Old 10-30-2010, 09:38 PM   #1
I<3APS
Member#: 262525
'03 WRX BabyZilla
Gunmetalish?
Default 2003 WRX HELP! Knock sensor!
I have a 2003 wrx with about 50k on the motor and I am throwing code p0328 knock sensor high input. Replaced the knock sensor because thats all I read on the forums was everyone saying replacing it fixed it. It didn't make the code go away. I did the age old test with a multimeter on ac current and tapping the block with a hammer but no dice.... didnt register anything. Now I dont know if that test doesnt work because WRX knock sensors are tuned for just ping which is like 6000-7000hz which I obviously can't replicate with a hammer buttt idk... I am stumped. The car doesnt really hesitate, the code just wont turn off and I don't hear knock whatsoever. Anyone have any ideas how else to test it or what else to do? Aftermarket knock light? I need this car tuned and they wont tune it without hte knock sensor!
I<3APS is offline   Reply With Quote
Old 10-31-2010, 05:33 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
the orientation of factory knock is important.
did you follow the instructions?
angle?
torque?
Old 10-31-2010, 05:34 AM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
angle?
torque?
Old 10-31-2010, 01:21 PM   #4
I<3APS
Member#: 262525
'03 WRX BabyZilla
Gunmetalish?
Yeah I can't remember what the torque was something undre 20ft lbs I torqued it too like 17 or something. And the pig tail gets tucked into the corner towards the tranny bellhousing. I've done it too many times to screw it up... lol Sooo yeah I'm not sure where else to check though other than starting the car up and purposely making the motor detonate to cause knock to test the sensor... but its hard to get the multimeter prong under the intercooler while the car is started.
Old 10-31-2010, 02:22 PM   #5
rouckey21
Member#: 148207
02 WRX
PPG box'd
did u try clearing the code out and driving around for a while... you say that everything seems to be fine now that you replaced it. just clear the code and drive around for a bit and see if it comes back. if it doesn't than you have no issue if it does than its something else
rouckey21 is offline   Reply With Quote
Old 10-31-2010, 03:34 PM   #6
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
Old 11-01-2010, 01:06 AM   #7
I<3APS
Member#: 262525
'03 WRX BabyZilla
Gunmetalish?
As soon as I clear the code with my code scanner it comes right back on. It will flash off for like 2 seconds then come right back even when the car isnt started up and just in the "on" position it wont go away. It shows 2 codes a "pending" one and then the actual code and they both wont go away. But thanks for that troubleshooting guid ill try it out!
Old 11-01-2010, 01:15 AM   #8
Uncle Scotty
OK buy Nates beans
did you see the link I posted, above????
Old 11-02-2010, 12:21 AM   #9
I<3APS
Member#: 262525
'03 WRX BabyZilla
Gunmetalish?
Yeah thanks for that I'll try it out on my day off tomorrow.
Old 07-27-2013, 12:51 PM   #10
vms150
Member#: 172917
2004 WRX
I know I am reviving an old thread, but it's right in line with my question. It's is said that the orientation is very important. Is it possible to clock the sensor incorrectly, causing an issue and does anyone have information on the exact position it needs to be in?
vms150 is offline   Reply With Quote
Old 08-10-2013, 12:53 PM   #11
MonsterRSTI
Member#: 351200
I have simular issue
MonsterRSTI is offline   Reply With Quote
Old 08-11-2013, 01:00 AM   #12
Uncle Scotty
OK buy Nates beans
yeah...it is real easy to put it in the wrong orientation
id post the page outta the fsm but im at work and dont have it handy
Old 08-11-2013, 01:44 PM   #13
Ej20_dgaf
Member#: 364985
Anyone know how to set the knock sensor on an apexi safc 2
Ej20_dgaf is offline   Reply With Quote
WRX Knock Sensor Check *HELP!!!* CarbonCJC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-28-2010 10:29 PM
2003 WRX Help! Breather Cover brd360sk8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-10-2010 09:12 PM
FS: 2003 WRX TGV/TPS Sensors lettucemanatee Engine/Power/Exhaust 1 03-29-2010 07:36 AM
Wtb: 2003 wrx front o2 sensor Never_Satisfied1 Private 'Wanted' Classifieds 1 08-18-2009 11:01 PM
2003 WRX Tap/Knocking noise from engine? help peterislazy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-31-2008 09:38 AM
