Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Closed Thread
Old 07-27-2013, 03:11 AM   #26
Member#: 268580
eNx is online now
Old 07-27-2013, 04:01 AM   #27
Member#: 88618
1994 Legacy
"The Silver Slug"
Yet here I am going to say that putting 5 litres in is actually fine.
i_c_the_light is offline
Old 07-27-2013, 06:57 AM   #28
Member#: 330507
2015 Jetta TDI
Pure White
Of course it's fine, 5 litres=5.3 q. BTW, "full full" isn't really an accurate method of measurement...just saying. 2004, should be almost due for its next oil change!
Caocao is offline
Old 07-27-2013, 07:41 AM   #29
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
You can put in 10 quarts and the only problem you'll see is oil seeping out of the dipstick hole. This isn't a Toyota that'll blow up with an extra ounce. Every other Jiffy Lube oil change in older Legacy GTs has been to remove the tranny bolt and drain the tranny fluid, then overfill the already full oil by 5 quarts. This is why Subaru went to a T70 on the tranny bolt. All the reports from those cars were lunched trannies and perfectly fine engines.
Jack is offline
Closed Thread
Over-filling the engine oil Rabid Dog Service & Maintenance 40 08-17-2013 01:10 PM
Could oil over fill cause knock? Kastley85891 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 03-23-2008 02:51 AM
Need Help! Oil Return Line From Turbo 84SubaruDL Mid Atlantic Impreza Club -- MAIC 22 08-09-2006 01:11 PM
tranny oil, over filled? subywrxdude Transmission (AT/MT) & Driveline 5 02-28-2006 01:14 PM
over filling oil Jerry Seagreaves Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-09-2003 05:27 PM
