Closed Thread
Old 07-17-2013, 07:41 PM   #42526
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
Originally Posted by WRX USA View Post
"Radiator", huh?
Sure looks like Varis to me on that box.
I have something interesting arriving tomorrow...
hehehe... can't wait to see... you should PM me your mobile number
Originally Posted by Smurftastic View Post
Infek, you're an original owner, what's made you stick with the Bug?
honestly... it's the investment I've made into it over the years... Also because I enjoy the car more and more every year and when times are good the car is there and even when times are bad it's still there for me too... it doesn't complain or judge me either. I've always had a goal to take this car into classic status and plan to stick with it. I usually invest in things for the long term and rarely do I jump from one thing to another. this can be said for almost everything I do in life unless I feel the need to just pick up and go.. the car will take me to where I need to go
Originally Posted by dub c View Post
Ahh, didn't know you had a Varis.
From the side it looks similar to this add-on piece.
My sincerest apologies .
no worries... there are replicas of this setup on ebay as well that are very similar to my setup. I have honestly never seen the versions you have though... but they are carbon wrapped over fiberglass instead of full carbon. Longevity is the goal.
iNfEk is offline
Old 07-17-2013, 07:58 PM   #42527
projectQWKSLVR
Member#: 285270
03 WRX
I've searched all over, with mixed answers :-/
Maybe one of you old school guys has first hand knowledge of this.
I'm picking up a PnP'd Throttle Body. So, I've gotta swap all the sensors. IACV and MAP are a no brainer. The TPS has me a little confused.
I've read you have to "zero" it at closed throttle to .5v. Okay, non issue. Except, my TPS doesn't have slotted holes. Then I read the 16bit ecu doesn't care, just slap the sensor on.
Huh? Which is it? Any of you guys been here before?
I only ask in here, because it seems specific to the 16bit ecu.
projectQWKSLVR is offline
Old 07-17-2013, 08:04 PM   #42528
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
well it's drive by cable NOT wire. If I'm remembering right you don't do anything with the TPS and just slap the sensor on. The ECU determines all the particulars based on a few things.
iNfEk is offline
Old 07-17-2013, 08:09 PM   #42529
projectQWKSLVR
Member#: 285270
03 WRX
Right, which makes sense. Part that gets me is, the TGVs use the same sensor to determine position, and those do need to be preloaded.
That's why I'm confused.
Old 07-17-2013, 08:15 PM   #42530
Pencils
Member#: 152726
The 2003 pwrFAP
thing
http://img825.imageshack.us/img825/7...generators.jpg
saw this floating around a few weeks/month ago. my friend has them.
this is what i planned on buying to complete my diffuser to fill out my widebody.
Pencils is offline
Old 07-17-2013, 08:17 PM   #42531
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
exactly.... I believe the reason it needs to be loaded is because the TGVs don't use the full range that the sensor is capable of... where when it's a TPS you it uses the full range or most of it.
iNfEk is offline
Old 07-17-2013, 08:19 PM   #42532
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
right... like the varis one... the end pieces and the center are purchased separately. I can tell by the pictures of the center that they are made similarly though.
FYI: I DID need to cut on my driver side of the center section to fit my exhaust though... be prepared. I was trying to not cut but ended up needing to.
iNfEk is offline
Old 07-17-2013, 09:18 PM   #42533
abstracted
Member#: 155722
02 WRX
MBP
Summer mode:
Sorry for crappy iPhone pics
abstracted is offline
Old 07-17-2013, 09:20 PM   #42534
WRX USA
Member#: 11192
.. VF48'd Bugeye
Oddly enough, those wheels work really well with that wing
Let me know when you get tired of them...
WRX USA is online now
Old 07-17-2013, 09:31 PM   #42535
abstracted
Member#: 155722
02 WRX
MBP
Lol yep the roof vent helps the overall appearance too along with jdm sti grille which you can't see in the pics but I only rock these wheels/tires for a few months until it starts raining here in Oregon then they go back to storage... Will let you know if they ever come up for sale, actually it is a set of 5 for to have s202 spare
Old 07-17-2013, 09:38 PM   #42536
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
damn that's a nice find abstracted
iNfEk is offline
Old 07-17-2013, 09:51 PM   #42537
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
Do want s202 RAYS wheels :drool:
silverF4turbo is offline
Old 07-17-2013, 09:53 PM   #42538
07imprezRS
Member#: 164302
2011 STi Ltd Sedan
DGM & 02 WRB WRX
This lol
07imprezRS is offline
Old 07-17-2013, 09:58 PM   #42539
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Because tomorrow is Throwback Thursday... here is an old picture from two years ago!
Smurftastic is offline
Old 07-18-2013, 12:45 AM   #42540
Static806
Member#: 362111
Midnight Black Metallic
Wrong thread, but I do have retrofitted HID projectors on my bugeye. I just don't know what kit I'll be safe with running. I was thinking about running the Bi-Xenon kit but what other kits can I run for a decent price right now? Both my ballasts just went out and one high beam refuses to come on.
Static806 is offline
Old 07-18-2013, 01:02 AM   #42541
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Bi-xenon kit? There's a few. High/low and just low. The factory and JDM setup are separate for high and low beams how do you have it hooked up to the chassis harness and are you using an additional relay harness. Are you using the slim or regular style ballast?
Pictures help especially since this is the bugeye thread
iNfEk is offline
Old 07-18-2013, 02:05 AM   #42542
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
test fitting new race setup...
BeBop86 is offline
Old 07-18-2013, 02:36 AM   #42543
KGwrx
Member#: 268868
Dub C your bugeye is epic, do you have any new shots of it?
KGwrx is offline
Old 07-18-2013, 02:57 AM   #42544
Static806
Member#: 362111
I'll post some pics up during the daytime, it's pretty dark where I live.
Old 07-18-2013, 07:17 AM   #42545
AutoPrue
Member#: 115459
2002 WRX Sedan
Atomic Orange
Dude I think he got rid of it.
AutoPrue is offline
Old 07-18-2013, 10:13 AM   #42546
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Slikkity.. what are they. Cant read with my old eyes...
The Phenx is offline
Old 07-18-2013, 10:21 AM   #42547
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Oh and got the bug back today, new trans, clutch, shifter bushings, etc... Thanks again to Andrewtech. She drives like a demon bitch.
Old 07-18-2013, 10:35 AM   #42548
1breel
Member#: 189314
2002 GGSTi
01G
Not that they are just down the road from the likes of TopSpeed and JPM Coachworks, http://www.theretrofitsource.com/contact_us.php is the place for headlights. Give them a call
1breel is offline
Old 07-18-2013, 11:22 AM   #42549
O HELLA JDM
Member#: 292267
2002 Impreza WRX
O HELLA JDM is offline
Old 07-18-2013, 11:34 AM   #42550
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
285/30/18 Hoosier A6s on 18x9.5 Mach V Wicked Awesomes. They weight 3lbs less at each corner than my 17x9 wheels and tires, lol
Unfortunately, they hit the suspension with their +42 offset, so I've got 12mm spacers coming in the mail.
BeBop86 is offline
Closed Thread
the Bugeye thread 5spdfrk Member's Car Gallery 18633 05-20-2010 12:18 PM
Where's the bugeye lip thread?! yankdanger Interior & Exterior Modification 0 04-06-2009 09:43 PM
