Old 02-24-2013, 02:07 PM   #26
wrxli93
Member#: 300434
wrxli93 is offline   Reply With Quote
Old 02-25-2013, 08:25 AM   #27
twinturbomeow
Member#: 315546
03 wrx
Originally Posted by wrxli93 View Post
Thank you Everyone. And yes maybe I should simplify the question... If you were a poor college student what parts would you put on a 2.0 Bugeye to make a reliable 330.
upgrade to sti turbo, injectors, tmic, fresh red intake mani with tgv deletes, turboback and catless uppipe flashed with a cobb map for the sti turbo= fun ass reliable daily
twinturbomeow is offline   Reply With Quote
Old 02-25-2013, 08:56 AM   #28
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
If your goal is cheap 300ish whp I would go with a vf39 +sti pink injectors+used sti topmount and the cobb basemap with proper data logging.
https://static.cobbtuning.com/cobbtu...02-05_VF3X.pdf
for more info
at least that saves you some money to pay to rebuild your 5speed that will at somepoint eat its self alive anyways
Shortpersonbk is offline   Reply With Quote
Old 02-25-2013, 10:41 AM   #29
wrxli93
Member#: 300434
My Goals are more that 300ish... I want closer to 350 there's a difference.
Old 02-25-2013, 12:12 PM   #30
wotrex
Member#: 330266
Upgrade trans sooner rather than later, otherwise that happens^^^^^
wotrex is online now   Reply With Quote
Old 02-25-2013, 12:38 PM   #31
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well besides what i said before wrxli93 you are prob around 195whp on the stock tune. on a stage 2 tune you can get your car to the 250whp area no problem. going from 190ish to 350 is nearly doubling the whp which is quite a bit of power upgrade. going up 100whp with a sti turbo, tmic, injectors and some maintanence parts will make the car very reliable and you wont have to worry about blowing the trans as fast. mine blew to hell on a spicey e85 tune w/ the td04 two years ago. other guys i know have 18g's w/ ej255 and there trans are fine. its how you treat it but just ONE mistake will ruin your day. you can upgrade to around 300whp for around 1k dollars and have money left over to fix small stuff. if you want some more help i can help you via pm. i got some sti parts as well i can sell ya
WhiteBgeye02 is offline   Reply With Quote
Old 02-25-2013, 12:50 PM   #32
Mike05wrx
Member#: 314747
2005 WRX
have you ever driven an all wheel drive car with 350whp? that's quite a lot of power, and since you have a bugeye, those 5spds are weak. you're not really gonna be able to unleash the full power without a real danger of blowing up your tranny. if you're in college, and don't wanna spend 4k for a 6spd, i'd recommend just going with a vf39/43/48, an sti top mount, injectors and a fuel pump. that'll put you at more or less 300whp and you won't have to worry so much about your 5spd grenading
Mike05wrx is offline   Reply With Quote
Old 02-25-2013, 07:06 PM   #33
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Built not bought. #0003
My 02' bugeye has about 180k on it and I have been pushing 300+ AWHP for about 100k of that. Granted I have rebuilt the motor once because my head gaskets went. But my trans is still rocking like a champ. I beat on my car pretty hard too. I know this is a rarity and pretty much a miracle with these glass trannys (02-03's) but just saying, do what you want here, and if your trans blows up it blows up. But until then, I don't see the need to worry about it.
But when my trans finally does go, a full 6 speed swap will take its place.
02blkwagn19 is offline   Reply With Quote
Old 07-28-2013, 07:40 PM   #34
MidnightMist02
Member#: 363623
What 6spd transmission are you aiming for when the time comes?
MidnightMist02 is offline   Reply With Quote
Old 07-28-2013, 11:09 PM   #35
amagana
Member#: 320578
2003 WRX
PSM Stage 2
As a fellow college student who is in the same boat (literally just went stage 2 & coils this summer) and trying to keep your car reliable (my bugeye is about to hit 70k miles), upgrade to a sti turbo (vf39, 43, 48), bigger fuel pump and fuel injectors (255 and at least 565 respectively), and a sti or equivalent TMIC and you'll be more than satisfied till the end of you college years. You could even pull a map off of cobbs shelf with the vf39 and skip the tune (assuming you already have an accessport)
I just turned 20 and go to college and this is what I'm doing, plus headers, sway bars, and a tune.
amagana is offline   Reply With Quote
Old 07-28-2013, 11:48 PM   #36
ToddMcF2002
Member#: 135007
2014 STi Hatch
Crystal Black Silica
I'm not going to get preachy but this is a very sensible post. Solid power boost the car is more likely to handle. Granted they are 2.5L, but have you driven an sti with a proper tune? They aren't exactly slow!
ToddMcF2002 is offline   Reply With Quote
Old 07-29-2013, 11:55 PM   #37
OBP WRX
Member#: 330185
I agree...vf39/sti tmic/pinks/fuel pump is your best bang for the buck and with a good tune will be fun until you have the $$$ to build it right.
If you NEED MOAR...(** is what I consider minimum requirements)
**High quality TMIC (GrimmSpeed, Process West, etc)
**ID 1000's
**DW 300 pump or bigger if you plan on E85
**18gxt (320hp) or 20gxt (350hp)
Composite tgv deletes (no need for phenolic spacers then)
GrimmSpeed P&P/coated manifold/cross-pipe
**GrimmSpeed catless/coated up-pipe
**GrimmSpeed EBCS
GrimmSpeed pulley
**Perrin turbo inlet
Cobb SF intake with box
OBP WRX is offline   Reply With Quote
Old 07-30-2013, 12:14 AM   #38
yellowlightrunner
Member#: 287869
2005 Legacy GT
[quote="OBP WRX;40301734"]I agree...vf39/sti tmic/pinks/fuel pump is your best bang for the buck and with a good tune will be fun until you have the $$$ to build it right.
That and a catless invidia tbe and up pipe be a solid car
yellowlightrunner is offline   Reply With Quote
Old 07-30-2013, 01:42 AM   #39
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
[quote=yellowlightrunner;40301860]
Very little (if any) gains with catless DP in this power range. Better off with a hi-flow catted dp. You won't get the in cabin funk, the rear of the car will be cleaner, and of course, it's better for the enviroment.
Fierysun is offline   Reply With Quote
Old 08-01-2013, 04:06 PM   #40
rburns95
Member#: 326731
2002 Impreza WRX
Do not go with an eBay tmic. Go with an sti tmic. The eBay ones wont hold boost and will give you serious lag. I had an eBay tmic on my bugeye and i was super slow untill i got the STi TMIC. You should get the grimmspeed air oil separator as well if you want your car to be super reliable and last forever. You should also look into mishimoto a oil coolers as well they work wonders on turbo'd cars.
rburns95 is offline   Reply With Quote
Old 08-01-2013, 04:08 PM   #41
rburns95
Member#: 326731
2002 Impreza WRX
You should put RA gears in your tranny if you are serious trying to pull mid 3s. You will blow the stock bugeye transmission and thatll cost you an arm and a let. Upgraded gears would run you $1500 in parts but would save you later down the road trust me
