Old 07-11-2013, 06:27 PM   #901
r0bman
Member#: 87015
Originally Posted by 240kat View Post
Anybody have experience with the little hibachi grills? My apartment complex says they're okay to use, and I much prefer anything to a plug-in grill.
Depending on how strict they are, maybe a Weber 1520?
I use mine on every single camping trip... does the job for burgers, hot dogs, steaks, etc. as long as you close it up between flips (otherwise it just doesn't put off enough heat).
Amazon.com : Weber 1520 Propane Gas Go-Anywhere Grill : Freestanding Grills : Patio, Lawn & GardenAmazon.com : Weber 1520 Propane Gas Go-Anywhere Grill : Freestanding Grills : Patio, Lawn & Garden
r0bman is offline   Reply With Quote
Old 07-11-2013, 06:29 PM   #902
TrickNipple
moon moon
Member#: 86213
"Comes with porcelain-enameled flavorizer bars"
I love the ridiculous names they come up with for stuff.
Amazon.com : Weber 10020 Smokey Joe Silver Charcoal Grill, Black : Freestanding Grills : Patio, Lawn & GardenAmazon.com : Weber 10020 Smokey Joe Silver Charcoal Grill, Black : Freestanding Grills : Patio, Lawn & Garden
That might be another option too.
TrickNipple is offline   Reply With Quote
Old 07-11-2013, 06:29 PM   #903
r0bman
Member#: 87015
Yeah, they went directly from the box to the garbage. Didn't even bother "installing" them.
Old 07-11-2013, 06:30 PM   #904
dudeondacouch
Member#: 192226
2012 Sandking SWB
can i get a fork with porcelain-enameled flavorizer bars?
dudeondacouch is offline   Reply With Quote
Old 07-11-2013, 06:33 PM   #905
constantinus
Member#: 153174
i have the charbroil(?) version of this for camping. Perfect, but as the 0rb says, you definitely need to put the top back on after flips to get good cooking heat.
I suspect his apartment complex has a restriction on charcoal grills. Otherwise, that'd be an excellent option.
constantinus is offline   Reply With Quote
Old 07-11-2013, 06:36 PM   #906
TrickNipple
moon moon
Member#: 86213
He said that they approved a hibachi, which usually are little charcoal grills, right? I would assume, based on his wording, that the little Weber would be ok. I may be wrong, apartments can have some ridiculous and vague rules.
Old 07-11-2013, 06:37 PM   #907
aod
Member#: 7121
Originally Posted by Dizmal View Post
That's what I pay at the local butcher. Which is worth it for that meat.
But a local grocer?? **** even Lund's and Byerly's(upper class grocers) aren't that expensive here unless you go for the USDA PRIME aged meats. Otherwise $6.99-8/lb for the common big grocery stores here.
In their defense, they do have an in house butcher and they carry only Angus choice and prime cuts.
aod is online now   Reply With Quote
Old 07-11-2013, 06:44 PM   #908
L Bo
RIP Brother
Member#: 8739
Originally Posted by 2k2 View Post
What about a weber q?
I had one similar to the Weber1520, took it to the beach every weekend. After a few seasons the salt air finally gave it incurable orange cancer and had to be put down.
Now have a Weber Q100, a little bigger, just as portable though and compact. Takes the cylindrical propane tubes or you can ger a hose to hook up to a bigger tank. After a year or two of ownership I am still impressed with it every time I hit the ignite button.
Holds heat well, cooks evenly, gets up to temp quick, the porcelain enameled grill grate is easy to clean and non-stick, blah blah blah......... best grill ever owned in a compact.
For 2X the cost of other portable grills it's worth 10X as much IMO.
Amazon.com: Weber 386002 Q 100 Portable 189-Square-Inch 8500-BTU Liquid-Propane Gas Grill: Patio, Lawn & GardenAmazon.com: Weber 386002 Q 100 Portable 189-Square-Inch 8500-BTU Liquid-Propane Gas Grill: Patio, Lawn & Garden
L Bo is offline   Reply With Quote
Old 07-11-2013, 06:45 PM   #909
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
lots of great info. i am NOT grilling for a couple weeks, hitting the road (again).
the thought of BBQ and / or Grilling makes me want to yak right now... Hello? Earl? YAAAAAK.
i'm cooking some chops of pork, mixed veggies (frozen - i know, throw rocks at me) and rice pilaf tonight... on the stove / oven.
the chops come out good more often than NOT.
1 package of chicken bouillon
1 spoon of balsalmic vinegar
1 spoon of concentrated lemon juice
1 spoon of Goya seasoning w/o peppers (or with... whatever)
1 spoon of oregano
1 spoon of EVOO or any cooking oil you use...
3 cups of water
**bring the said chops to a boil, then simmer from 20 to 45 minutes, depending on the thickness... i have 1/2" thick ones on there, so probably 30ish...
**make sure you turn them over more often if they are thin as they will curl up whilst simmering
** spray a roasting pan w/ Pam cooking spray, preheat oven anywhere between 325*F and 350*F
bye the time you put the chops in the oven, they should be done and good enough to eat... the oven is to just crispen them up and brown them on the outside... you can also use your grill, but i found that to be too much work.
your sides, starches may vary... you can add other stuff like soy sauce, red wine vinegar, and other "all purpose seasoning vs. what i listed above... they come out great... once you can "smell them" they are probably done.. but i have a sensative nose... they brown pretty quick in the oven and you'll have to flip them once..
IF you wait to long, they will start to stick. you've been warned.
the flavor profile is somewhat tangy, NOT spicy...
also, you can baste them with whatever after they're cooked.. BBQ, sweet heat, sweet and sour ect... sometimes that helped if they taste is too rich, strong, bland or whatever...
your sides? you're on your own.
ETA: that "general" recipe of 3 cups of water & one packet of chicken bullion works for chicken, lamb and turkey as well.... i don't ever cook more than 2 pounds of meat and i use 1 package w/ 3 cups of water vs. 2 (what most suggest) because of all the liquid add-ons...
ChesterWRX is offline   Reply With Quote
Old 07-11-2013, 06:49 PM   #910
constantinus
Member#: 153174
I think his wording of hibachi may be a bit confusing. All apartments I've lived in had restrictions on charcoal grills on the apartment patio, but were okay with gas grills. You could only use charcoal grills in the courtyard.
Old 07-11-2013, 06:50 PM   #911
aod
Member#: 7121
The **** is wrong with you?
Old 07-11-2013, 06:58 PM   #912
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
look back one page or so... i ate BBQ (grilled) chicken wings two days in a roll. along with boneless / skinless chicken breasts and pork bellies...
there is nothing wrong w/ me... i went on a "grilling" binge after coming of a mission.... there was beer, there was wimmins... there was late-night munchies...
that's like saying "dude"... you don't wanna go out to eat? WTF is wrong with you? *when i was fresh off a 6 week school and stayed at a hotel.... that meant six straight weeks of fast food and dining out... YES, it gets old.
the key is variety. plus, knowing how to cook somewhat makes me steer more towards overall "good" food and cooking, using my crock pot, rice cooker ECT...
Old 07-11-2013, 06:59 PM   #913
Matt K
Member#: 45204
16 you don't
respond to danger
Originally Posted by dudeondacouch View Post
and the finished product, with some southern fried yellow squash:
(was oh my tasty)
what is this, dinner for ants??
also, I decided to do my own half-assed pork and beef kofta travesty. I'm sure they'll be tasty.
Matt K is offline   Reply With Quote
Old 07-11-2013, 07:04 PM   #914
Matt K
Member#: 45204
16 you don't
respond to danger
the same guy just called porkchops "chops of pork"...
Old 07-11-2013, 07:07 PM   #915
dudeondacouch
Member#: 192226
2012 Sandking SWB
<--- also drinking beer. mustn't get golden corral fat.
Old 07-11-2013, 07:09 PM   #916
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
splitting hairs? /thread
are you folks really this anal retentive or do you just play "mr cool guy" online?
lemme guess? spelling and grammar insults coming up next?
grow the **** up good sir. i thought this was the grilling thread... i've seen similar posts for recipes so if you want, you can just report me. maybe i'll get banned. who knows... right?
Old 07-11-2013, 07:14 PM   #917
aod
Member#: 7121
That's still no excuse. That's like saying "this food has too much bacon in it." It is just wrong and should never be uttered. Ever.
Old 07-11-2013, 07:16 PM   #918
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
That thing sucks. It is just a big George Forman grill with a pedestal
Ummm no.
2k2 is offline   Reply With Quote
Old 07-11-2013, 07:17 PM   #919
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
You're doing a great job of making friends around here.
You noticed how every thread you frequently post in eventually turns into the entire thread telling you to shut up? Maybe stop posting for a while and lurk a little more. Just a thought.
Old 07-11-2013, 07:21 PM   #920
TrickNipple
moon moon
Member#: 86213
Ummm no.
The one I used a couple weeks back was. I guess it was a little different because it didn't have the top, but it was just a griddle with raised sections.
Old 07-11-2013, 07:21 PM   #921
Matt K
Member#: 45204
16 you don't
respond to danger
yeah, wow.
anyway:
came out a bit more like porky-spiced-herby hamburgers than I was planning on, but they're tasty. If I had an appropriately middle eastern sauce to serve on them, it'd be more believable.
Old 07-11-2013, 07:22 PM   #922
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
sure.... you can ban me if you want. i honestly don't care. the internet is NOT real life. it will not affect me either way.
it seems to be a one-way street... back to to grilling.
i think i will invest on one of them smokers posted when i get back... need to do more homework. i want to graduate to briskets, pork shoulders and beef ribs... pork ribs (baby backs, st. louis) i can do and have done in a gas grill... they come out good... just gotta watch how much propane you waste....
Old 07-11-2013, 07:26 PM   #923
L Bo
RIP Brother
Member#: 8739
Here is dinner from the other night, marinated chicken breast and portobello caps.
The chicken bathed in; cider vinegar, canola oil, poultry seasoning, garlic powder, salt and pepper. The mushrooms were soaked for an hour in; balsamic vinegar, oil, diced garlic and chopped onions. (The Q100 needs a little cleaning)
Old 07-11-2013, 07:27 PM   #924
Matt K
Member#: 45204
16 you don't
respond to danger
those caps look particularly good. what is liquid egg?
Old 07-11-2013, 07:29 PM   #925
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
Ok yeah. Mine is a propane grill with a single oval element and a cast iron griddle. I have used it for tailgates for years and its awesome. I can cook a ton of food on the little thing.
