Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
Old 07-25-2013, 10:48 AM   #18551
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by lumpy View Post
I've had the best luck with Kartboys. Tom makes great products and they have supported the Subaru community for a long time
The other option would be seeing if any STi owners are selling their stock endlinks and maybe save a few bucks.
Their end links are the same as ours, I have over 20000 miles on mine with fairly hard cornering and no issues, save your money
Old 07-26-2013, 11:26 AM   #18552
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Is that HD radio only in the navigation unit?
foghelmut is offline   Reply With Quote
Old 07-26-2013, 12:22 PM   #18553
Rememo
Member#: 340728
2013 Impreza 5-spd
The non-nav units with the color screen have HD radio. Some also have satellite radio capability.
Rememo is offline   Reply With Quote
Old 07-27-2013, 01:05 AM   #18554
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
IMG_3075 by Dijm8, on Flickr
Dijm8 is offline   Reply With Quote
Old 07-27-2013, 09:08 PM   #18555
ronjr8102
Member#: 216040
2013 Impreza 2.0i5dr
dark metallic grey
Are those sidemarkers oem or aftermarket?
ronjr8102 is offline   Reply With Quote
Old 07-27-2013, 09:14 PM   #18556
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Its oem, just not available in usdm trims
Old 07-28-2013, 10:01 AM   #18557
ronjr8102
Member#: 216040
dark metallic grey
Does someone have the part numbers for the light and socket so I could order them from somewhere?
I love sidemarkers on cars more than the mirror signals.
Old 07-28-2013, 11:07 AM   #18558
n00b on demand
Member#: 158355
2012 Sport 5MT
Am I doing something wrong? Im trying to jack up the impreza with a 2 1/4 ton floor jack using the pinch welds and Im cranking and cranking and cranking and the tire wont lift off the ground....the body of the car keeps rising.
n00b on demand is offline   Reply With Quote
Old 07-28-2013, 11:20 AM   #18559
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Yes you are. Not lifting high enough or your jack has reached it's max height possibly
gregorz4 is offline   Reply With Quote
Old 07-28-2013, 11:26 AM   #18560
79letour
Member#: 302570
2013 XV
DGM!
The spare jack in the trunk is one of the best, quickest oem jacks I've ever used. I had my rears off my xv with it in <5mins. And it fits the pinch weld perfectly so no worries about bending anything. Not saying at all that its better than a good floor jack- But if you.need to use the spare, it will work better than you'd expect.
Old 07-28-2013, 11:36 AM   #18561
n00b on demand
Member#: 158355
2012 Sport 5MT
Hmm the jack keeps going up and looks like the body of the car does too but no tire off the ground. Seems abnormally long.
Old 07-28-2013, 11:40 AM   #18562
79letour
Member#: 302570
2013 XV
DGM!
May be quicker to use the spare jack then...
Some heavy duty floor jacks just simply dont have a whole lot of lift.
Old 07-28-2013, 02:31 PM   #18563
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
I know people here have done a lot of lowering and a few have done lifting, but I'm curious, has anyone figured out if there is a set of coils that will stiffen up the suspension without lowering the ride height? I'd like to raise it or keep it the same, but the fact is these coils are just ever so slightly too soft. I wonder if perhaps springs from the FR-S or BRZ will fit, or struts for that matter, as they are based on the same general platform with modifications?
Old 07-28-2013, 08:44 PM   #18564
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
^ would love an answer too! I go camping and just a few extra pounds in the hatch really lowers it down. Would love to stiffen that thing up. Maybe even get a small lift out of it.
SIA_worker is offline   Reply With Quote
Old 07-28-2013, 09:15 PM   #18565
myrt1987
Member#: 323103
2012 Limited 2.0i
I agree. I like the scissor jack more then the floor jack. It takes longer but wont slowly leak air, thus lowering the car, or bend the pinch welds.
On a different note, my oil light came on today while driving on the parkway! what gives! I checked the oil and it was fine, almost to the full mark. I added 1/3 quart (maybe less) and light goes away never to return. Son of a....
Old 07-28-2013, 09:31 PM   #18566
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
If you have a floor jack, lift the car by the differentials. The first time I rotated my tires I used the corner lift points, and getting the jack stands in the correct position was a PITA. A couple weeks ago when I rotated my tires again I used the differentials. So much easier. The front took a little work to get started because it's awfully far under from the front, but it was so much easier to place the jack stands.
Xafen is offline   Reply With Quote
Old 07-28-2013, 11:02 PM   #18567
Dirt Bringer
Member#: 340297
Ice Silver
If it's just a lift, Subtle Solutions makes a 1" lift kit that will work on this car, if you hadn't heard yet. You may need an alignment done after that though. I like it's ride height, it feels optimal for what I do, but the springs are just too soft.
Old 07-29-2013, 02:13 PM   #18568
Angelus911
Member#: 89967
2012 Impreza Sport
+1, I was going to post this. Definitely used the diffs to lifts the car with a floor jack. I would only use the pinch welds with the oem lift and only in an emergency.
Also helps to drive up on a couple blocks of woods as well prior to lifting the car - since the Impreza is so low, it makes getting the jack to the diffs a little challenging. Driving up on wood blocks helps a lot
Old 07-29-2013, 02:24 PM   #18569
79letour
Member#: 302570
2013 XV
DGM!
Yeah that wpuld help a LOT!
I've already forgotten how much lower the Impreza is than my new XV.
Man, not needing ramps or a lift to get under it is very nice.
Old 07-29-2013, 02:44 PM   #18570
Xafen
Member#: 306398
Camellia Red
Argh! Why didn't I think of that. All I needed was another 1.5-2" to make the front easy to get the jack under. Thanks! Next time I do any work with it on jack stands I'll run the front up on a couple 2x4's before jacking it up.
Old 07-29-2013, 03:44 PM   #18571
nubsub
Member#: 313575
2012 Impreza 2.0i HB
yep, 2x4's are all you need. i found a couple of scrap 2x6s and that's all i needed to get enough clearance to do my oil changes. the extra 1 5/8" is the right amount to make life easier.
Old 07-30-2013, 01:53 PM   #18572
fistv
Member#: 350063
2013 Impreza sport
Couple of 2x10's angle cut and nailed together and you can get it a bit higher, put a screen door pull handle topside end to carry and to act as a wheel stop, find someone building a deck and get some scraps.
fistv is offline   Reply With Quote
Old 07-30-2013, 02:35 PM   #18573
79letour
Member#: 302570
2013 XV
DGM!
I went to home depot and had some 2x10's cut so I could get a little extra clearance.
Old 07-30-2013, 04:25 PM   #18574
swede978
Member#: 89233
99 RS Aspen White
2014 Outback SWP
http://allwelldrive.blogspot.com/201...-from-brz.html
Has anyone seen this done? I am looking at doing this to mine.
swede978 is offline   Reply With Quote
Old 07-30-2013, 06:32 PM   #18575
imcausinmadrukis
Member#: 318978
My brake light went out yesterday.
Does anyone know the replacement bulb model?
imcausinmadrukis is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
