Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 07-19-2013, 12:29 PM   #1
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
Default 2013 Impreza First Oil Change, which Mobil 1 oil you use?
Which one do you guys use?
Going to bring the oil to the dealership and let them change it for me.
Do you guys buy your own filter and give it to them too?
Which one should I use? 3 different kind of Mobil 1 Available in Autozone.
http://www.autozone.com/autozone/acc...mString=search
subaru604 is offline   Reply With Quote
Old 07-19-2013, 12:47 PM   #2
fistv
Member#: 350063
2013 Impreza sport
I have always used Mobil-1 but the consensus on here seems to lean towards Pennzoil Platinum or Shell Rotella. I picked up two 5 quart containers of the Pennzoil at Walmart, ~$22 each, and will be changing it as well as adding a fumoto valve that just came in on wed. I'm just trying to decide on a filter, all the dealer had were the blue honeywell filters. Remember this takes 5 quarts and most of the autozone and such stores sell 4 quart jugs not 5 quart.
fistv is offline   Reply With Quote
Old 07-19-2013, 12:49 PM   #3
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
Mobil/Advanced fuel economy engine oil SAE 0W-20 1 qt.
I'm also gonna give Eneos a try. I haven't seen anything bad about it on here yet. Mobil 1 is cheap and readily available though...
I bought 6 of the black rokis from ebay, and that should last me quite a while.
If you're bringing the supplies, I'd find a service station you or someone you know trusts already, instead of the dealership. It's just an oil change, you need someone to care about it, they don't necessarily need to have intimate Subaru knowledge.
Xafen is offline   Reply With Quote
Old 07-19-2013, 12:51 PM   #4
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
Have you guys heard of Motul or Amsoil? Are they better than Mobil 1 for the 2013 Impreza's?
Old 07-19-2013, 12:52 PM   #5
79letour
Member#: 302570
2013 XV
DGM!
Just chang it yourself! Its as easy as an oil change can get.
I wouldn't go M1, I'd get amsoil oe or Castrol Edge. Wallywprld finally has lots of 0w oil!
Old 07-19-2013, 12:53 PM   #6
79letour
Member#: 302570
2013 XV
DGM!
In my opinion, the Amsoil is the best you can get.
Old 07-19-2013, 12:53 PM   #7
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
Will changing it myself void the car's warranty? It's a brand new card....so I don't want to mess with it too much.
Old 07-19-2013, 01:17 PM   #8
fistv
Member#: 350063
2013 Impreza sport
I took mine in to the dealer for the first one so they would do the initial service and fix any problems but I'm not going to pay $105 bucks for anybodies oil change and tire rotation after that first time. Just save your receipts for proof of change.
Old 07-19-2013, 01:24 PM   #9
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
HOLY CRAP, $105 for an oil change??
Old 07-19-2013, 01:40 PM   #10
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
No. It will not void anything. Keep your receipts if you are worried.
$105 sounds about right for a routine service for a stealership. Do it yourself or hand in your man card, your choice. lol
Old 07-19-2013, 01:42 PM   #11
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
My friend just did his oil change in Brooklyn's Subaru for $25 and he brings his own oil in.
Old 07-19-2013, 01:46 PM   #12
myrt1987
Member#: 323103
2012 Limited 2.0i
if you have your own wrench and 22 minutes you pay $0.
Old 07-19-2013, 01:47 PM   #13
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
if you have your own wrench you pay $0.
Yeah, I think I need to get some oil changing supplies...what do I need to buy?
Going to make a list and do some shopping on a Friday night tonight.
Old 07-19-2013, 01:53 PM   #14
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
17mm wrench for the oil drain bolt, filter wrench, and a drain pan. Most auto stores recycle oils for free.
SIA_worker is offline   Reply With Quote
Old 07-19-2013, 01:55 PM   #15
myrt1987
Member#: 323103
2012 Limited 2.0i
Probably want ramps as well. I never needed a filter wrench but good to have.
Old 07-19-2013, 01:57 PM   #16
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
I wonder if I'll get in trouble with changing my oil and lifting my car up in my building's garage.
Old 07-19-2013, 02:02 PM   #17
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
Good call lol forgot the ramps. Menards has them pretty cheap around here. Also I didn't first change myself and dealer did second one. No issues with me doing it. I have receipts in my file cabinet and also log onto "my subaru" and keep all my records there.
Old 07-19-2013, 02:20 PM   #18
lymphomaniac
Member#: 334451
2013 Impreza2.0i CVT
DGM (sedan)
My mechanic fills my car with Eneos. I'm pretty satisfied with it - it allows the boxer to rumble at higher revs, but is also very quiet at idle. It's so quiet that I've had people ask me, "Is your engine running?" while it's idling.
lymphomaniac is offline   Reply With Quote
Old 07-19-2013, 03:12 PM   #19
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Never heard of Eneos before. Who makes it and where do you buy it?
Old 07-19-2013, 03:13 PM   #20
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I've just switched from Amsoil OE to Pennzoil Platinum. I didn't switch because I disliked the Amsoil. I switched because the Pennzoil is cheaper and easier to find (at Walmart), and is often on sale. And also because Pennzoil is rated very highly by people who know oil.
For more information about oil, filters, etc., check out the Bob Is The Oil Guy website:
http://www.bobistheoilguy.com/
Old 07-19-2013, 03:23 PM   #21
lymphomaniac
Member#: 334451
DGM (sedan)
http://lmgtfy.com/?q=eneos&l=1
(just teasing... )
Old 07-19-2013, 03:41 PM   #22
winglik
Member#: 317022
2013 Impreza Sport
Dark Grey Metallic
I got my oil change in dealership. $55 in NJ. I think its a good deal consider it costs around $40 for the oil and filter. Do my own tires rotation myself.
So check your dealership site for coupon. sometime they offer reasonable deal.
winglik is offline   Reply With Quote
Old 07-19-2013, 04:12 PM   #23
Angelus911
Member#: 89967
2012 Impreza Sport
That's going to be my plan as well. I have one more oil change supply of Amsoil OE but will then be moving to Pennzoil Platinum instead.
Old 07-19-2013, 04:32 PM   #24
Caocao
Member#: 330507
2015 Jetta TDI
Pure White
Cheap! I paid close to $50 for a 4.4 litre jug at crappy tire. So i had to buy an extra litre for $12.
Caocao is offline   Reply With Quote
Old 07-19-2013, 04:36 PM   #25
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Well, I've been buying 5 qts of Pennzoil Platinum on sale at Walmart for $20, plus another $7 for the oil filter. I do my oil changes and tire rotations myself, so no additional labor charges. I also buy my air filters (engine and cabin air) at Walmart (or on Amazon) for much less than dealership charges, and install those myself too.
In addition, I've learned to do my own brake rotor/pad/fluid changes, but that's a different story that belongs in a different thread.
