Old 07-16-2013, 12:40 AM   #1
fuji_production
Member#: 224407
2005 Impreza WRX STI
CGM
Default please help with my rotated manifold setup
Before anyone ****s all over the floor; yes, I did look at this thread http://forums.nasioc.com/forums/showthread.php?t=807772 . I bought 8mm spacers and flipped the IM around. the TB still will not clear the alternator. so I yanked out my ac and now that I reference that thread I see that there are no dog gone pictures so I have no idea what the hell to do with this ac bracket...someone please point me in the right direction. All I need to do is figure out how to flip this damn thing then its off to the welder for piping...
fuji_production is offline   Reply With Quote
Old 07-16-2013, 02:18 AM   #2
Andrewxxcarlson
Member#: 316415
2006 WRX
Have you tried getting more clearance between the TB and alternator by rotating the TB, so the throttle actuator isn't facing down.
Andrewxxcarlson is offline   Reply With Quote
Old 07-16-2013, 10:51 AM   #3
fuji_production
Member#: 224407
CGM
yes, it seems as though it doesn't matter which way I rotate it the alt. is still too high...
Old 07-16-2013, 11:01 AM   #4
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
What about puting a shorter alternator belt on so the alternator sits lower.
With the alt where the AC was shouldn't be an issue but like mentioned above u can try that
trev762 is offline   Reply With Quote
Old 07-16-2013, 07:03 PM   #5
fuji_production
Member#: 224407
CGM
how much shorter of a belt do I need over stock? and how do I lengthen the dbw and MAP sensor wires?
Old 07-16-2013, 07:42 PM   #6
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Put the alternator as low as it can go then wrap a string around both pulleys and measure to see what length of belt u will need. But check to make sure the alternator will clear the TB first or will be a waste of time.
As for wiring there is lots of methods of doing this just make sure u use automotive wiring and don't ghetto rig it lol.
Do some searching unless someone chimes in with the best way that will suit u.
Old 07-16-2013, 07:52 PM   #7
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
You sure as **** didnt read through that thread very well. You can put your ac back on if you like cool air. Your going to need a 34-34.5 inch belt. Make it fit. Make ic piping fit. Done.
scby rex is offline   Reply With Quote
Old 07-16-2013, 08:56 PM   #8
fuji_production
Member#: 224407
CGM
should I be able to unwrap the loop a little and wrap it back up? I need like 1 more inch to plug in these connectors. and your right scby, I didn't read through all 80 some pages. my bad...I read the first few posts and the last couple of pages and didn't find my answer...
Old 07-16-2013, 10:16 PM   #9
scby rex
Member#: 104878
02 wrxbastardchild
Read what the dbw people did. Mod the alternator, and terminal. Look how to slot he alt lower. Its all in the last 10-15 pages of that thread. If you want to do it and make it look good do a little research like he rest of us.
Old 07-16-2013, 10:43 PM   #10
fuji_production
Member#: 224407
CGM
aint nobody got time fo dat!
Old 07-16-2013, 11:02 PM   #11
fuji_production
Member#: 224407
CGM
thanks for the help though rex. preciate it...
Old 07-17-2013, 12:40 PM   #12
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
So what your saying is you didn't read it and you just want to be told what to do.
I ground my alt bracket down so I could get it as low as possible. Works good, last long time.
Old 10-07-2013, 01:03 AM   #13
fuji_production
Member#: 224407
CGM
figured it out myself. I pretty much didnt have to do jack **** but slap a 40in belt on it. rotate that Alt. post and lengthen the power wire. I already had 8mm phenolic spacers so im sure that helped. VERY east to rotate the IM
