Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 07-14-2013, 08:23 PM   #1
mitsuevo10
Member#: 345475
Default ej25 sti hybrid with ej20 heads. help.
Im gonna build a 2.5 sti short block with ej20 heads and need to know what type of head gasket should i use and the thickness of it to match the sti compression. Thanks a lot.
mitsuevo10 is offline   Reply With Quote
Old 07-14-2013, 10:32 PM   #2
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
get a headgasket for the 2.5 sti
BONFIRE074 is offline   Reply With Quote
Old 07-14-2013, 10:41 PM   #3
mitsuevo10
Member#: 345475
Yeah but the stock sti headgasket is too thin and will be a bumpin the compression
Old 07-15-2013, 12:11 AM   #4
mitsuevo10
Member#: 345475
Any help pliss
Old 07-15-2013, 12:24 AM   #5
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
You need to get the combustion chambers done on the heads or get the right pistons. Those are the best ways to build a hybrid.
Old 07-15-2013, 07:40 PM   #6
mitsuevo10
Member#: 345475
What is the thickness of the stock sti head gasket
Old 07-16-2013, 01:52 PM   #7
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
Use OEM STI head gaskets and have the CC machined to the proper size. Having the head work done is not terribly expensive and is the best way to go.
naCAnItihS is offline   Reply With Quote
Old 07-16-2013, 02:10 PM   #8
RexWagonWA
Member#: 221945
Default Help
Yes, rebuild it right and only rebuild once. Maxwell (WA), EQ Tuning (CA), NF (MN), and ASF all modify heads toi fit the 2.5 ltr block. EQ Tuning and Maxwell did mine and I am very happy with the results.
RexWagonWA is offline   Reply With Quote
Old 07-17-2013, 10:19 AM   #9
ChronoX720
Member#: 184105
2015 WRB WRX Limited
Still Unamused
I used stock STi Headgaskets, as well as decked my 2.0 heads.
ChronoX720 is offline   Reply With Quote
