Old 07-28-2013, 04:29 PM   #1
kartracing6
Member#: 325196
2002 wrx wagon
black
Default 2002 wrx blown motor?
Hi I was driving my car the other day and when I hit 5000-6000rpm in first it stopped accelerating as fast and started making a loud knocking sound. Does anyone have any ideas what it is? The timing belt is still aligned and there are no metal shavings in the oil pan. It currently starts but barely runs.
http://www.youtube.com/watch?v=C5_nM...ature=youtu.be
here is a link to my startup this afternoon...
any advice would be appreciated, thanks!
kartracing6 is offline   Reply With Quote
Old 07-28-2013, 04:40 PM   #2
Imprzaboy89
Member#: 241311
95L V6WRXSTI type R
HE?RP DERP
This should be good
Imprzaboy89 is offline   Reply With Quote
Old 07-28-2013, 04:46 PM   #3
Frankh21
Member#: 295776
2005 SAAB 9-2x Aero
What oil u running?
Frankh21 is offline   Reply With Quote
Old 07-28-2013, 04:52 PM   #4
kartracing6
Member#: 325196
2002 wrx wagon
black
I was using mobil 1 5w30 synthetic oil. The engine was still full of oil and It had been around 4000-5000km since I last changed it
Old 07-28-2013, 04:53 PM   #5
kartracing6
Member#: 325196
2002 wrx wagon
black
I'm beggining to think it sounds like bad rod bearings
Old 07-28-2013, 05:12 PM   #6
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
Your description certainly does not rule this out.
Old 07-28-2013, 08:50 PM   #7
Frankh21
Member#: 295776
2005 SAAB 9-2x Aero
One more thing, was the car warmed up or cold when you hit 5-6000 rpms.
Old 07-28-2013, 09:22 PM   #8
kartracing6
Member#: 325196
2002 wrx wagon
black
it was at normal operating temperatures
Old 07-28-2013, 09:41 PM   #9
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Another subie motor lost to m1 5w-30...
I would pull your plugs and see if the piston is smashing the heads yet. It sounds really bad...
2gnt2wrx is offline   Reply With Quote
Old 07-28-2013, 11:52 PM   #10
Frankh21
Member#: 295776
2005 SAAB 9-2x Aero
I'd save some money and invest in a new or rebuilt long block.
Old 07-29-2013, 07:50 PM   #11
kartracing6
Member#: 325196
2002 wrx wagon
black
Old 07-29-2013, 10:32 PM   #12
Fir3Fighter
Member#: 316780
2003 Impreza WRX
Its so sad
Fir3Fighter is offline   Reply With Quote
Old 07-30-2013, 08:03 AM   #13
Parpoint
Member#: 359183
2000 Impreza
Green
Been there, and usually it damage a lot of thing other than just the bearings.
So like Frankh21 said, get a new longblock
Parpoint is offline   Reply With Quote
Old 07-30-2013, 10:56 AM   #14
funnky
Member#: 330236
2002 wrx
blue and black
another one bites the dust. an another one and another one bites the dust.
funnky is offline   Reply With Quote
Old 07-30-2013, 11:54 AM   #15
kartracing6
Member#: 325196
2002 wrx wagon
black
Yeah I think I will have to get a new longblock because rebuilding would be too expensive.
Old 07-30-2013, 12:05 PM   #16
rexblake
Member#: 178426
2010 S4
Gray
Make sure you get a new oil cooler. A oil pan and pick up wouldn't be a bad idea either. Otherwise make sure they are super clean before you reuse them.
Old 07-30-2013, 03:18 PM   #17
kartracing6
Member#: 325196
2002 wrx wagon
black
Would I need all that even if it came with the other engine I would buy? Probably would be a good idea either way just to be safe
Old 07-30-2013, 08:15 PM   #18
wrx1392
Member#: 342331
2003 wrx
blue
mobil 5-30 and rod knock .....do a serch ,this is not the first time .dont run the car untill you fix it ...if you rebuild get a new oil cooler ,oil pan,oil pump,and oil pick up . if it's knocking there is metal shaving in your oil and all through the motor.sorry dude rebuild or new motor time . do a serch on mobil oil
wrx1392 is offline   Reply With Quote
Old 07-31-2013, 07:57 AM   #19
bluesubie
Member#: 767
04 FXT
Do not run ANY oil that says Resource Conserving in the API donut on the back of the bottle. If you want to run Mobil1, use the 0W-40 or TDT 5W-40.
This M1 5W-30 analysis showed that the oil sheared to a 20 grade in 2,500 miles.
http://forums.nasioc.com/forums/show....php?t=2527193
-Dennis
Old 07-31-2013, 08:48 AM   #20
kartracing6
Member#: 325196
2002 wrx wagon
black
Yeah I learned that after it was too late...
-Dennis
Thanks for the info, will keep that in mind, I want my new engine to last!
Old 07-31-2013, 09:07 AM   #21
hetkind
Member#: 363611
2013 WRX
Now, are you SURE it was 5-6k in first and not 6-7k in first? It sounds to me like you overspun your engine...
Howard
hetkind is offline   Reply With Quote
Old 07-31-2013, 09:19 AM   #22
kartracing6
Member#: 325196
2002 wrx wagon
black
I think it might have been closer to 6-7k to be completely honest. I have to admit the engine failure was probably mostly my fault...
Edit: I also ordered a new longblock yesterday because I'm pretty sure the engine's toast. Lots of shavings in the oil pan
Old 07-31-2013, 09:46 AM   #23
hetkind
Member#: 363611
2013 WRX
Now, this MIGHT be preaching to the choir, but if you are going to drive this like a RALLY car, you have to MAINTAIN it like a RALLY car. Use a higher viscosity oil, change it more often and DON'T overspin the engine:-)
And if you hear ANY noise from the lower end of the engine, pull the pan and inspect bearings...
I hope the longblock didn't set you back too much, but keep the old engine, take it apart, do a Post Mortem and see what failed and why. I don't know much about Subaru machine shop work, but there is a shop near me that rebuilds Subaru motors when they don't have enough BMW motorcycle work to keep busy.
If the valves didn't hit the piston, repair costs will be much lower.
Howard
Old 07-31-2013, 10:00 AM   #24
kartracing6
Member#: 325196
2002 wrx wagon
black
You're right, I change the oil every 5000km and I thought mobil 1 was a good oil to use but I guess not!
removing the oil pan revealed a fried rod bearing on the big end.
I paid 1300 usd for the engine, all I need from my old one are the exhaust, intercooler, intake, turbo etc.
Old 07-31-2013, 12:19 PM   #25
Scooby2002
Member#: 291441
2004 WRX
1300 for a used engine? Not bad. Mind if I ask where you bought it from?
Scooby2002 is offline   Reply With Quote
