Old 03-22-2010, 09:18 AM   #1
Pearly_Whites
Member#: 164714
2007 WRX TR
Unhappy Front end vibration help!
I'm getting a vibration (shimmy) through the steering wheel and floor whenever I'm going over 70mph. I've had the wheels balanced already and the brakes have just been replaced (pads/rotors all around). The car doesn't pull in either direction so I'm kind of stumped as to what might be the cause.
It's really irritating the heck out of me.
Pearly_Whites is offline   Reply With Quote
Old 03-22-2010, 10:54 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Were the wheel road forced? They can be in balance, but still cause shaking. Are the wheels bent at all?
Tony
Old 03-22-2010, 11:24 AM   #3
Pearly_Whites
Member#: 164714
2007 WRX TR
As far as I know they aren't bent. A little rash on the sides from parking but I can't clearly see any dent or bends. I took it to sears since they mounted my tires a month ago and gave me free lifetime balancing for the wheels. I doubt sears roadforce balances but..... Would that make that big of a difference?
Old 03-22-2010, 11:34 AM   #4
Pearly_Whites
Member#: 164714
2007 WRX TR
Also, tire pressures are correct. Could a bad end link cause something like this? Normal city driving is fine but at highway speeds the steering wheel just vibrates in my hand and the front end just feels loose.
I should mention too, that the car doesn't seem to be taking bumps as well either. I only have 59,xxx miles on it.
Old 03-22-2010, 08:11 PM   #5
Pearly_Whites
Member#: 164714
2007 WRX TR
Would a worn out motor mount cause these symptoms as well? I need some help guys
Old 03-22-2010, 08:15 PM   #6
chaingangsoldier
Member#: 113993
2005 STi
CF White
One wheel might be loose or didnt bolt up snug, i had that prob b4 and i took the two fronts off and rebolted them and it went away
chaingangsoldier is offline   Reply With Quote
Old 03-22-2010, 09:02 PM   #7
KoalaSlim
Member#: 94002
I'd start by putting the car up on jackstands and giving all the suspension bits a good tug to make sure they aren't loose. whack some stuff with a rubber mallet. check your swaybar mounts and endlinks just for ****s and giggles.
Beyond that I'd say take your wheels to a more reputable shop and have them balance them. I've had wheels done at the local Goodyear Tire shop and ended up with the symptoms you describe. After shelling out for a proper shop to balance the tires syptoms went away.
Hope this helps. good luck.
KoalaSlim is offline   Reply With Quote
Old 03-23-2010, 09:46 AM   #8
Pearly_Whites
Member#: 164714
2007 WRX TR
I'm not seeing anything wrong with the wheels off. Nothing looks bent, broken, or loose. Gave everything a tug and it's all solid.
I think I have an idea..
When my brakes were done, the drivers side pads were worn out almost down to the backing plate, but all of the other pads still had maybe 30% life left. We thought the caliper was seized but the pistons went back in. Now I'm unsure of if this could cause the problem but I am hearing a light scraping sound as well, like the pads are rubbing the rotor, especially when I'm turning at lower speeds.
If the caliper is seized, could this cause my vibration at higher speeds? I'm having a sinking feeling that this is the cause of my problem...
Old 03-23-2010, 02:18 PM   #9
jdblock
Member#: 235211
2004 STi
Put the front tires on the rear and rear on front. Vibration goes away then its a wheel/tire. If not keep investigating. still there? Get an alignment check. The lasers will tell you a lot that your eyes can't see, ie; wheel bearing, tie rod.
jdblock is offline   Reply With Quote
Old 03-24-2010, 07:06 AM   #10
Pearly_Whites
Member#: 164714
2007 WRX TR
Everyone seems to think this is a wheel problem where as I'm leaning more towards my possibly stuck caliper
Old 03-24-2010, 09:54 AM   #11
jdblock
Member#: 235211
2004 STi
Yes we are. That is what you check first to diagnose the problem. Have you rotated your wheels and test driven the vehicle yet? With a stuck caliper you will get a pull to one side. ROTATE THE WHEELS!
Old 03-25-2010, 09:51 AM   #12
Pearly_Whites
Member#: 164714
2007 WRX TR
I did rotate the wheels. No change in symptoms. I'm really lost on this one.
Old 03-25-2010, 12:29 PM   #13
jdblock
Member#: 235211
2004 STi
I don't even know why I'm posting in here again. Get your alignment checked and tell them your symptoms. Are your tires showing any sign of abnormal wear? Cupping, feathering, the inside or outside wearing faster then the rest? If your not sure take it to a shop before a wheel falls off going down the hiway. There is a lot the machine will see that we can't. Maybe its your inner tie rod, or the wheel bearing. Both things that could cause more damage if not fixed now. If you keep driving on it you WILL cause abnormal tire wear. And you can't just replace two tires like 2wd. It is cheaper to fix problem Z, rather than problem Z and four tires.
Old 09-26-2010, 03:26 AM   #14
castelao
Member#: 258978
Hello,
Did you solve this problem, I have similar situation
I have WRX SW 2005 at 50k I started felt vibration on the steering wheel and I changed pads(necto) and rotors(Tarox drilled), also front left bearing, and at the same time I changed the Shock aborbers for one Kayaba regulable in 4 postions. After 1k I started to feel the vibration on the steering again and in the pedal while breaking, also feeling of general vibration in the car. I change a new set of discs(Tarox ones), after 500km same vibration again. Third time I installed Original discs of the Subaru, after 200km same vibration, and the vibration is now in the gas pedal, mainly between 3000rpm and 4000rpm, also while braking the brake pedal has vibration decelerating at some speeds mainly 60Kmh, the vibration is heavy really heavy, is like if anything has unnormal iner time, also general vibration is present in the rear part. I have change also front bearings and the frontal hub units. We checked the dics everytime we changed and all of them has ovality around 5-7mm... All car is aligened, also tires balanced.Obviously the problem is not in the brakes..
castelao is offline   Reply With Quote
Old 07-12-2013, 08:57 AM   #15
WRX in WI
Member#: 304333
2009 WRX
Gunmetal
So did anyone ever get a resolution for this? I've got an issue just like it. the tires have been rotated - rebalanced with the issue still being the same also new calipers were installed along with my last set of rotors and pads. Wondering if anyone had any futher troubleshooting I could do before sucking it up and taking it to a shop
WRX in WI is offline   Reply With Quote
Old 07-12-2013, 05:08 PM   #16
ryansx
Member#: 324527
2013 wrx
white
Did you have them match mounted(or road forced checked whichever you want to call it) like it says in post #2(I know this thread is 3 years old)
ryansx is offline   Reply With Quote
Old 07-14-2013, 04:05 PM   #17
2003wrx64
Member#: 171615
this type of vibration is a common issue with aftermarket wheels that have a larger center hub bore than than the factory hub. if using an aftermarket wheel, make sure that it comes with an adapter that properly centers the wheel on the hub or even better has the correct bore to start with.
2003wrx64 is offline   Reply With Quote
Old 01-12-2016, 07:55 PM   #18
javi_evm
Member#: 437995
2002 Impreza WRX
Exclamation Reviving from the death
Alright, I know this is old but I can't post anything because I'm a noob to this site. I don't see anybody getting this exact problem so I figured I ask on this post. I have a 2002 WRX Wagon, after a week after I got it I started noticing this rattle sound coming from the front passenger side wheel, I also felt it on the steering wheel, didn't really bothered at the time, the wagon came with a set of coilovers that were shot, I replaced them with a normal set up of struts and springs that were pretty much new. After I installed them, I went for a ride to test them and it felt amazing compared to the stiff bouncy mess I had before, once i got up to about 40 mph the car started rattling, vibrating bad and I'm guessing there had to be some wobbling going on from the same wheel I was hearing and feeling things before I installed the new suspension.
I've checked wheel bearing and tie rods and both seem fine, rotates smoothly, I shook the tire and all. I've checked control arm ball joint and it seems and feels fine. I checked the axle and it also looks, feels and rotates just fine. I took some video under the car while driving and I see the wheel wobbling a lot but don't see anything out of the ordinary. The only other thing I've done is installed a set of rotors and pads but that was way before I did the suspension and I was already hearing and feeling the sound/vibration before doing the rotors and pads.
I should note that it is not a constant thing, it only happens when I turn the wheel to the right slightly and then it goes away when I turn the wheel even more. It doesnt do it when Im going straight. Only when I'm on that "sweet spot".
Im going crazy here and I need yeezus.:co nfused:
javi_evm is offline   Reply With Quote
Old 01-12-2016, 09:35 PM   #19
16Rex
Member#: 435405
2016 WRX Limited
Sure hope you get this fixed so you can stop resurrecting 2 year old threads.
16Rex is offline   Reply With Quote
Old 01-13-2016, 10:42 AM   #20
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
I believe the 5th one by now.
kenliu84 is offline   Reply With Quote
Front end vibration djobson101 Newbies & FAQs 23 03-05-2010 11:28 PM
Front end vibration while braking..bearings? donkey_cart Service & Maintenance 5 06-25-2007 07:37 PM
Brake pulsation/front end vibration only after hard braking...what to do? The Modaholic Brakes, Steering & Suspension 24 11-30-2004 02:14 PM
Help! Persistant Steering Wheel anf Front End Vibration jasonb Brakes, Steering & Suspension 3 11-05-2002 04:40 PM
('93-'01) Front end shudders! HELP! Texas25RS Impreza Forum 5 05-06-2001 11:23 PM
