Old 01-14-2012, 04:32 PM   #1
bc3forsd
Member#: 196868
2006 wrx
Default AVCS Solenoid!!!!!!!!!!!!!
so i have a quick question!!! is the AVCS solenoid supposed to come apart?
bc3forsd is offline   Reply With Quote
Old 01-16-2012, 10:31 PM   #2
Blowby
Member#: 122684
2006 WRB WRX w/ VF39
molested by a drunkmann
I am just now trying to figure this out myself.....my "left side" solenoid is messing up on me, I think. I have been throwing a CEL and my tuner found that the left side is not running up to speed like the right side is, if only I knew what was considered left (viewing from front of car or back of car).
I think I will be pulling mine apart to clean them just to see if that will fix the problem.
Blowby is offline   Reply With Quote
Old 01-17-2012, 12:57 AM   #3
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
sitting in the front seat right is right left is left.
Old 01-17-2012, 01:07 AM   #4
jetski247
Member#: 188171
04 sti baby
wrb
which side is bank 1 and which side is bank 2?
i thought that right and left are when you are looking at the engine standing in front of the car??
right side left side? bank 1 bank 2? i couldn't find anything in the manual about which side is which?
jetski247 is offline   Reply With Quote
Old 01-18-2012, 12:21 AM   #5
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Bank 1 is right side when sitting in front seat.
Old 01-18-2012, 08:59 AM   #6
jetski247
Member#: 188171
04 sti baby
wrb
thanks mod, my driver side keeps throwing a 0021 code and it will idle really rough sometimes. i've swapped out avcs solenoids but it is still there.
as far as taking it apart, i'll have to look at it since i have two of them sitting out from my old engine and i'll let you know what i find, i would think they can be taken apart. in my other post, someone mentioned to hook a 9v battery up to it to see if it opens up to test it, id try that and see what it does, it should show if its getting stuck or not opening.
Old 01-19-2012, 10:28 AM   #7
bc3forsd
Member#: 196868
2006 wrx
I had asked that because while pulling the solenoid from the motor.. the electrical part separated from the actuating part (if that makes any sense) non the less I found and purchased a new one just in case.. and after a flush and an oil change 200+ miles I haven't thrown the p0021 code yet...
(Crossing fingers and knocking on wood that I didn't just jinx myself)
Old 01-19-2012, 11:39 PM   #8
jetski247
Member#: 188171
04 sti baby
wrb
thats good to hear, glad you got rid of yours. i'm going to switch to a heavier weight oil and see what happens since mine only does it at idle and i have a tad bit looser bearing clearances.........
Old 07-02-2013, 09:27 PM   #9
SienerSubie
Member#: 353507
2004 WRB WRX STi
Hey guys just having a P0021 code and its causing things to get worse... How do you remove the AVCS solenoid I took out all the bolts and it wouldn't come out I took out both on the side and the one on top it wouldn't move how do I clean it out
SienerSubie is offline   Reply With Quote
Old 07-03-2013, 03:57 PM   #10
Masta Splint
Member#: 189211
2005 18g WRX wagon
Every single car out there and all the parts go by if you were sitting in the drivers seat. So for USDM cars (left hand drive) driver is always left and passanger is always right.
Masta Splint is offline   Reply With Quote
Old 07-15-2013, 08:37 PM   #11
northwesterner
Member#: 362431
Default P0011 code Subaru WRX 2008 stock
I have received this code several times now and the mechanics are stumped.
The car drives beautifully, no detrimental effects to the turbo or performance otherwise. Most recently, the check engine light came on 120 miles after having work done and the code reset. I was getting on the freeway in 5th gear and let the RPMs slip below 2,000 when the light came on. The vehicle occasionally will send minor vibrations while at a stop, but it's not alarming.
My WRX is an '08 with 72,000 miles and no modifications. Prior to the check engine light coming on, the timing belt was replaced and oil changed regularly. Since the P0011 code, I've had both camshaft position sensors (solenoids) replaced (banks 1 and 2), as well as the oil changed again.
Please advise as to what direction I should go in. Is it just a timing issue that can be resolved with the high quality tools of a dealership, or am I looking at serious maladies. Thanks!
northwesterner is offline   Reply With Quote
Old 07-27-2013, 08:13 AM   #12
MSR
Member#: 20842
05 Spec C Type RA
The issue is the avcs gears, log the AVCS timing below 2k, see they float around off targets, gears seals inside are leaking to the wrong side, solenoids keep chasing targets, need to replace the avcs gears and also solenoids burnout chasing it.
MSR is offline   Reply With Quote
JDM AVCS solenoid vs. USDM AVCS solenoid coolcougar Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 39 11-08-2012 08:02 AM
JDM AVCS Solenoid... is the USDM STI one compatible? InfamousDX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-23-2007 06:33 PM
WTB AVCS solenoids and set of cam sensors k_thaosta Private 'Wanted' Classifieds 9 10-09-2006 01:27 PM
URGENT: attn: JDM vendors: JDM AVCS solenoid *pic* InfamousDX Private 'Wanted' Classifieds 3 09-21-2006 05:12 PM
2005 2.5ltr STI AVCS Solenoid HELP grilled Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 07-01-2006 09:19 AM
