Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 07-10-2013, 09:31 PM   #1
BeardedShogun
Member#: 354456
Default stock 07 wrx, cylindar misfire, hesitation at wot
Would love some help for this situation, can't seem to figure out what's the problem.
my WRX is bone stock, no performance mods yet at all.
some problems I'm seeing is:
hesitation at WOT, will hold at 4-5k, take off, and hold again.
a possible overboost
CEL flashing, cylinder 3 misfire.
Running only 93 octane and have used fuel cleaner regularly to try to eliminate an injector problem.
what could it be?
BeardedShogun is offline   Reply With Quote
Old 07-11-2013, 08:39 AM   #2
Dr. octagon
Member#: 171127
GDA Cyborg T4
Not waving back
what could it be?
Seems as though its misfiring, seems you have identified the missing cylinder. Search misfire, and stop using that fuel injector ****. If the injectors are dirty, pull them and send them off to get cleaned.
Old 07-15-2013, 09:46 PM   #3
diablo0730
Member#: 362438
Clean the MAF i had the same problem and MAF was dirty as heck.
diablo0730 is offline   Reply With Quote
Old 07-17-2013, 12:53 AM   #4
BeardedShogun
Member#: 354456
did that
probably going to buy a new one.
Cleaned the boost solenoid as well, no change.
Old 07-18-2013, 01:47 AM   #5
Mukeworx
Member#: 361994
2005 STI
I'm having the same issue... Did compression test, leak down, all good, new plugs and coilpacks still cylinder 4 misfire....
Clogged injector??
Mukeworx is offline   Reply With Quote
Old 07-18-2013, 09:34 AM   #6
kungfuturkey
Member#: 286925
2006 Impreza WRX
This could be the starting signs of a coil going out... My car did this when I first bought it if I was on the hwy for a long period of time always the same cylinder. A year later the coil went out all the way...
kungfuturkey is offline   Reply With Quote
Old 07-18-2013, 12:23 PM   #7
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Said coilpacks were new.
SlimJim8804 is offline   Reply With Quote
Old 07-19-2013, 01:45 AM   #8
street carp
Member#: 216768
2004 STI
Check all the vacuum lines. Better yet, get a smoke test done at the shop. A vacuum leak could cause a misfire.
street carp is offline   Reply With Quote
Old 07-19-2013, 02:15 AM   #9
BURNING4ORCE
Member#: 356215
From my experience if it's a injector problem, not always, the engine idles really rough. Try swapping out coil packs to the next cylinder see if the misfire follows the cylinder it was swapped too. Since it's the 3rd cylinder( top passenger side) swap below the 1st which is located in the bottom towards the radiator. Change plugs too if that hasn't already been done. It could be numerous thing, vacuum leak, o-ring from injectors, wiring, fuel rail lifting up only at wot at certain boost pressure, best thing to do is to get a smoke test done like someone already mentioned and if that passes a cylinder leak test to see if that cylinder or motor is healthy. If you have someone with a tactrix cable locally you even log your car to see where it's at and maybe see if it has a leak or not.
BURNING4ORCE is offline   Reply With Quote
Old 07-19-2013, 06:03 AM   #10
BeardedShogun
Member#: 354456
Thanks for the suggestions, I replaced the plugs and my cylinder misfire cel went away.
However my other problem still occurs. hesitation and bucking at wot, car gets to about 5k (sluggishly) and just hits a wall.
I'm definitely going to take some suggestions from here, but could this be a possible overboosting problem?
Old 07-19-2013, 06:17 AM   #11
BURNING4ORCE
Member#: 356215
Do you have a boost gauge? It could be overboosting as it seems like your hitting fuel cut, have you thrown any codes for overboosting like p0244 or so? Run wastegate boost pressure by connecting just 1 single hose to the wastegate nipple and to the turbo compressor nipple where your turbo is and do a wot pull again if hesitation is still there then we can rule that out to some extent. Quit doing those wot pulls for the meantime to avoid any possible catastrophic failure. Check for leaking/cracked boost lines or loose lines on the turbo hoses as well.
Old 07-19-2013, 03:20 PM   #12
BeardedShogun
Member#: 354456
No, haven't thrown any turbo specific codes, closest would be a "system too lean" code that went away shortly.
All the lines look good to me, I'm about to just bite the bullet and take it to a mechanic.
Old 07-20-2013, 04:48 AM   #13
kungfuturkey
Member#: 286925
2006 Impreza WRX
Sorry I missed that. Have you checked fuel pressure? Your fuel pump could be on it's way out it takes a while some times and can be pretty subtle.
