Brakes & Suspension Forum sponsored by The Tire Rack |
03-04-2013, 10:57 AM | #476 | |
Member#: 20952
MAIC
Vehicle:BRZ & Datsun White & White |
They will fit. 93-01 is identical for WRX and RS except for front swaybar.
03-10-2013, 10:52 PM | #477 |
Member#: 319679
NWIC
Vehicle:2002 Wrx Sedan Silver |
Anyone know if 04 sti usdm pinks will fit a 2000 outback sport? Just 04-07 tophats needed? Scoobyspacer? Any input greatly appreciated
03-11-2013, 01:06 AM | #478 |
Member#: 27136
Don't the pinks lift the GC chassis a bit?
They should work though. It's really hard to find pictures, I had the same question myself. :-* |
03-12-2013, 03:05 PM | #479 |
Member#: 276823
TXIC
Vehicle:2010 WRX |
do these HKS coils fit on a 2010 wrx?
http://www.amazon.com/HKS-80140-AF007-Hipermax-Coilover-Suspension/dp/B001N21HJM i found the link below that says 08-09 but 2010 should work fine too right? Looks like there was not a sport version for the wrx in the GE/GH family. thoughts? http://www.hks-power.co.jp/usa/products/Pid=3436.html 80140-AF007 SUBARU Impreza WRX 2008-2009 there are 2010 listings on there for the sti only though Last edited by Hextro; 03-12-2013 at 03:11 PM. |
03-12-2013, 04:06 PM | #480 | |
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
03-12-2013, 04:08 PM | #481 |
Member#: 276823
TXIC
Vehicle:2010 WRX |
i question it because that's amazon saying that and not the HKS site. Amazon sells a lot of everything so they might not be as dialed in as needed.
thanks, |
03-12-2013, 04:17 PM | #482 |
Member#: 268328
BAIC
The only difference between the 08-10 and 11+ wrx's (in terms of suspension) is the spring rates as well as the slightly wider track width with the 11+'s. Did you try contacting hks to triple check?
03-12-2013, 04:27 PM | #483 |
Member#: 20952
MAIC
08-10 coilovers and shocks for WRX are interchangeable. STI fronts are different.
11+ has the widebody so they aren't exactly the same, but they fit. Putting 08-10 style shocks/coilovers on an 11 will get you a bunch more negative camber (which can be a good thing). Going the other direction you end up with a lot less negative camber. FWIW you can do better than that for that much cash. - drew |
03-12-2013, 04:33 PM | #484 |
Member#: 276823
TXIC
Vehicle:2010 WRX |
AndyRoo - totally agree, but I might get some lightly used for < $1k and that would be worth it IMO.
I'm also thinking about just doing the koni setup so i don't mess with the setup all the time (which i bet i would be with track day visits etc..). i almost need the cup kit install and forget it setup |
03-12-2013, 04:39 PM | #485 |
Member#: 20952
MAIC
Gotcha, not a bad deal if they're in good condition. A new Koni + RCE set-up from TIC might be around that price new though. Haven't looked in a while.
- drew |
03-12-2013, 05:48 PM | #486 | |
Member#: 268328
BAIC
03-13-2013, 01:58 AM | #487 |
Member#: 324849
NESIC
Vehicle:2005 STI PSM |
Curious with the issues of a front 02-07 wrx swaybar on a 05 STI? Nothing is mentioned specifically
04-05-2013, 08:26 AM | #488 |
Member#: 311952
MAIC
Vehicle:2005 Subaru WRX Crystal Grey Metallic |
So if I read correctly. 04-07 sti struts, springs, and top hats should fit onto a 05 wrx? Or only 05-07 sti struts, springs, top hats will fit 05-07 wrx's? Am I correct? Looking to upgrade my suspension with sti struts springs and top hats
04-05-2013, 08:51 AM | #489 |
Member#: 72891
MAIC
Vehicle:2018 STI 99 2.5RS 2dr - 2017 XV |
No, 04 STi struts and springs will fit 02-07 WRX. 05-07 STi rears will fit but fronts will not.
04-05-2013, 09:15 AM | #490 |
Member#: 311952
MAIC
04-24-2013, 05:36 PM | #491 |
Member#: 188956
MWSOC
Vehicle:2006 Impreza Wagon Silver |
The "Will it fit?" portion for the MY range that covers my 2006 states that 05+ STI suspension bits will not fit on my car. That said, the post was written in 2007.
I'd just like to confirm that this trend did in fact hold true since the original posting date. The question at hand is, if I swapped struts, springs, and top hats from an 08 STi to my '06 2.5i wagon, would there be any issues? Thanks! |
04-24-2013, 05:38 PM | #492 |
Member#: 20952
MAIC
08+ anything will not fit 02-07 anything.
04-24-2013, 05:40 PM | #493 |
Member#: 20952
MAIC
and yes it should be edited to be more clear.
04-25-2013, 10:46 AM | #494 |
Member#: 188956
MWSOC
Awesome - thanks!
07-15-2013, 03:43 AM | #495 |
Member#: 354456
South East
will 02 wrx struts fit an 07 wrx?
08-15-2013, 06:56 PM | #496 |
Member#: 360076
RMIC
Vehicle:2004 WRX Wagon |
Will 06 wrx sway bars fit my 05 FXT?
08-16-2013, 07:59 AM | #497 |
Member#: 219717
South East
Vehicle:05 FXT Dom2.5R 4EAT FTW!!!! |
08-16-2013, 08:01 AM | #498 |
Member#: 219717
South East
08-16-2013, 12:00 PM | #499 |
Member#: 248892
MAIC
Vehicle:2006 WRX Wagon CGM |
08-16-2013, 12:02 PM | #500 |
Member#: 118141
Vehicle:95 'lifted' legacy |
Nice thread Race Comp Engineering!!
Here's a little something I just discovered. I was able to straight swap the factory 15mm RSB from my 95 legacy into my wife's 03 OBS. I'd removed the SB from the lagacy to up-size it to a gen 1 OB's 18mm RSB. So it follows that the 13mm RSB from an 02-03 OBS (I assume 00-07 impreza bodies?) can ultimately be replaced a gen 1 OB's (96-99) 18mm RSB. These are more abundant and possibly cheaper than WRX 20mm bars, so a great and easy improvement if not THE best possible improvement. I noticed you have specific info regarding sti part fitment etc. and those specifics are out of my experience (I'm an off-road guy with a lifted BD), but I did find something which could be of use regarding RSB on my wife's 03 OBS. Ciao! |
Similar Threads | ||||
Another "Vote for my ___ " Thread. This time, my badass dog. | Sharkbait | Off-Topic | 56 | 10-14-2009 11:46 AM |
The parting out my car feeler thread | vision.dynamix | NESIC Private Classifieds | 51 | 04-25-2009 06:00 AM |
The official "Will this part fit my car?" thread | Butt Dyno | Brakes, Steering & Suspension | 20 | 07-12-2007 06:41 AM |
The Official "Will you print my car?" thread | MeanEditor | Grassroots Motorsports Magazine Forum | 0 | 02-11-2007 10:25 PM |
