Old 07-11-2013, 10:17 AM   #1
Iownit4
Member#: 358947
13 Wrx
Default 2013 wrx hatch & 17x9 with 255/40/17
Will this set up work on a stock suspension or will it rub.
I want enkei rpf1 17x9 was thinking of getting 255/40/17 . What offset will I be best off with stock suspension. Thanks
Iownit4 is offline   Reply With Quote
Old 07-11-2013, 10:27 AM   #2
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
go with the +45. you shouldnt rub.
gsrcrxsi is offline   Reply With Quote
Old 07-11-2013, 10:58 AM   #3
Iownit4
Member#: 358947
13 Wrx
Ok ty
Old 07-11-2013, 11:22 AM   #4
Iownit4
Member#: 358947
13 Wrx
Would 17x8 work with 255 /40 ?
Old 07-11-2013, 11:53 AM   #5
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Not ideal. Stick with 17x9.
mav1c is online now   Reply With Quote
Old 07-18-2013, 10:18 AM   #6
Wr3ks
Member#: 358988
2013 wrx
wrb
Late to the conversation, but if u want a flat face rpf1 you have to get a 9" wide wheel. Just an FYI.
Wr3ks is offline   Reply With Quote
Old 07-18-2013, 11:12 AM   #7
Josh R.
Member#: 351365
2013 PBP WRX
2002 2.5 RS
Yes it will work fine. That's what I have and a lot of autocrossers also use that. But if you can get a 17x9 you might as well.
Josh R. is offline   Reply With Quote
Old 07-24-2013, 02:55 AM   #8
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
lol on stock struts and everything? take pics of fitment. i think your gonna need spacers and some work done w/o rubbing.
JAMM0N is offline   Reply With Quote
Old 07-24-2013, 08:31 AM   #9
Josh R.
Member#: 351365
2013 PBP WRX
2002 2.5 RS
I don't know why that's funny, but yes...
On stock struts "and everything." Lots of room.
Old 01-12-2014, 10:56 AM   #10
Iownit4
Member#: 358947
13 Wrx
Is it ok if I'm using 255/40/17 with my 17x9 rpf1 in the back and the stock 235/45/17 on the same rims in yhe fronts, or should I get 255/45/17 for the back
Old 01-12-2014, 11:13 AM   #11
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Do not stagger tire sizes under any circumstances. Do so, then prepare for imminent failure of your center diff. The tires you choose must all be the same size mounted to the same sized wheel.
RoadKillDMD is offline   Reply With Quote
Old 01-12-2014, 01:01 PM   #12
Iownit4
Member#: 358947
13 Wrx
Ok will do 255 all around
Old 01-12-2014, 01:08 PM   #13
RoadKillDMD
Member#: 284792
2011 STI
Blurple
They also have to have the same sidewall height. 255/40/17 all around will do you fine.
Old 01-12-2014, 06:56 PM   #14
Iownit4
Member#: 358947
13 Wrx
Okay thank you I appreciate the information
Rob
