Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 07-28-2013, 06:56 PM   #1
MikeC5
Member#: 104702
95 Legacy
Green
Default Misfire Codes
My '02 2.5L is throwing occasional misfire codes. I did go through the FAQ and read through several threads on this issue but many of them don't have a resolution of the problem posted.
About 2 months ago I replaced head gaskets (Six Star) and replaced all gaskets/seals, plug wires and plugs while engine was out. A few days after it was back on the road I got a cel for P0301. I cleared it and it has been O.K. for the last 2 months. Engine light comes on the other day and I'm getting P0301, 2, 3 and 4 plus pending on 1 and 2. The car seems to run fine, idles fine, gas mileage is around 25 mpg which is what it usually is... WTF?
I never saw any misfires before doing HG (in 70K miles that I've owned it). I did adjust valves while heads were off and cleaned up the piston tops and combustion chambers....
I plan to pull the plugs next and see if they look funny.
MikeC5 is offline   Reply With Quote
Old 07-30-2013, 12:26 PM   #2
MikeC5
Member#: 104702
95 Legacy
Green
Pulled the plugs and they looked fine. They are new AC plugs, not NGK and are just plain old single electrode plugs (which had never previously been a problem). The gap was right at 1 mm. I will admit to using Autozone for replacement plug wires (Bosch, I think). I replaced the fuel filter while under there and cleaned up engine/firewall grounds, no obvious vacuum leaks. I tried misting water on the coil pack while running at night and saw no arcing. Driving it to work this morning (40 miles) it ran fine but I did see engine light come on for maybe a second and then off. I read that a blinking light could mean damaging misfires but wouldn't the light eventually stay on?
Old 07-30-2013, 07:32 PM   #3
MikeC5
Member#: 104702
95 Legacy
Green
Light stayed on this afternoon.. Misfire on all 4 plus a pending 0420. You guys are really a great help...
Old 07-31-2013, 01:37 AM   #4
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
You are having misfires on all cylinders? I am thinking any of the following to check or check again:
Spark plugs (get some ngk)
Coil
Injectors
Check resistance on plug wires
Are your battery terminals clean and tight?
rhino6303 is offline   Reply With Quote
Old 07-31-2013, 05:49 AM   #5
MikeC5
Member#: 104702
95 Legacy
Green
What should resistance on plug wires be? For the coil, I can swap it out for another one. I don't think there would be much point doing reistance checks since the problem is intermittent (and car starts & runs fine). Battery connections are good. Since this only started happening after an HG and clutch job (engine removed) with new plugs & wires, I'm hoping it is one of the latter two...
Old 07-31-2013, 05:37 PM   #6
MikeC5
Member#: 104702
95 Legacy
Green
The Bosch plug wires measure around 800 ohms and the manual says they should be between (roughly) 5k to 12K ohms. I checked one on our other Outback and it measured around 2.5k (non-OEM). I did go ahead and swap the coil with one that I knew worked when removed. We'll see. I may have to bite the bullet and get some NGKs and OEM wires...
