Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 07-20-2013, 09:26 AM   #26
Subie_Noob_Brian
Member#: 288037
2015 LightingRed WRX
11' WRX sold**14' XV sold
Originally Posted by ans2k View Post
Could you expand on these?
YouTube.com/brian0010
Look for my video on to disable the VDC
The picture is of my rigid industries dually LED lights. I have to on my roof rack and 1 inside the back hatch facing out.
Subie_Noob_Brian is offline   Reply With Quote
Old 07-20-2013, 10:50 AM   #27
79letour
Member#: 302570
2013 XV
DGM!
Well the RB flaps arleady have me wondering. They seem to need an extra hole drilled on the front and one of the brackets was the wrong size/bend a.d broke when I tried to bend it back. Looks like I'll have to.fabricate some brackets of my own and drill some holes. Definitely not an easy, out of the box fit.
Old 07-20-2013, 11:36 AM   #28
zebratruck
Member#: 362851
2013 Crossrtrek
Ice Silver
Default Rokblokz mud flaps
http://clubcrosstrek.com/index.php/topic,1197.0.html
Mine went on without hitch. Fronts are easy, rears I had to switch around some of their hardware but worked fine. No extra hold needed on the fronts, one drill per side on the rears but it's just into the lower plastic corners.
zebratruck is offline   Reply With Quote
Old 07-20-2013, 11:40 AM   #29
79letour
Member#: 302570
2013 XV
DGM!
These brackets look like a kid made them. and there has to be a hole drilled behind the front face of the L bracket. Did your car come with oem splash guards?
Old 07-20-2013, 11:41 AM   #30
79letour
Member#: 302570
2013 XV
DGM!
The holes on the L brackets are so off-center that they can't line up with the clips.
Old 07-20-2013, 11:45 AM   #31
79letour
Member#: 302570
2013 XV
DGM!
I work in a fabrication shop so I can make my own brackets monday.
It just sucks that I have to wait. I wanted to install them this weekend. I'm trying to think of some way of making them now but IDK where to get anything like what I need on the weekend.
Old 07-20-2013, 11:45 AM   #32
zebratruck
Member#: 362851
2013 Crossrtrek
Ice Silver
Don't know, I put everything together loose and got it lined up and it all worked. If I can take any extra pics or something for ya of mine i will.
Old 07-20-2013, 11:46 AM   #33
79letour
Member#: 302570
2013 XV
DGM!
Cool that would be nice!
Old 07-20-2013, 11:54 AM   #34
zebratruck
Member#: 362851
2013 Crossrtrek
Ice Silver
I did not have the factory mud flaps.
Old 07-20-2013, 11:56 AM   #35
zebratruck
Member#: 362851
2013 Crossrtrek
Ice Silver
True, the hardware looks like it's right from the local hardware store but it all seemed to work. And for half the price of the RA's, I'm good with that.
Old 07-20-2013, 12:19 PM   #36
zebratruck
Member#: 362851
2013 Crossrtrek
Ice Silver
Vertical screw first through the L bracket, left loose, the the horizontal screws?
Old 07-20-2013, 12:26 PM   #37
zebratruck
Member#: 362851
2013 Crossrtrek
Ice Silver
From the bottom:
Old 07-20-2013, 12:27 PM   #38
zebratruck
Member#: 362851
2013 Crossrtrek
Ice Silver
And from inside the wheel well. You can see the flap is skewed to one side but it still worked.
Old 07-20-2013, 12:31 PM   #39
zebratruck
Member#: 362851
2013 Crossrtrek
Ice Silver
Hey ans2k, where did you tap in to power the rear basket work lights? Are they on a separate switch/relay setup?
Old 07-20-2013, 12:39 PM   #40
79letour
Member#: 302570
2013 XV
DGM!
Yeah I'm gonna go to ace and see if I can find somethimg to make the L brackets out of.
To Rokblokx credit- theyre very friendly and easy to deal.with.
If these can be put on without any more hitches, I'll be pleased. The hardware is at least stainless, and for $20 per wheel it isnt a bad deal.
Old 07-20-2013, 01:10 PM   #41
ans2k
Member#: 315631
2012 Impreza Sport
Hey, I think you might have missed it, but I was quoting Subie_Noob_Brian. I would like to know as well.
Old 07-20-2013, 01:13 PM   #42
Tacodude
Member#: 362845
2013 XV CROSSTREK
Tangerine Orange Pearl
Originally Posted by old school View Post
My only mod so far is wheels.
What kind of wheels are those? They look real good on your XV.
Tacodude is offline   Reply With Quote
Old 07-20-2013, 02:41 PM   #43
Subie_Noob_Brian
Member#: 288037
They come with a complete wiring harness, relay, and switch. I have the 2 lights on the basket on a switch up front by the traction control button and the light in the rear is wired completely separate with the switch in the rear hatch cut into where the abs cover pops off of the c pillar.
Old 07-20-2013, 06:37 PM   #44
79letour
Member#: 302570
2013 XV
DGM!
Finally done with the install of the Rokblokx flaps.
Meh, they're ok. I'm a little disappointed. I am decent at rigging things, and am pretty crafty at fabbing up stuff on the fly.
The rear hardware is almost useless, more than half of it had to be sourced at the local ACE hardware.
I would say if you're handy, and have tools and a work area- they are a decent buy. But they are not a simple bolt on. The fronts mounted pretty well. The rears dont have as solid a mount, due to mostly plastic as the backer to attatch to.
I need to do some more tweaking on the rears, theyre a little slanted.
But really, other than the flaps, every other bit is sitting right at tue hardware store. Even the brackets that mount the lower fronts, theyre just rebent "corner supports" available right at the hardware store.
On a 1-10 scale, I'd give these a 5 or 6.
If you want cheap flaps that are diy I that a universal kit and some stuff from Ace would be a better buy for the money. I'll grab some cutting boards at ikea and maybe try that method next time. I am not trying to trash the product. I just think theyre merely ok and that they could have been engineered a little better. I'd still rather have these than the oem splashguards.
But if you aren't handy, have someone qualified to install them. And unless they change some things you may need to head to the hardware store.
Im pleased that theyre on, and I like the fronts.
Pics when it gets done raining...
I finished JUST IN TIME. Was a bit of a headache, but now its debadged, and the flaps and weathertech mats are nice on an all-weather, all-roads type of car.
Starting to really enjoy the tasteful modding.
Now to do something about all that chrome on the nose...
Old 07-20-2013, 07:06 PM   #45
79letour
Member#: 302570
2013 XV
DGM!
To their credit- the RB'S are made of great material, and the people at Rokblokx are simply FANTASTIC to deal with. They are quick to respond and very courteous and helpful. I give them an A as they were sending me the right brackets etc... I just wanted to get them done so I had to get some hardware. Not the end of the world and I DID save $50-60 over buying Rallarmor's.
Another plus is that unlike RA's, you dont have to have logos. Since I'm loving the un-badged look, I think these are the best out there in kit form for the same price as oem plastic pieces.
Old 07-20-2013, 08:38 PM   #46
zebratruck
Member#: 362851
2013 Crossrtrek
Ice Silver
Those rear lights look great, very bright.
Old 07-20-2013, 11:40 PM   #47
79letour
Member#: 302570
2013 XV
DGM!
Those are amazing!
Idk if i'd need all that, but brighter/more reverse lighting is on the to-do list.
Old 07-21-2013, 12:13 AM   #48
ans2k
Member#: 315631
2012 Impreza Sport
can we get a picture without them on? Hard to see without the glare.
Old 07-21-2013, 12:13 PM   #49
old school
Member#: 22647
91 Leg SUS
015 XV SE
THey're Motegi. I chose them for their weight, 16.3 lbs vs 18.8 for the stock wheels.
old school is offline   Reply With Quote
Old 07-22-2013, 06:48 PM   #50
79letour
Member#: 302570
2013 XV
DGM!
The flaps are doing their job! Man has it ever been rainy this summer, there are puddles everywhere. They offer excellent coverage. I'm really pleased with the fronts. I am going to re-do the rears friday at the shop where I work.
