Old 05-22-2013, 09:32 PM   #626
pauvil
Member#: 357215
2003 WRX Impreza
Sorry, also my EGT gauge, at what temp should I start to get worried? and what kind of knock sensor system do these motors use?
pauvil is offline   Reply With Quote
Old 05-22-2013, 10:50 PM   #627
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
Wow...I know you are new and all, but did you seriously think that the Turbo list thread was the best place to ask your questions?
Old 05-23-2013, 07:18 AM   #628
subieguy87
Member#: 153412
1998 Impreza wrxRS
Agreed.
Originally Posted by pauvil View Post
Newbie, 2003, just wondering, my boost gauge is on it's way and I want to get started with mods. What is the stock motor putting out in boost psi?
Look in the factory 2.0 forum
subieguy87 is offline   Reply With Quote
Old 07-03-2013, 09:41 PM   #629
CoopersXT
Member#: 361260
2007 Subaru Impreza
Default Thanks for info I'm new member working on second subie
In process of trying to find and replace my turbo on my 05 forester xt that I killed months after getting the car. Thanks again very informative
CoopersXT is offline   Reply With Quote
Old 07-13-2013, 02:10 AM   #630
Bmize89
Member#: 360896
2006 WRX
Vf22 best all around turbo
Bmize89 is offline   Reply With Quote
Old 07-14-2013, 05:03 PM   #631
rexblake
Member#: 178426
2010 S4
Gray
I sincerely hope your kidding.
Old 07-14-2013, 08:59 PM   #632
sti0087
Member#: 350373
2011 STI
Grey
Hahahaha
sti0087 is offline   Reply With Quote
Old 07-15-2013, 08:09 PM   #633
northwesterner
Member#: 362431
Default Sweet.
Thanks.
northwesterner is offline   Reply With Quote
Old 09-01-2013, 12:04 PM   #634
sa-motorsports
Member#: 364228
2006 impreza
red
Default Turbos and other cool stuff
Hi guys,nice list of turbo's.I am currently testing efr Borg Warner turbos.They have made all other turbo's obsolete unless you are just upgrading from the factory turbo.The efr needs a custom twin scroll equal length header but it has almost zero back pressure while under boost it flows so well,this is exhaust turbine to compressor wheel pressure ratio. allowing the use of a more radical cam as the twin scroll reduces reversion.Reversion is more prevalent on non-twin scroll turbos forcing the camshafts or shaft to have a wider lobe separation and in short less overlap.Too much boost and your air speed goes over 500 ft per second closing in on sonic stall,this has been confirmed on the flow bench ,that`s where the mixture in the runners and chamber slow down and efficiency decreases.some things to look at that I am currently studying before I build my 2.2 turbo motor for my impreza.just putting it out there,research research research,all I can say,as far as my credentials go,licensed auto tech since 1989,road racer since 1996,shop owner since 1993,and I am still going to school everyday!
fullrace.com has a tremendous write up on the efr turbo
squish band
short turn velocity
port flow efficiency
146 cfm per square inch
sa-motorsports is offline   Reply With Quote
Old 09-21-2013, 02:50 AM   #635
mike5845
Member#: 368915
Nice write up berry informative
mike5845 is offline   Reply With Quote
Old 10-04-2013, 02:23 AM   #636
Runker
Member#: 370047
03 Evo 8
Very good info.
Runker is offline   Reply With Quote
Old 10-05-2013, 02:36 AM   #637
wh00sher
Member#: 370117
Very useful thread. Many thanks to the OP for taking the time to put it together
wh00sher is offline   Reply With Quote
Old 10-17-2013, 10:16 AM   #638
RevedOut
Member#: 370559
Default Help...Turbo Identification
I need some help identifying this turbo. I was on the WRX motor that I swapped into my 2002. The markings on the compressor are 5679. I have the oem one on now and have no use for this one. I need to identify it then put it up for sale. Any help would be great.
https://plus.google.com/photos/11664...LGDkZav79Of7AE
RevedOut is offline   Reply With Quote
Old 10-25-2013, 12:37 PM   #639
CptTripps
Member#: 371033
Awesome thread. I've been referencing it 2X a day researching what turbo I want to use. Thanks!
CptTripps is offline   Reply With Quote
Old 10-25-2013, 02:34 PM   #640
street carp
Member#: 216768
2016 STI
HYPER BLUE
definitely wouldnt mind going rotated with an EFR turbo. they're almost too good to be true. quick spool with lots of top end. its everybody's dream. too bad it costs the big bucks...
street carp is offline   Reply With Quote
Old 10-28-2013, 01:30 PM   #641
Anthony3991
Member#: 371293
Default Wish
wish I could afford a turbo for my car right now.
Anthony3991 is offline   Reply With Quote
Old 10-31-2013, 02:03 PM   #642
n5bennett
Member#: 278940
Default turbo question
my buddy is giving me his TD05-H from his wrx...will this fit on my 05 legacy gt ?
n5bennett is offline   Reply With Quote
Old 10-31-2013, 02:16 PM   #643
acumenhokie
Member#: 271479
2010 LGT
2009 FXT
He's giving you the hot side only and you want to mate that to the stock compressor?
acumenhokie is offline   Reply With Quote
Old 10-31-2013, 02:20 PM   #644
n5bennett
Member#: 278940
well i just blew the stock turbo... so i just want to know if this one will fit
Old 11-01-2013, 01:24 AM   #645
superacerc
Member#: 317679
2009 2.5XT/20G
Metallic Black
Depends on the compressor side configuration where it meets the intercooler. The legacy went to a flanged compressor that bolts to the intercooler around your year. If your turbo you blew is a vf40 then it probably won't work. The pre 08 wrx turbos are meant to have a hose to intercooler connection and not a bolted flange. If that td05 h is from an 08+ wrx it might fit but stock the 08+wrx was a vf52.
superacerc is offline   Reply With Quote
Old 11-02-2013, 11:08 AM   #646
Mike_STI
Member#: 369642
very good write up. did you think of adding AMRs Turbos? or did I just miss them?
Mike_STI is offline   Reply With Quote
Old 11-05-2013, 10:22 PM   #647
Patrikman
Member#: 234499
2004 Outbrat XT
Regatta Red/Silverstone
Any updates? Can we get some more info on the Legacy models too?
Patrikman is offline   Reply With Quote
Old 11-06-2013, 12:11 AM   #648
drogos
Member#: 245483
2008 Legacy Spec B
specifying which wrx would get you your answer by now. 08+ wrx will fit but you don't want 08 WRX since it's smaller than your Turbo. 09+ are bigger with **** load of torque down low, either way you have to tune.
you meant stock 09+
drogos is offline   Reply With Quote
Old 11-06-2013, 12:58 AM   #649
superacerc
Member#: 317679
2009 2.5XT/20G
Metallic Black
Originally Posted by drogos View Post
you meant stock 09+
Yep, forgot the 08 was still td04 but modified.
Old 11-06-2013, 12:44 PM   #650
bassman5066
Member#: 335282
Question
I noticed your list doesn't cover any of subaru's OEM turbos, and I would like more info on them.
http://www.turbomaster.info/eng/appl.../subaru/TODOS/
The turbo in question is found on the 2012 Forrester and Legacy, as shown in the above link. The model number listed is MGT2259S.
I would like to know the following:
Both for turbine and compressor:
A/R
Inducer size
Exducer size
Inlet and outlet sizes
Turbine inlet/outlet flange types
If anyone can point me to where to find this info, or if you have one you can measure that would be great. I've tried Garrett's references to the GT2259 but I'm trying to figure out the differences between their aftermarket catalog turbo and this Subaru OEM "M" variant of the 2259.
The reason for my question is I have been told the Subaru version of the 2259 has a larger compressor measurement and also has a twin scroll style turbine. Any help is appreciated. Thanks.
bassman5066 is offline   Reply With Quote
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever pepperjack News & Rumors 74 07-14-2015 07:07 AM
is there a Subaru turbo list? housedj General Community 8 03-18-2009 12:48 PM
subaru forum list 949 General Community 10 11-01-2005 11:32 PM
Subaru wish list carrera News & Rumors 9 06-19-2002 08:45 PM
('93-'01) Subaru Mailing List rubadub Impreza Forum 3 08-18-2001 02:40 PM
