Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 07-11-2013, 10:54 PM   #1
5050
Member#: 252122
2007 Sti
OPB
Default Installing Sparco Hub & Wheel on 2007 Sti
Bought a Sparco Hub and Wheel for my car and long story short. When I went to install it everything was fine till I put the hub up to the steering column. I'll post pictures below. But there's a black plate that turns and has to rubber prongs sticking out towards the driver. Does this stay? Or does thus also have to be removed. The hub will neither fit around the rubberish prongs or will it allow the cords to fit through the back that are attached to this black spinning plate.
Any advice would be much appreciated or If there is a write of some sort that I didn't find, sharing it would be much appreciated. Thanks in advance guys!
Here's the "black plate" that spins with the stock wheel.
Back side of hub.
5050 is offline   Reply With Quote
Old 07-11-2013, 11:00 PM   #2
5050
Member#: 252122
2007 Sti
OPB
I guess the main question is, do I remove the clock spring (if that's what it's called) when installing the hub & wheel?
Old 07-11-2013, 11:49 PM   #3
ryansx
Member#: 324527
2013 wrx
white
Looks like you have too. It is of no use anyways now that your using aftermarket steering wheel. Air bag light is going to be on now too if you didn't know. And the clock spring is broken if you have spun it one way or another to many times.
ryansx is offline   Reply With Quote
Old 07-12-2013, 01:55 AM   #4
5050
Member#: 252122
2007 Sti
OPB
I actually put it back together and everything works fine! I'll try again tomorrow and remove the clock spring too see if that helps out! Thanks for you help man!
Old 07-12-2013, 07:27 AM   #5
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
The second half of the steering roll connector is the problem area for 06' STI owners, and I am pretty sure this applies to '07s too. The "Steering Position Sensor" is screwed together with the clock spring, so you can't remove the clock spring. This is actually part of the DCCD circuit and feeds steering inputs to the Yaw Rate & Lateral G sensor in the DCCD control module. Removing this leaves your DCCD stuck in full open and your driver controls are lost.
See this thread: http://www.iwsti.com/forums/gd-inter...l-outcome.html
mav1c is online now   Reply With Quote
Old 07-12-2013, 08:00 AM   #6
ryansx
Member#: 324527
2013 wrx
white
Originally Posted by mav1c View Post
The second half of the steering roll connector is the problem area for 06' STI owners, and I am pretty sure this applies to '07s too. The "Steering Position Sensor" is screwed together with the clock spring, so you can't remove the clock spring. This is actually part of the DCCD circuit and feeds steering inputs to the Yaw Rate & Lateral G sensor in the DCCD control module. Removing this leaves your DCCD stuck in full open and your driver controls are lost.[/url]
Interesting. Haven't seen any other veh with the steering position sensor attached to clock spring, in fact I have only seen them either built into column and at base of column, but I also haven't had to do one a Subaru before. But if this is true then that would be a problem removing it
Old 07-12-2013, 10:41 AM   #7
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Yeah. If you want to keep the DCCD functional, you HAVE to keep the clock spring/sensor. You can't use the Sparco Hub. I had the same problem (I had an NRG hub that didn't work) and ended up with a Works Bell hub that works. Splash is another brand that works, but I think it's just a re-branded Works Bell, or vice versa.
This is what I have. You can see the holes for the sensor:
Old 07-12-2013, 11:18 AM   #8
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
FYI...there are a couple on eBay:
http://www.ebay.com/itm/Works-Bell-S...9020fb&vxp=mtr
http://www.ebay.com/itm/WORKS-BELL-I...6080e2&vxp=mtr
OR just search the interwebs for "Works Bell 116S"
Old 07-12-2013, 12:33 PM   #9
5050
Member#: 252122
2007 Sti
OPB
Thanks for your help man! I'm gonna order one of those hubs to just stay away from messing with too much of the clock spring.
Old 07-13-2013, 01:02 AM   #10
5050
Member#: 252122
2007 Sti
OPB
Just an update. Got everything installed. I removed the clock spring the DCCD still works fine and everything fit right up!
Old 07-14-2013, 02:15 AM   #11
ryansx
Member#: 324527
2013 wrx
white
Nice, no air bag light either?? If not that's surprising.
