Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Alaskan Impreza Club
Old 07-18-2013, 07:34 PM   #776
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Good choice on clutch! Case closed.
Originally Posted by SleePy04ScOObY View Post
That's my only assumption, I went in to have my car dyno and tuned but they had to stop mid tune because they said my clutch was was slipping @ 17 psi.. So they turned it down to 13.5 and said come back when you get a new clutch installed... My RPMs went up like normal but it's not like my car didnt accelerate.. It did just very.. Verrrry slowly.. I just purchased an ACT XTSS so I'm hopin to get that installed ASAP
P3Auto is offline   Reply With Quote
Old 07-18-2013, 07:50 PM   #777
SleePy04ScOObY
Member#: 362066
2004 Impreza WRX
Aspen white
Thanks man
SleePy04ScOObY is offline   Reply With Quote
Old 07-19-2013, 12:05 AM   #778
Wrxak02
Member#: 262361
06 Evo MR
Wicked White
Seth,
It's Richard. Would that hesitation during WOT shifting be from a possible boost leak? Figuring since theyre the cheap couplers and bands for the FMIC and Intake.
Dick
Wrxak02 is offline   Reply With Quote
Old 07-19-2013, 02:03 PM   #779
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
There are different factors that can come in here. Boost leaks in a MAF setup can cause the car to go rich and perhaps cause a stumble. The BOV if you have one venting to atmosphere can cause a rich spike as well. If after the shift you are experiencing a boost spike this can cause some issues depending on whats going on and how the tune is responding to this spike. The BPV or BOV could also be a little loose or not closing completely or fast enough. Many things can add up to what your feeling.
In any cases like this I like to start with the basics so yes a boost leak check would be a good idea and its simple enough to do. Some basic logging can tell a lot about whats happening as well.
It could be something simple like a little too much tip in (momentary blast of fuel when pressing the accelerator back down quickly after a shift). In this case a wideband would be needed to check to see whats going on during this time. Keep in mind that leaks and other mechanical issues could be causing this effect so they have to be ruled out before you start making tune changes.
All said and done, more data is required here to answer accurately, so start by checking all the basics first.
Seth
P3 Import Autowerks 907.355.6655
Originally Posted by Wrxak02 View Post
Seth,
Dick
Old 07-19-2013, 02:19 PM   #780
Wrxak02
Member#: 262361
06 Evo MR
Wicked White
Word. I just finished making my 'Coupler leak checker' the other night, was waiting for the weekend to test. Thanks for the input.
P.S. I'll probably be scheduling with ya'll about the clutch within the month, it's just about to be delivered, but the book labor time is gonna kill me, HAHAHA
Seth
Old 07-23-2013, 11:53 PM   #781
exogen
Member#: 355393
03 wrx 4eat
psm
You probably should also look into a 3 port grimmspeed (or whatever) EBCS. The stock boost control solenoids on the older cars are usually pretty shot by now.
Seth.
P3 Import Autowerks 907-355-6655
Is the Cobb tuning just as good?
exogen is offline   Reply With Quote
Old 07-24-2013, 08:57 PM   #782
AK907TRE
Member#: 230886
02 wrx,in a coma
loaned a 2001 rs coupe
do most reputable shops in town use the cobb racer software or do they use the more advanced cobb pro (i think?) software to tune accessport - equipped wrx's?
AK907TRE is offline   Reply With Quote
Old 07-24-2013, 10:33 PM   #783
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
The Cobb 3-port is just as good and also comes with a mounting bracket as well, looking at picking one up for my car at some point
tribalwrx is offline   Reply With Quote
Old 07-25-2013, 12:52 AM   #784
exogen
Member#: 355393
03 wrx 4eat
psm
Yeah same, Looks like COBBs is about 5-10$ cheaper and I think free shipping, Grimmspeed isn't. Guess I'll be going with COBB
Old 07-25-2013, 01:11 AM   #785
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
Before doing anything you should figure out who is going to tune it for you. See which they prefer.
LiLpNoY is offline   Reply With Quote
Old 07-25-2013, 01:53 AM   #786
russianphil18
Member#: 339048
2005 wrx sti
Idk if this is a common problem but I want to know if this could be because of my tune.
When ever u let off the throttle and don't have it in gear the rpms sit for a little and then drop. So to make smooth daily driving shifts (having a CM stage 4 clutch and KB short shifter) I have to wait for the rpms to drop a little. I don't have a wideband yet but I am using the AP to read the A/F and when I let off the gas not in gear it reads richer for a second and then leans out.
I hope that was clear. Could this be a tune problem or is this common? Thanks
russianphil18 is offline   Reply With Quote
Old 07-25-2013, 09:50 AM   #787
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
You have a fmic?
cosseywrx is offline   Reply With Quote
Old 07-25-2013, 10:18 AM   #788
Echodeltaseg
Member#: 362716
09 sti
metallic grey
Default how soon can i tune my car after replacing the shortblock.
Echodeltaseg is offline   Reply With Quote
Old 07-25-2013, 01:41 PM   #789
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Our shop has the tools to tune with Cobb or direct flash. Both methods are good and meet the needs for 90% of the customers.
We also do AWD dyno tuning which allows for a precise and fully optimized tune.
Seth
Old 07-25-2013, 01:43 PM   #790
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
I keep the grimmspeed 3ports in stock and will match the price of cobb. The grimmspeeds also do come with a bracket and hoses now.
Old 07-25-2013, 01:45 PM   #791
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
There is some ways to tune this a little. Also do you have a blow off valve that vents to the atmosphere? This can cause your rich spikes and other small issues.
Old 07-25-2013, 06:06 PM   #792
exogen
Member#: 355393
03 wrx 4eat
psm
Can't beat instock. Next paycheck I will try and set up a time to come by and get a tune and a few other things done.
Thanks Seth!
Old 07-25-2013, 06:22 PM   #793
es743u
Member#: 259849
02 Bugeye
I have a 02 EJ20. It was rebuilt and im running a VF49 twinscroll. I have been getting a cracking poping like backfiring combination. It only happens when the turbo spools up and 3/4 to WOT. Also have a accesport and its not throwing any codes. Any ideas? I have changed plugs fuel filter and cleaned the MAF with MAF cleaner.
es743u is offline   Reply With Quote
Old 07-25-2013, 06:45 PM   #794
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Part throttle issues can be for a lot of reasons. A lot of tuners pay little to no attention to that area of the tune as well. That being said you may just need that area of the tune adjusted.
Things that can cause this vary...Manual boost control or stand alone boost control can cause this, atmospheric venting blow off valves, boost leaks, etc.
You probably should go back and check all the basics first. A log or at the very least a reading from a wideband AFR gauge during the event would be helpful.
Using your AP to log a bit would help as well. I would suggest speaking with who ever tuned the car first after you check the basics. If you are still stuck we can walk you thru a few things to try logging but without a wideband we are a little blind on the fueling side of the car.
Old 07-25-2013, 06:52 PM   #795
es743u
Member#: 259849
02 Bugeye
Ok I will get some data from the accesport. I have a walboro 255 fuel pump. Also I used modified injectors.
Old 07-26-2013, 12:12 AM   #796
russianphil18
Member#: 339048
2005 wrx sti
P3auto and cossetwrx
I have a front mount with a bypass valve. 850cc injectors, ported head, Dom 4.0....many other mods but those should be the only relevant ones
So the tune can be adjusted to get rid of those spikes and in turn let the car lower its rpms normally?
Old 07-26-2013, 01:41 AM   #797
cosseywrx
Member#: 276443
If im reading and thinking right ky car does this. But only a few hundred rpms. Then it dies down to normal ifle once fully stopped. Imo its a normal subie action
Old 07-26-2013, 02:27 PM   #798
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Some of it can be normal. Excessive rpms or long term rpm hang is not. There are ways to tune some of this out assuming its not a mechanical issue. My experience with the 2005 STI is that this hang you describe is not normal if its prolonged enough to affect gear shifts for you.
Old 07-28-2013, 04:21 PM   #799
russianphil18
Member#: 339048
2005 wrx sti
I think that if I had a stock clutch and a stock shifter then I think it would be normal timing. But because I have a short shifter and an almost racing clutch I can shift faster but it seems that my engine doesn't want to let me do it that fast. So I think the hang isn't noticeable when stock. Do others with similar setups notice this?
Old 07-30-2013, 02:20 PM   #800
R7MR7M
Member#: 86570
2007 STi
Urban Gray
I also am experiencing RPMs hanging after placing it in neutral. They usually stay around 2500 RPM for about a second or two before dropping to idle, where it kind of surges a bit.
I have an 07 STi with Injen CAI and Catless DP/TBE. I also have a protune, although all the mods/tune were done before I bought the car.
Aside from the tune/mods, what could cause this? I also have some slight hesitation above 2800 RPMs or so when the engine is cold so I usually sit and let it warm up for 1 minute and then it drives like a champ. Anyone have thoughts on that?
R7MR7M is offline   Reply With Quote
Tuner FAQ: How to pick one, what to ask of them, and how to prepare for a tune Unabomber Engine Management & Tuning 16 11-06-2014 02:12 PM
Bend, Oregon Tuners Carartist North West Impreza Club Forum -- NWIC 52 10-05-2010 10:07 PM
Tuner is asking me what compression I am using. Ryan314 Built Motor Discussion 7 04-24-2010 05:44 PM
('93-'01) sorry to ask if asked, how do u search ? christurismohk Impreza Forum 1 06-07-2001 10:11 PM
