Old 07-29-2013, 12:55 AM   #1
Lets Bugi
Member#: 353466
Default Bent Valves?
I drive a 2003 WRX. no mods other than a cat back. a couple weeks ago a heard a noise coming from my timing belt so I took it home immediately. The next day I changed the... Nevermind, long story short, I took it too a shop and there was a bolt restricting the tensioner from tensioning. Driving away from the shop it wasn't the same. loud tick and loss of power at about 4000 rpm up until about 5500. At about 5500 it felt as if vtec kicked in and it felt normal. So I assumed the belt slipped and I had bent valves. tore it all down too look and they all look fine. Should they be noticeably bent or can a small unnoticeable bend do what I am explaining? Is there something else a should check out? Any input is greatly appreciated! thanks
Lets Bugi is offline   Reply With Quote
Old 07-29-2013, 06:40 PM   #2
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
You tore an engine down before doing a basic compression test???? Wow.......
boosted25 is offline   Reply With Quote
Old 07-31-2013, 01:45 AM   #3
Lets Bugi
Member#: 353466
It was at about 100-110 all around. They are bent.. Just subtly.
Old 07-31-2013, 04:59 AM   #4
Gamble_WRX
Member#: 234783
2004 STi
Stick them in a power drill. (dont mar them up) and spin them. thats how i tell if theyre bent.
Gamble_WRX is offline   Reply With Quote
Old 07-31-2013, 12:20 PM   #5
czwalga
Member#: 349787
I've done this before works pretty well.
czwalga is offline   Reply With Quote
