Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
View Poll Results: Which Color do you like?
Gold 278 27.83%
Hyper Silver 130 13.01%
Chronium Black (gunmetal'ish) 340 34.03%
Flat black 225 22.52%
Bronze 130 13.01%
Multiple Choice Poll. Voters: 999. You may not vote on this poll
Old 07-25-2013, 10:58 PM   #6876
Dori Ninja
Member#: 73974
04 RSTi
rim sizing?? *Bunchsta*
Dori Ninja is offline   Reply With Quote
Old 07-25-2013, 10:59 PM   #6877
Kris_JDM
Member#: 326859
02 Impreza OBS
Plasti-Dip Black
Xxr 530 17x9.75 with 235/40-17 Sonar SX1 tires, lowered on Tein S-Techs
Kris_JDM is offline   Reply With Quote
Old 07-25-2013, 11:50 PM   #6878
Bunchsta
Member#: 274015
06 WRX
Obsidian Black Pearl
18.975 +20 offset
@lilbunchy
Bunchsta is offline   Reply With Quote
Old 07-27-2013, 01:32 AM   #6879
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
Hey all just ordered some XXR 531's 18x 9.5 +35 for my 12 wrx... I also ordered some muteki sr48 i was planning to use on my stock wheels, but since these are comming ill waite, do these wheels work with the 60 degree taper? ill post some pics once they come in and installed.
Nighthawkra is offline   Reply With Quote
Old 07-27-2013, 08:31 AM   #6880
gfred024
Member#: 141757
08 Sti
Just to confirm. I have xxr 531 18x9.5 +35. Your gonna need a 10mm spacer to clear the front brembo calipers not a 5mm.
gfred024 is offline   Reply With Quote
Old 07-27-2013, 09:51 AM   #6881
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
I have no brembos
Old 07-27-2013, 10:22 AM   #6882
gfred024
Member#: 141757
08 Sti
Then it doesn't apply to you. Just for future reference.
Old 07-27-2013, 11:07 AM   #6883
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
Care to donate brembos? I'll take all donations
Old 07-27-2013, 11:14 AM   #6884
gfred024
Member#: 141757
08 Sti
Lol no I need them to stop.
Old 07-27-2013, 12:21 PM   #6885
NWsoobie
Member#: 289516
2012 WRX
ISM
If your running 10mm spacers, I hope you are running extended studs.
NWsoobie is offline   Reply With Quote
Old 07-27-2013, 02:23 PM   #6886
Tsujen
Member#: 269643
07 BMW 335i
Monaco Blue
Originally Posted by wrcnick View Post
Have you ever brought your car to the track and raced?
Tsujen is offline   Reply With Quote
Old 07-27-2013, 02:47 PM   #6887
Soobie4life
Member#: 337830
Sorry fellas for bothering. I sold my RS and bought a black wrx. I'm buying any xxrs. Let me know if your selling some. Thanks and once again sorry!
Looking for 9.5 or 9.75 wide xxrs, any kind! Thanks and pm me! :P sorry for the bother again.
Soobie4life is offline   Reply With Quote
Old 07-27-2013, 04:36 PM   #6888
skatin707
Member#: 251552
Chapter/Region: HIIC
2014 FXT
Who said the 9.5 needed a 5mm? It's the x9 that needs 5mm.
skatin707 is offline   Reply With Quote
Old 07-27-2013, 05:27 PM   #6889
gfred024
Member#: 141757
08 Sti
No I just have the lugs bearly on there. Of course I'm running extended studs. And about 40 pages back it says a 5 mm is needed. To avoid confusion. The xxr 531 18x9.5 +35 needs a 10mm spacer to clear the front brembo calipers.
Old 07-27-2013, 05:30 PM   #6890
gfred024
Member#: 141757
08 Sti
They don't even make the xxr 531 in 18x9 not sure what your talking about.
Old 07-27-2013, 05:57 PM   #6891
skatin707
Member#: 251552
2014 FXT
They make them in 17x9 +35
Old 07-28-2013, 04:58 AM   #6892
WRXACY
Member#: 326701
2012 WRX
I just got the XXR 527 18x9.75+20 what size tire should I run I'm stock hight 2012 WRX
WRXACY is offline   Reply With Quote
Old 07-28-2013, 09:32 AM   #6893
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
I'm just going to guess 245 40 18...or what ever the stock sti is.. u might still need to roll rears. But hopefully a pro will chime in
Old 07-28-2013, 09:43 AM   #6894
skatin707
Member#: 251552
2014 FXT
That size will be fine. A roll is definitely recommended. Personally, I'd go with a 255, coils, and a good roll. Wide wheels are great for wide tires
Old 07-28-2013, 08:54 PM   #6895
Jdsti06626
Member#: 310761
0609 Wrx Sti 06/09
Sgm/pear white
Can you do 255/45/18 on stock suspension ? With a roll and pull? And camber? Tomorrow i was going to get 245/40/18 for my 18x9.75+20 but if I can get away with 255 ill do it lol
Jdsti06626 is online now   Reply With Quote
Old 07-28-2013, 08:57 PM   #6896
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
Many run 265 35 18 so I'm sure !
I ordered 255 35 18 with 35 offset though
Old 07-28-2013, 10:48 PM   #6897
J_Maher_WRX
Member#: 290307
You don't want 255/45's... You're going to need serious fender work to get a +20 to work with a 255 tire. A 255/35 would be the correct size, however you're probably gonna have to run a 225 or 235 to get it to fit unless you're willing on doing lots of fender work.
J_Maher_WRX is offline   Reply With Quote
Old 07-28-2013, 10:49 PM   #6898
J_Maher_WRX
Member#: 290307
I have the same size tire, Michelin PSS, on my 527s in 18x8.75 +35.. I rolled my rears flat, figured I may as well while I had the roller, however with a mild roll you'll do fine on stock suspension. If you're lowered you'll probably need a more aggressive roll if not rolled flat like mine.
Old 07-28-2013, 11:33 PM   #6899
skatin707
Member#: 251552
2014 FXT
I'm jealous of the fender space on newer models. My 17x9 +30 wheels with 235/45 tires fit without a roll.
Old 07-29-2013, 05:53 AM   #6900
Austingriff
Member#: 354418
2005 STI
I bought my car about 3 months ago and i still haven't posted a picture of it anywhere other than my instagram, which isn't very cool. I saw this thread and i figured its time to post my car and setup!
2005 White STi on Chromium Black XXR 527's 17's on TeinFlex coil overs (I just went mind blank and forgot my offset) But my offset is pretty crazy. I had like negative 3/4 camber when i first got it, but I had some pretty bad tire wear on the front wheels especially and ended up having to get 2 new tires. I could see the metal through part of the tread. I believe the person i bought the car from didn't rotate the tires as much as they should have but either way the "stance" look causes awkward tire wear.
I got the car realigned when i put the tires on and took the camber off as much as i could. I still couldn't fit my wheels all the way under my car so I'm at like a negative 1 camber still. I definitely felt a huge increase in handling, grip, and over all performance with my new alignment and positive camber, and i know the new tires added to this performance increase but its still a noticeably different feel riding on more of the tire with the positive camber. I love it.
I was thinking about selling my wheels to get wheels with less of an offset and a different look but I'm starting to love my XXR's. Im thinking about painting them flat black though. I think that would look better than the chrome black. But if i top sell em ill be sure to post em on NASIOC's F/S thread and ill mention it in this thread as well to let anyone viewing who might be interested.
Btw, i love all of the cars in this thread! Some great looking scoobs in here on XXR's!
Austingriff is offline   Reply With Quote
Enough of teh Sex threads! Remy E. LeBeau Off-Topic 18 08-19-2013 07:47 PM
teh burn thread Samuelleeogden Off-Topic 13 09-06-2005 08:28 PM
Teh Welcoming Thread.. PwNeD Texas Impreza Club Forum -- TXIC 7 10-06-2004 10:42 AM
