Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 07-03-2013, 07:26 PM   #101
lodown1
Member#: 200596
98 Forester 3.0R
So advantage of the hub conversion...well it allows me to use those wheels, which I have had for a few years I wasnt set on using them since i will need to do body work to make it look proper, but figured i might as well...those wheel are decent weight wise, I think last time I weighed them about 21-22 lbs.
Rear wiring was time consuming but not terrible difficult as long as you have good service manual diagrams and lists of all the wires. everything really was very similar... as for the legacy fuel pump issues, well the EDM ecu does not have provisions for any smog/ fuel evap systems. so all I didi was wire in a new walbro pump and delete the evap system. Also the early ez30r ecu run a standard return style fuel system...
Right now I am finishing up a Industrial design degree at the University of Kansas. Most of my time has been spent working on the FSAE race car engineering project. I have been doing brake systems, wheels, and sub-frame systems for the last 3 years... I should upload some of the photos of the cars we have built..
now for a little more update in my widebody centerlock wheel saga
floating front rotors, custom "hats", ap racing friction disks. Just waiting in the hardware
lodown1 is offline   Reply With Quote
Old 07-03-2013, 08:39 PM   #102
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Soooooooo hot.
Don't forget to safety wire the hat bolts / nuts.
Old 07-04-2013, 09:07 AM   #103
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Ah see the US 3.0R if I remember from the get go ran return less fuel system last time I looked at the tech files.
Weight on the wheels isn't bad, what are the other specs on them? Doing something about widening the body isn't bad thing either... That's what I'm doing on my OBS but I planned to do that from the start. I'm also pushing BEYOND the GDB suspension footing on top of that for a firmer track width though.
Seraphinwolf is offline   Reply With Quote
Old 07-05-2013, 12:13 PM   #104
lodown1
Member#: 200596
98 Forester 3.0R
The early US 3.0R had what i would call a semi return-less system.. 05-07 the fuel pressure regulator is not at the engine bolts to the left front strut tower here is a diagram of the piece...
Old 07-08-2013, 11:00 PM   #105
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Originally Posted by ballitch View Post
^^^ They do... IIRC, from 06 on the EJ25 has EL headers from the factory, and all them boys are switching to UEL to get the rumble lol.
Anyway, AMAZING work man. This kind of project takes a seriously dedi-f*cking-cated person to undertake. I don't even want to think of the stress level you must have at times..
~Josh~
He was talking about the exhaust ports in the head. You can build a better header if you take into account the length of the individual ports since they are not equal length.
geronimo81 is offline   Reply With Quote
Old 07-09-2013, 06:22 AM   #106
Seraphinwolf
Member#: 150922
97 OBS EZ30R
H6 is a whole different sound to begin with... Any of my H4's vs my SVX... SVX wins every time in sound!
Old 07-14-2013, 11:15 PM   #107
brandonk721
Member#: 275182
i have the same year forester and i got ksport coils that were on my 03 wrx, would they fit on the forester. im only asking cause i dont want to go through the trouble of trying to make them fit if they really arent going to. Did you have to get like the sti knuckle or something?
brandonk721 is offline   Reply With Quote
Old 07-15-2013, 08:01 AM   #108
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Forester figment is same as Imprezas of the same or about the same year. Front will bolt up, rears will bolt up at the knuckle, but the upper mounts will require new top hats or drilling new holes into the chassis.
Old 07-15-2013, 11:13 AM   #109
Racerjeff88
Member#: 347439
So ..... To fit a set of KSport Coilovers from a 03 WRX new top hats specific to the 1999 Forester (SF) need to be fitted to Coilovers?
However, 2002-07 Struts will bold right up?
Racerjeff88 is offline   Reply With Quote
Old 07-15-2013, 04:31 PM   #110
brandonk721
Member#: 275182
you saying that i have to get 98 - 00 impreza struts?
or that my front coils off my 03 wrx will fit on my forester
my bad for the stupid questions
Old 07-15-2013, 08:24 PM   #111
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Guys - Go to the Suspension, Brakes & Steering forum. You will find your answers.
Old 07-15-2013, 11:50 PM   #112
Hondaslayer
Member#: 4562
1995 Legacy LSi
02 and up Impreza suspension will bolt right in. Now, take it to the proper forum and don't litter this thread anymore.
Old 07-16-2013, 12:54 AM   #113
LUMBERZACK
Member#: 340009
2007 STi
48W
too much awesome!!
LUMBERZACK is offline   Reply With Quote
Old 07-16-2013, 08:33 PM   #114
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
This is tickling me where bad ideas usually tickle me. This is awesome!
Bad Noodle is offline   Reply With Quote
Old 07-21-2013, 02:26 AM   #115
lodown1
Member#: 200596
98 Forester 3.0R
Default Front brake rotor assembly
Well, I finally got my floating rotor bobbins and hardware together. The bobbins are grade 5 titanium, rotors are 2024-t8 aluminum... all that is left for those before final assembly is a enp coating on the aluminum to increase the wear resistance, and something on the titanium to prevent galling... oh and weight is 12.8lb
Old 07-22-2013, 11:16 PM   #116
04trailsti
Member#: 179170
This is the first F1 inspired Subaru, and its a forester. AWESOME!
04trailsti is offline   Reply With Quote
Old 08-15-2013, 03:26 AM   #117
lodown1
Member#: 200596
98 Forester 3.0R
Default nearly finished...
Here are some update pics on the centerlock wheel fitment project...
Powdercoated satin black
Hubs are out of the bearings, should be done tomorrow with the machine work to convert them to a 5x130 spline drive system.
These are a little something extra I spent the last week making... custom carbon center caps
I will be spending some time this week figuring out the fender flares needed to cover these 10" wide 0 offset wheels with 275/35/18 tires. Hoping to have everything back driving in a week or so.
Old 08-15-2013, 08:36 PM   #118
slow03
Member#: 93625
2002 Outback H6
'12 Fiesta hatch
Wheels look great!
Get anywhere with the intake throttle bodies? I still want a set of those adapters...
slow03 is offline   Reply With Quote
Old 08-15-2013, 09:11 PM   #119
lodown1
Member#: 200596
98 Forester 3.0R
well i spent some time earlier this summer, working on making the throttle bodies drive by wire units...
I should be able to adapt the stock subaru DBW units to run one bank of throttles each, I have some designs that need a little attention for the runners and plenum... Its probably got another 6 months in the project so I could probably be convinced to sell you that first set
Old 08-15-2013, 10:17 PM   #120
slow03
Member#: 93625
2002 Outback H6
'12 Fiesta hatch
Sendme PM with how much you would like for the adapters, and I can see what I can scrape together.
Old 08-24-2013, 12:34 AM   #121
lodown1
Member#: 200596
98 Forester 3.0R
Nearly finished with the wheel/tire/ front brake upgrade
Those are the rear shots
And Fronts
These are 18x10 zero offset wheels with 275/35/18 tires
Old 08-24-2013, 02:01 AM   #122
D3F0
Member#: 265799
1988 Subaru RX TURBO
Jesus man you need to calm down haha again so gorgeous. I am getting my skills up with Solidworks and Camworks so one day I can start a manufacturer making custom conversions like this center lug sex thing you got going on here. Also dam nice my college has a Formula SAE team but we got shut down because one of the kids a few years ago was testing the cars through the streets of Boston. The stance on your forester is just plain scary...Make some Porsche looking flairs for it.
D3F0 is offline   Reply With Quote
Old 08-24-2013, 11:04 AM   #123
FROMxAxDIGG
Member#: 356652
2008 wrx
spark silver
And Fronts
Love that look. Keep it up... quite the looker you got there.
Also what rims are those? Are they bbs painted black with no center caps??Look sick on the fozzy.
FROMxAxDIGG is offline   Reply With Quote
Old 08-24-2013, 04:33 PM   #124
lodown1
Member#: 200596
98 Forester 3.0R
those wheels are ATS GT racing center lock wheels
http://www.ats-wheels.com/ats_wheels...id=132&lang=en
as for my center caps... they should be done soon, just need to put some good clearcoat over the carbon to prevent yellowing of the resign due to uv rays
Old 08-24-2013, 04:45 PM   #125
lodown1
Member#: 200596
98 Forester 3.0R
I did take some nice slows drives today, here it is without the flares
damn those small brembo brakes
Forester/STI suspension parts from SPT? JSR Brakes, Steering & Suspension 1 04-28-2006 09:08 AM
JDM Forester STi Suspension DanzBorin Forester Forum 9 08-09-2005 09:01 AM
JDM Forester STi Suspension DanzBorin Private 'For Sale' Classifieds 2 07-29-2005 11:04 AM
Forester STi suspension installed Peaty Forester Forum 6 06-06-2005 09:55 AM
03 RS to 98 Forester shifter linkage swap?? jonnysubby Transmission (AT/MT) & Driveline 2 04-17-2005 10:29 PM
