Welcome to the North American Subaru Impreza Owners Club Wednesday February 10, 2016
Old 07-16-2013, 09:44 PM   #1576
vicious_fishes
Member#: 158864
2003 SOHC destroker
found the answer:
Originally Posted by sponaugle View Post
Jeff has a video camera now, and is recording some runs, which I will post up asap. Sorry for the delay, but I was out of town for a bit, then managed to get the flu. We swapped motor mounts yesterday on the H6 for some custom adapted ones we made (the regular H6 mounts suck, and the stock STI and Group N ones don't bolt up without an adapter).
JeffS
vicious_fishes is online now   Reply With Quote
Old 07-19-2013, 07:16 AM   #1577
Spec C
Member#: 77737
2003 spec C
Originally Posted by Patrick Olsen View Post
As I recall they used Group N mounts, but removed the EJ top plate (the part that bolts to the engine) and made EZ plates.
Sounds like a plan
Spec C is offline   Reply With Quote
Old 07-19-2013, 10:30 AM   #1578
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
I was just gonna run the D ones till I got around to using machining stuff or CAD and made some solid ones... See if I could manage clearances to get 1/4" lower with the motor. Twin scroll means I'll have two smaller diameter sections of exhast to run through the GDB xmembers notch.
Seraphinwolf is offline   Reply With Quote
Old 07-20-2013, 09:51 AM   #1579
vicious_fishes
Member#: 158864
2003 SOHC destroker
ok so my state transport authority says the only thing that will stop my swap getting registered will be the emissions. anyone have any information RE: emissions of these engines?
i mean i don't foresee any problems so long as there's a cat in the exhaust but better safe than sorry.
Old 07-20-2013, 02:44 PM   #1580
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Plug in. If you don't pass ODB2 readieness nothing will be worth anything.
Old 07-20-2013, 05:26 PM   #1581
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Is that comment based on your vast experience with emissions testing in New Zealand?
Old 07-20-2013, 06:40 PM   #1582
Seraphinwolf
Member#: 150922
97 OBS EZ30R
No it's on my vast forgetting that not everyone is in the US. It's still a most likely case if there is any emissions testing I would presume.
It is a wonder if those other market ECU's that are opensourcable will let you force readiness like the US WRX and STi ECU's.
Old 07-26-2013, 10:16 AM   #1583
vicious_fishes
Member#: 158864
2003 SOHC destroker
Got the short block together at the machine shop today and brought it home and mounted it back on the engine stand. Still need to put the oil pan(s) on. Block-to-head pins will get to the dealer on Tuesday, after which I can do the heads. No real hurry, since I still have to do all the electrical stuff and I don't even have the harnesses yet.
Received the OBX header, plus a couple little baby Magnaflow spun cats and a new Y-merge.
I don't know if the cats will go in ahead of / upstream of the flexes, or if I'll just ditch the flexes and put the cats in their place. (AFAIK the stock manifolds don't have flexes like that, so I'm not sure what the need is. They're huge flexes, too - I'm used to ones about 1/3 or 1/4 as long.)
hey pat what made you go with a pair of little 2 inch cats (or whatever they are) rather than a single 2.5 inch at the collector?
Old 07-26-2013, 12:24 PM   #1584
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Generally you want the cats closer to the head so they warm up and become effective more quickly.
With that said, the 2" ones are pretty tiny, so I may change my mind at some point. We'll see...
Old 07-26-2013, 02:52 PM   #1585
vicious_fishes
Member#: 158864
2003 SOHC destroker
nothing to do with flow then, gotcha.
i just got a 2.5 for the midpipe so i was curious!
Old 07-30-2013, 03:06 AM   #1586
vicious_fishes
Member#: 158864
2003 SOHC destroker
yesssss just got approval from the transport authority. my swap is going to be registered
Old 07-31-2013, 07:07 PM   #1587
vicious_fishes
Member#: 158864
2003 SOHC destroker
and to make my third post in a row: anyone looked into forged internals for these engines?
there's a couple of brands that make production/off the shelf rods and pistons, BUT... i'd really like to run a custom job with them. like the MPS engines, i'd love to get a custom piston made with the wrist pin further up the body and longer rods to compensate.
i haven't contacted any manufacturers yet but i've taken a squiz at the piston..
i can't help but think that short of machining into the bottom ringland (which has already been done stock) there isn't much room to move. aftermarket manufacturers are already doing this as they increase the total thickness of the ringlands on their forged pistons.
supertech:
mahle:
Old 07-31-2013, 10:26 PM   #1588
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I hydrolocked the EJ25D in my car last week, so it will sit until the EZ30D is in it. No point in fixing the EJ25 or finding another one to throw in there when I have a project that I've been meaning to do for so long!
I had to give the heads back to the machine shop for some clean up on the lifter bores - previous machine shop nicked the bores when they tore the heads down to clean up , so the lifters didn't want to slide in cleanly. Should have the heads back this week, and perhaps this weekend I can actually work on assembling the engine. I'll also be working on pulling the EJ25, once I get my other car out of the garage (currently taking it apart for some header test fitting).
I've exchanged emails with Franz Diebold @ Diebold Autosport about doing the Vipec V88 install. He's a few hours away in Winchester, VA, which is coincidentally where I picked up this EZ30D back in December. He's awaiting word from me once I get closer to actually bringing him the car.
Old 08-01-2013, 12:06 AM   #1589
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
I came here to say I want a 3L H6 that makes 100hp/L naturally aspirated and want you guys to figure it out, then swap it in my vehicle. Thanks. God bless.
OrbitalEllipses is online now   Reply With Quote
Old 08-01-2013, 12:17 AM   #1590
vicious_fishes
Member#: 158864
2003 SOHC destroker
stock engine with an exhaust & tune on decent fuel will do that...
Old 08-01-2013, 12:20 AM   #1591
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Which engine code, how available, how reliable, and is it aluminum?
Old 08-01-2013, 04:49 AM   #1592
vicious_fishes
Member#: 158864
2003 SOHC destroker
how much do you want to spend?
EZ30R is probably the most accessible/easiest to swap over. EZ36 is the engine i'd swap if i could/was going to stay NA, but it'll cost you $thousands more.
reliability with an exhaust & tune? same as factory. in fact possibly greater.
all alloy engine, about 35kg heavier than an ej25.
Old 08-01-2013, 07:14 AM   #1593
Seraphinwolf
Member#: 150922
97 OBS EZ30R
EZ30D is easiest in my book, with a close second to the EG33 the cheapest. If you are putting in the work the EZ36R should be only slightly harder than the EZ30R.
100hp/L NA? I'd do an EG33. Stock they are way under powered compared to what can be extracted.
Vicious, why do you want to shift the geometry of the pistons and rods?
Old 08-01-2013, 08:37 AM   #1594
vicious_fishes
Member#: 158864
2003 SOHC destroker
all other things equal, the longer a rod is the better.
and i want to rev the snot out of it
Old 08-01-2013, 09:10 AM   #1595
Seraphinwolf
Member#: 150922
97 OBS EZ30R
You want to rev the piss out if it? Valve train, porting, and oiling.
Old 08-01-2013, 04:04 PM   #1596
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Uh. Boost vs engine swap is the question...so less than $7K? Pipe dream really.
Now I'm seeming to remember an earlier conversation about the Subaru engines other than the FA not mating to the bell-housing of my Aisin trans.
I'll have to read more, but EZ36R is the Legacy 3.6R and Tribeca powerplant right?
"Output: 256 hp @ 6,000 rpm, 247 lb-ft @ 4,400 rpm" Must rev higher and needs 100 more hp...these stock numbers are about the wheel output of a very well tuned up twin-screw supercharger with supporting modifications.
Old 08-01-2013, 08:08 PM   #1597
vicious_fishes
Member#: 158864
2003 SOHC destroker
no kidding. i didn't say longer rods are the ONLY thing you need to do
but my older EZ30D without the oil draining AVCS is much more racetrack/rpm friendly.
ah. well you never told us that. in that case i'd just supercharge an ej25 assuming you're trying to find something with more lowdown torque. loads of guys on rs25 have done it. tell us what you're trying to achieve and we can help you much better.
yes that's the ez36. getting one and getting it swapped on the other hand is fairly difficult.
Old 08-02-2013, 08:23 AM   #1598
vicious_fishes
Member#: 158864
2003 SOHC destroker
some of my production for the afternoon:
parallel fuel rails!
Old 08-03-2013, 02:25 AM   #1599
vicious_fishes
Member#: 158864
2003 SOHC destroker
and after testing belt tension on this vs what it is on my ej, decided to give the belt some more wrap:
Old 08-04-2013, 10:13 AM   #1600
sureshot007
Member#: 142405
#716 G2 OBS
I'm thinking about swapping an 02 EZ30D into an 02 OBS. If I get a donor car, do I just need to swap the bulkhead to ecu wiring?
sureshot007 is offline   Reply With Quote
Vag-Com cable resource thread cooleys04 Open Source Reflashes 272 05-08-2015 03:59 AM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 05:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-20-2007 12:36 AM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-17-2005 12:11 AM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 06:04 PM
