Old 07-27-2013, 12:20 PM   #1
vms150
Member#: 172917
2004 WRX
Default Car Falters Violently Under Boost
Yesterday I was driving my car and as soon as I got into boost (between 5-10lbs) the engine pretty much fell on its face as if it hit the fuel cut off. It was violent. The car would stutter hard and the boost needle would shake violently. I would let off the accelerator and I could drive fine out of boost. This happened about a month ago but a bit differently. I would start the car and it would idle horribly for about 5 seconds then die. It was non-responsive for the most part to the throttle to try to keep it alive. I have checked for boost leaks, loose grounds and vacuum leaks to no avail. I installed a new fuel filter at that point just incase. The odd thing is the next day it worked fine and has since, until yesterday. BOTH instances were in the rain, I don't know if this is coincidence or possible part of the problem. Any help would be much appreciated. ALSO, no CEL or codes on the scanner.
Mod List for Reference:
port and polished td04
header back catless exhaust
GS EBCS
Warboro 255lph fuel pump
STI tmic
SPT intake
Wicked Innovations tune
vms150 is offline   Reply With Quote
Old 07-27-2013, 01:30 PM   #2
WTFWJD014
Member#: 226468
2005 Impreza WRX
I woukd try a compression test and a leak down just to know the numbers are at a safe level. Does it run rich or lean? If you have logs that would be helpful too
WTFWJD014 is online now   Reply With Quote
Old 07-27-2013, 01:51 PM   #3
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
I'm located near you and can help. I've seen a bit of cars with the same issue, and as they get older I see it more and more often.
9/10 its bad plugs, a coil pack on its way out, or cam sensor failing.
PM me if you would like me to try and help.
Old 07-27-2013, 01:56 PM   #4
vms150
Member#: 172917
2004 WRX
Blaze, if the issue persists I will definitely contact you. Thanks so much for the offer. I believe I may have tracked down the issue. It seems that what it rains hard a puddle forms on top of the knock sensor. I blew it out with compressed air and let the engine heat up for about 15 mins to dry it out and now it's fine.
Also, is there any way or testing for a bad coil pack? I don't mind just swapping plugs or cam sensors but the coil packs are rather expensive to change on a guess.
Old 07-27-2013, 04:25 PM   #5
WMCCook29
Member#: 152685
2005 VF34 WRX Wagon
GS EBCS
STI tmic
SPT intake
A wet MAF exhibits these symptoms - happens with short rams from time to time.
WMCCook29 is offline   Reply With Quote
