two cylinders. The first things I would try are swapping components.
Pull cylinder 4 coil pack and put it on cylinder 1, and vice versa. Drive with that for a week and see if the problem follows that coil pack or if stays on cylinder 4. If it stays at 4, I'd swap that injector with a different one (cylinder 2 would make it easy since it's right there).
It does make things easier having aftermarket rails, injectors, tune, etc but I'd hate to see you throw money at the situation and have it be a faulty coil or something. A little bit of troubleshooting could save you tons of money down the line.
Travisty is offline   Reply With Quote
Old 07-08-2013, 08:07 AM   #9379
Layvon
Member#: 195711
STi 04/05/06/07
+1. Love the JR Tune.
I just had a coil **** out on me so it DOES happen. Talk about stressful though!
Layvon is online now   Reply With Quote
Old 07-08-2013, 08:36 AM   #9380
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
It's something stupid but since the problem came up nothing has been done to check it out other then running a sketchy cobb map, and having a compression test done. I rather use my keyboard and complain that I need a new motor.... See I am related
Shortpersonbk is online now   Reply With Quote
Old 07-08-2013, 11:07 AM   #9381
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
Do you need a cool pack?
Old 07-08-2013, 11:23 AM   #9382
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
I'll take a cool pack.
His connector popped off.
Old 07-08-2013, 11:45 AM   #9383
Layvon
Member#: 195711
STi 04/05/06/07
Now now now... the coil pack connector broke. It didn't just fall off
Old 07-08-2013, 11:55 AM   #9384
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
So technically it did pop off, but only after the tang broke.
Old 07-08-2013, 12:04 PM   #9385
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
**** I could go for a cool pack today.
Old 07-10-2013, 08:15 AM   #9386
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
In need of a maf sensor. If anyone has one I could pick up ASAP that would be appreciated.
Old 07-10-2013, 08:52 AM   #9387
Layvon
Member#: 195711
STi 04/05/06/07
I Have one. Mailed out is the fastest I can get it to you, 04 STi
Old 07-10-2013, 11:24 AM   #9388
stiguy1976
Member#: 189739
2004 wrx sti
96 coupe 98 outback
I have one from 04 sti located in grand blank area you can have if you want to pick it up lmk
stiguy1976 is offline   Reply With Quote
Old 07-11-2013, 07:28 PM   #9389
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Why in the **** Did I think Darius's Rotors where gonna fit my 05 Swap. I am a assclown!
Old 07-11-2013, 07:34 PM   #9390
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
Come on just fab something up.
PS: gingerman is this Monday.
Old 07-11-2013, 07:35 PM   #9391
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Sorry, why won't they fit? I am completely uneducated in the ways of the Brembo.
Old 07-11-2013, 07:36 PM   #9392
sackytar
Member#: 149262
PrimerGrey
I know trying to get this POS ready the front are the same both year but the rears are different!!! FUUUUUUCK
4 pot s not brem hoes!
Old 07-11-2013, 07:38 PM   #9393
sackytar
Member#: 149262
PrimerGrey
Are you ready?
Old 07-11-2013, 07:40 PM   #9394
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
Are you ready?
**** no.....
Old 07-11-2013, 07:43 PM   #9395
sackytar
Member#: 149262
PrimerGrey
OH boy going to napa!!!!
Old 07-11-2013, 07:44 PM   #9396
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Durr, that's why they don't fit, haha
Just go buy new rotors tomorrow
Old 07-11-2013, 08:09 PM   #9397
Layvon
Member#: 195711
STi 04/05/06/07
I have 2 full sets of 05 STI rotors if you need to set in a pinch
Old 07-11-2013, 09:21 PM   #9398
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
He needs some from a 06/07 WRX for the 4/2 pots they use.
Old 07-11-2013, 09:26 PM   #9399
Layvon
Member#: 195711
STi 04/05/06/07
Reading >> me
Old 07-11-2013, 09:41 PM   #9400
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
anyone going to be around tmrw night? I need some one to look over my swap and see wtf I did wrong. Tuning not going good
Anyone here from the Grand Rapids, Holland, or Muskegon MI areas? Scooby do Mid West Subaru Owners Club Forum -- MWSOC 19 05-25-2012 02:09 PM
Good alignment shops in the Grand Rapids/Muskegon areas? Paradenu Mid West Subaru Owners Club Forum -- MWSOC 3 12-08-2006 01:20 PM
Anyone close to Grand Rapids going to the Ojibwe ProRally? penjaja Mid West Subaru Owners Club Forum -- MWSOC 4 08-13-2002 01:55 AM
Grand Rapids metroplanner Mid West Subaru Owners Club Forum -- MWSOC 0 06-15-2001 05:00 AM
Grand Rapids MI Autocross Scooby do General Forum Archive 0 09-27-2000 03:26 PM
