Old 07-16-2013, 02:49 PM   #1
jdp12
Member#: 343943
Default Legacy Rear shelf and pillar area noise/rattle
I have been hearing a popping/ticking noise coming from the passenger side, rear shelf/window area. Almost like tapping knuckles down the side of a television.
It occurs at lower speeds (>35), driving on uneven ground, turning corners/bends, as well as, going uphill/downhill or pulling in/out of driveways (mainly with bumps).
I brought it in to the dealer and they deemed it to be a loose clip that latches into the shelf (at least that is how I understood it). They repositioned the clip and it went away for a little while. Now, the noise is back.
I know this noise is coming from the rear shelf and/or pillars. I almost think that there is not enough stuffing under the shelf because I can push all the way down on it and it stick my finger under the plastic pillar covering.
Has anyone else had this issue and know of a fix? Or something along the lines that I could try?
jdp12 is offline   Reply With Quote
Old 07-16-2013, 05:09 PM   #2
Masta Splint
Member#: 189211
2005 18g WRX wagon
Go back to the dealer and tell them whatever they did didnt fix the issue and they will have to try and fix it again at no cost to you. If they cant fix it and it really bothers you email SOA and see if theres something they can do about it for you. I would first try the dealer again though.
Masta Splint is offline   Reply With Quote
Old 07-16-2013, 05:19 PM   #3
jdp12
Member#: 343943
I did bring it back. They said that they can't hear anything and can't fix it because of that reason. I asked them to just redo what they did because it worked for a short time,, but I don't think they know what they did. I've read all sorts of blogs that have had an issue in the same area.
Old 07-17-2013, 08:37 AM   #4
prescottn6ft7
Member#: 268918
2002 WRX Wagon
My 2004 STi was doing the same thing... I took out the rear seat, and the rear shelf cover and then went to Home Depot... I put this stiuff under everything http://www.homedepot.com/p/Frost-Kin...3#.UeaQZKJBnng Works like Dynomat... made my stereo system sound better, reduced road noise, and everything that was rattling is gone. Cost me $20, and 2 hours of labor in the drive way.
prescottn6ft7 is offline   Reply With Quote
