Old 07-30-2013, 05:19 PM   #1
subie.wrex
Member#: 326689
2004 Impreza WRX
Default 2.5 sohc replacement engine
Picked up an 01 legacy with a blown motor. Replaced the motor with exact same block and heads from same year legacy. Any chance the ecu needs to go with the new engine? Not getting any spark due to the ecu not reading cam and crank sensors right or could be something else too. Replaced both sensors. Checked all grounds, everything looks great. Engine cranks and gets fuel but will not spark. New plugs and wires. Coil pack is fine. Any input is great.
subie.wrex is offline   Reply With Quote
Old 07-30-2013, 06:28 PM   #2
JoeBowHunter
Member#: 359083
2012 WRX Hatchback
Dark grey
Im not too sure but I would get out the ol multi meter and go digging.
JoeBowHunter is offline   Reply With Quote
Old 07-30-2013, 06:46 PM   #3
subie.wrex
Member#: 326689
2004 Impreza WRX
I have tested everything i could possibly test. Some funky readings. Delayed spark makes me think the ecu in the car is not reading the sensors right.
Old 07-31-2013, 08:02 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Do you still have the old engine? When I've done engine swaps, I've re-used the old intake manifold (with wiring harness, fuel injectors, and sensors attached) on the "new" engine. That way all the stuff I knew was good I kept.
Old 07-31-2013, 01:07 PM   #5
subie.wrex
Member#: 326689
2004 Impreza WRX
Yes i have. And i did end up getting the ecu out of the car i took the engine from. Still nothing! And everything checks out
Old 07-31-2013, 10:08 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Well, that sucks.
Old 08-01-2013, 07:20 AM   #7
subie.wrex
Member#: 326689
2004 Impreza WRX
Well, that sucks.
Looks like the timing belt jumped a few teeth.
Old 08-01-2013, 07:20 AM   #8
subie.wrex
Member#: 326689
2004 Impreza WRX
Got it running though. All set
Old 08-01-2013, 08:08 AM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Well, that doesn't suck.
