Old 07-16-2013, 12:40 AM   #1
fuji_production
Member#: 224407
2005 Impreza WRX STI
Default please help with my rotated manifold setup
Before anyone ****s all over the floor; yes, I did look at this thread http://forums.nasioc.com/forums/showthread.php?t=807772 . I bought 8mm spacers and flipped the IM around. the TB still will not clear the alternator. so I yanked out my ac and now that I reference that thread I see that there are no dog gone pictures so I have no idea what the hell to do with this ac bracket...someone please point me in the right direction. All I need to do is figure out how to flip this damn thing then its off to the welder for piping...
fuji_production is offline   Reply With Quote
Old 07-16-2013, 02:18 AM   #2
Andrewxxcarlson
Member#: 316415
2006 WRX
Have you tried getting more clearance between the TB and alternator by rotating the TB, so the throttle actuator isn't facing down.
Old 07-16-2013, 10:51 AM   #3
fuji_production
Member#: 224407
yes, it seems as though it doesn't matter which way I rotate it the alt. is still too high...
Old 07-16-2013, 11:01 AM   #4
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
What about puting a shorter alternator belt on so the alternator sits lower.
With the alt where the AC was shouldn't be an issue but like mentioned above u can try that
Old 07-16-2013, 07:03 PM   #5
fuji_production
Member#: 224407
how much shorter of a belt do I need over stock? and how do I lengthen the dbw and MAP sensor wires?
Old 07-16-2013, 07:42 PM   #6
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Put the alternator as low as it can go then wrap a string around both pulleys and measure to see what length of belt u will need. But check to make sure the alternator will clear the TB first or will be a waste of time.
As for wiring there is lots of methods of doing this just make sure u use automotive wiring and don't ghetto rig it lol.
Do some searching unless someone chimes in with the best way that will suit u.
Old 07-16-2013, 07:52 PM   #7
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
You sure as **** didnt read through that thread very well. You can put your ac back on if you like cool air. Your going to need a 34-34.5 inch belt. Make it fit. Make ic piping fit. Done.
Old 07-16-2013, 08:56 PM   #8
fuji_production
Member#: 224407
should I be able to unwrap the loop a little and wrap it back up? I need like 1 more inch to plug in these connectors. and your right scby, I didn't read through all 80 some pages. my bad...I read the first few posts and the last couple of pages and didn't find my answer...
Old 07-16-2013, 10:16 PM   #9
scby rex
Member#: 104878
02 wrxbastardchild
Read what the dbw people did. Mod the alternator, and terminal. Look how to slot he alt lower. Its all in the last 10-15 pages of that thread. If you want to do it and make it look good do a little research like he rest of us.
Old 07-16-2013, 10:43 PM   #10
fuji_production
Member#: 224407
aint nobody got time fo dat!
Old 07-16-2013, 11:02 PM   #11
fuji_production
Member#: 224407
thanks for the help though rex. preciate it...
Old 07-17-2013, 12:40 PM   #12
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
So what your saying is you didn't read it and you just want to be told what to do.
I ground my alt bracket down so I could get it as low as possible. Works good, last long time.
Old 10-07-2013, 01:03 AM   #13
fuji_production
Member#: 224407
figured it out myself. I pretty much didnt have to do jack **** but slap a 40in belt on it. rotate that Alt. post and lengthen the power wire. I already had 8mm phenolic spacers so im sure that helped. VERY east to rotate the IM
