Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 05-19-2013, 11:16 AM   #2151
Kavanaghcr
Member#: 356804
2005 Subaru 2.5RS
Matt Grey
Originally Posted by sc00by4life View Post
You'll need to roll fenders for sure.
You need to find out the center bore of the weeks though....Toyota uses a narrower hub bore than Subaru, so there's a high chance the wheels still won't fit.
That fitment and stretch will look pretty stupid at stock height.
Yeah I went to get new centering rings that shouldn't be an issue anymore. But I figured that much. I'll save for some coilovers before putting them on.
If I were to only get something like Tein S Techs instead would you have a suggestion as to what tire size would be better to fill in the wheel gap? I don't mind meaty tires.
Kavanaghcr is offline   Reply With Quote
Old 05-19-2013, 01:02 PM   #2152
sc00by4life
Member#: 97135
Hub rings won't work if its too small to fit over the Subaru hub bore....
Old 05-19-2013, 03:02 PM   #2153
Kavanaghcr
Member#: 356804
2005 Subaru 2.5RS
Matt Grey
The rings are not the issue. they fit thats all good. forget about the hub bore.
I just want to know what is a good tire size for a subaru lowered on s techs for that rim size. If anyone has a suggestion since my 225/40/18 are too stretched/would look funny
Old 05-20-2013, 10:09 PM   #2154
swede_ish
Member#: 327426
Default 17X9 +45 rpf1 myth buster..
A lot of people say with the flat face rpf1 on a +45 offset 9 inches wide you will barely have any brake clearance. I purchased some anyway, hoping to get away with some 3 mm spacers.
I drive a 9-2x aero with a wilwood 4 pot bbk. My rpf1's came in the mail today and I'd like to say I had plenty of clearance WITHOUT a spacer. The wilwoods stick out a half inch from the wheel mating surface of the hat.
Pics:
For those interested tires are nexen n7000 235/40's
swede_ish is offline   Reply With Quote
Old 05-21-2013, 12:07 AM   #2155
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Looks great.
And I think most of the brake clearance issues are with OEM type Brembos, which I'm pretty sure take up a lot more space then your sexy Wildwood kit.
Breezio is online now   Reply With Quote
Old 05-21-2013, 12:25 AM   #2156
swede_ish
Member#: 327426
Well from what I've read a lot of people claim this size and offset barely clear stock wrx brakes (2-pots not 4's)
Old 05-24-2013, 04:37 PM   #2157
SubaruLOVER69
Member#: 355403
2005 Impreza wrx sti
Talking
Ok I have read this whole thread but was wondering if I could put 18x8 with a 40 mm offset on my 2005 subaru sti. It is also on H&R lowering springs. If so what tires could i use. Any help would be great
SubaruLOVER69 is offline   Reply With Quote
Old 05-29-2013, 03:02 AM   #2158
JohnnyM
Member#: 356392
2014 BRZ
Im trying to get a flush fitment on my 05 wrx wagon. What size wheels and tires should i be running? Ive seen ppl say 18x9.5 or 17x9 but i really need help! lol Im gonna be on bc coils with front and rear camber plates.
JohnnyM is offline   Reply With Quote
Old 05-29-2013, 09:31 AM   #2159
swede_ish
Member#: 327426
If you want to run 17x9 I'd highly suggest a +42 fitment, or a 45 with a 3mm spacer. That will make you flush in the rear, the front however will poke, slightly. But that can be cured with sedan fenders. I'd run a 245 or 235 40 17 on those
Old 05-29-2013, 11:52 PM   #2160
23DD27
Member#: 317543
2004 WRX STI
23DD27 is offline   Reply With Quote
Old 05-31-2013, 03:32 PM   #2161
erikengland
Member#: 318868
Default shopping spree
Would anyone like to help me splurge? I have a $4k-$5k budget. I own a 2008 WRX Sedan and would like to upgrade wheels, coilovers, rotors, brakes. I am currently rocking stock all around. Stock wheels are in good shape and wouldnt mind keeping on the car. New rubber is extremely necessary.. Dimensions for stock wheels are 17" x 7", 5 Lug, 100mm Bolt Pattern, 55mm Offset.
If anyone wants to help, email me @ erikengland13@yahoo.com
I figure this may save me time from having to navigate this massive forum site.
erikengland is offline   Reply With Quote
Old 06-05-2013, 04:05 PM   #2162
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
What's in it for us? Why don't you have to spend the time searching when we did?
colin1234567 is offline   Reply With Quote
Old 06-17-2013, 08:23 PM   #2163
German05
Member#: 359738
Default 2005 Sti bbs to 08 Sti Oem rims
Am I able to put 2008 Oem rims which are 18in
With a offset of 55 on my 2005 Sti tht is lower and Oem rims without needing to rolling my fenders
German05 is offline   Reply With Quote
Old 06-17-2013, 10:06 PM   #2164
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Should work. What tires and what's the width of the wheel?
dburgoon is offline   Reply With Quote
Old 06-18-2013, 11:41 AM   #2165
Breezio
Member#: 234357
2009 WRX
OEM GR wheels are 18x8.5 IIRC
Old 06-21-2013, 08:46 PM   #2166
G.Tric
Member#: 357152
2005 Legacy gt wagon
Midnight Blue
Hey guys def a rookie to all all of this so pardon if this is a dumb question...I'm looking to put some 3sdm .01 on my 05 legacy wagon 2.5 gt ..the guy I was going to buy them from said The Legacy is listed to use a ET35 offset but on an 8J rim. These are 8.5J so they may catch on the arches..does anybody know if this is the case? And if it is what will I have to do to make it work? And I have tried to research I'm just not really up on the lingo so i don't understand much..another question is if it does catch the arches why?? (Just for my understanding) thanks
G.Tric is offline   Reply With Quote
Old 06-21-2013, 09:43 PM   #2167
sc00by4life
Member#: 97135
You've posted this already.
You're information on stock legacy wheel specs is still wrong.
Take a ruler and go do some measuring.
Old 06-24-2013, 01:06 PM   #2168
G.Tric
Member#: 357152
Midnight Blue
17x7 off set 55..I see a bunch of ppl putting wheels on there cars that don't match stock specs..what I need to know is what exactly I would have to do in order to fit these wheels..
Old 06-24-2013, 11:55 PM   #2169
Breezio
Member#: 234357
2009 WRX
His point was that the information you were given about stock Legacy wheels was wrong.
All the recent ones have a ET55 offset. Not ET35.
And I'm not sure about the newest generation, but the 05-08 Legacy's ran a 17x7, not a 17x8.
So, it makes it hard to give you any advice as the information you have is incorrect.
It sounds like you are looking to put a 8.5" wide wheel (unkown diameter) with a +35mm offset on a '05 Legacy. My understanding is that is a somewhat aggressive fitment and would likely need some fender work depending on tire size, ride height, etc...
Old 06-25-2013, 11:59 AM   #2170
G.Tric
Member#: 357152
Midnight Blue
Ok thanks
Old 06-28-2013, 04:38 PM   #2171
Ballocks
Member#: 281928
2008 WRX hatch
obp
Hey guys, just purchased some 225/45/17 size tires for my 08 wrx hatch (this is stock size for 09-10). The reason I went with the wider stock size is because I'd like to pick up some 17x8 or possibly 17x8.5 wheels. My question is what sort of offset is needed to get a wheel of that size to fit?
Ballocks is offline   Reply With Quote
Old 06-28-2013, 05:03 PM   #2172
Dat8687
Member#: 243261
2004 WRX
Java black pearl
That tire will fit 17x8 and 17x8.5...It will be stretched some on the 8.5 not much though.. within spec probably..
If you have an 08 I would get an 8.5 wide at least with 45 offset minimum but that's just me..
Dat8687 is offline   Reply With Quote
Old 06-30-2013, 04:21 PM   #2173
Breezio
Member#: 234357
2009 WRX
Probably anywhere from +55 - +40 wouldn't require fender work.
Old 07-12-2013, 02:10 PM   #2174
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
Originally Posted by Red_Devil_24 View Post
11-12 wrx as a +53 offset with stock wheel, STi as +55. Anything between +55 and +40 on an 8" or 8.5" width wheel will fit easily.
Yea. After searching through 100 pages I found my answer, assuming this is correct. I don't just want a good fit, I also want a stock appearance. I was concerned that stock is 53 but most of tire rick's 17 x 8 rims are 45 or 48.
HAL1 is offline   Reply With Quote
Old 07-25-2013, 07:49 PM   #2175
doeboy23
Member#: 358362
Great info
doeboy23 is offline   Reply With Quote
So I read the Offset thread... Dracon Tire & Wheel 6 11-18-2012 05:39 AM
The Hella Flush Information Thread Impreza2.5i-Kid Tire & Wheel 16 08-23-2010 09:33 AM
The end all 6 speed swap information thread DS1 Transmission (AT/MT) & Driveline 156 11-14-2009 09:21 PM
Can we correct "The Offset Information Thread"? Portly Tire & Wheel 15 02-25-2006 07:48 PM
The Header Information Thread imposter Normally Aspirated Powertrain 315 04-25-2003 03:59 PM
