Old 07-18-2013, 05:17 PM   #1
2002wrxwv
Member#: 291567
Default EJ 205 Turbo Problem and CEL
I have completely and successfully swapped the JDM EJ205 into my bugeye, well so i thought. I took it out for the first drive and it threw the code P0121 which is Throttle Position Sensor Switch A Circuit/Range Problem. It also feels like the turbo isnt spooling at all and it will barely run 55 mph. Any suggestions?
2002wrxwv is offline   Reply With Quote
Old 07-18-2013, 09:33 PM   #2
2002wrxwv
Member#: 291567
I replaced the TPS and nothing happened, still wont pull itself hardly at all. Im lost on this one.
Old 07-18-2013, 10:18 PM   #3
rdieder
Member#: 257818
2007 STi
What ecu are you running?
rdieder is offline   Reply With Quote
Old 07-18-2013, 10:22 PM   #4
2002wrxwv
Member#: 291567
USDM, the distributor of these jdm ej205 said all I had to do was swap the cam position sensor, crank position sensor, sprockets to match those two, and the intake manifolds which i did.
Old 07-19-2013, 03:20 PM   #5
2002wrxwv
Member#: 291567
Any ideas?
Old 07-20-2013, 05:49 PM   #6
2002wrxwv
Member#: 291567
Anyone?
Old 07-20-2013, 07:03 PM   #7
2002wrxwv
Member#: 291567
I took the intercooler off and oil fell out of the turbo, im assuming this could be a serious contributor to my problem
Old 07-27-2013, 12:34 AM   #8
Mike Wondo
Member#: 332416
2002 WRX Wagon
did you pre-lube the turbo ?...also there is a filter screen in the turbo oil feed line. They get clogged and starve the turbo and ultimately burn up the seal...
Mike Wondo is offline   Reply With Quote
