Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 04-05-2013, 08:49 AM   #426
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I think I stuck a huge wire nut on there and used old fashion electrical tape on top of that for that gob of wires.
BWX is offline   Reply With Quote
Old 04-05-2013, 09:39 AM   #427
foolycooly
Member#: 260545
2011 WRX Limited 4dr
Originally Posted by SVXdc View Post
The wire twist looks OK. But you need to think ahead on how the heat shrink will work. (hint -- you'll want to pre-position the HS tube so that you can slide it over the junction after you've soldered it.
So in your picture, the tube at the bottom won't work.
You want a tube around the two wires at the upper-left. Or change the tube at the bottom to include the wire going off to the right.
Slide the HS far enough away so that it doesn't start shrinking while you're soldering.
Here's a good guide I found on how to twist and solder wires together:
http://www.whoolie.com/solder.htm
To join more than 2, start with the first two as shown there, and then spiral each additional wire around the initial junction, ending up with all wires parallel. Remember to slide heat shrink over all of the wires on one side before you start. Then solder the whole set together at one time.
Thanks for the tips--very helpful. I did my best to do it the way you describe. I started with the large ground from the pioneer harness and twisted it parallel with the black ground from your harness. I then weaved the other 3 wires into place around that connection. It was kind of hard to not have smalls stands separate by the time I got to the 5th wire though.
The wire that looks like it will make the heatshrink not work is not in its final position in this picture--I just moved it there to better show the 5-way connection. It is the ground from the solid state bypass and it's going to move up to the left so that it's parallel with the rest of the wires (some of the insulated wire will be in the heatshrink...I hope that's not an issue). I chose a larger tube size for this junction and I think I will be able to get it over the connection after soldering. There is also more room to the bottom right to slide the tube out of the way. I'll take more pictures after i start soldering.
foolycooly is offline   Reply With Quote
Old 04-05-2013, 05:22 PM   #428
foolycooly
Member#: 260545
I will probably start my own thread, but I wanted to update my previous post with a couple of pictures. SVXdc's guides are as good as they get, but I think pictures like these would have helped a first timer like myself visualize everything.
I got all of the "dry" connections done while I wait for my soldering iron to arrive on Monday. There are 4 "items" that need to be connected in one way or another. The orientation in the picture below is as follows:
1. Upper-left: Axxess ASWC-1 (purchased from SVXdc)
2. Left: Pioneer Harness (comes with the head unit)
3. Right: 20-pin forward harness (purchased from SVXdc)
4. Lower-right: Parking brake bypass (purchased on ebay)
I cleaned up the 5-way ground connection a little bit:
Parking brake bypass' orientation and heatshrink. The white harness on the bottom is SVXdc's 20-pin forward.
A lot of unused wires from the ASWC-1:
I stripped an extra 1/4 - 1/2" from most of the wires. This seemed to make the twisting connections easier, but I'm sure it will leave me with a lot more soldering to do.
A couple of questions:
This is how I wired the parking brake wire from the pioneer harness to the bypass (it came with the red clamp pictured above by default). I figured I would leave most of the wire intact in case I needed to run it in a legit way to my parking brake for some reason. Am I better off shortening this so it goes straight from the pioneer harness to the bypass?
Lastly, I leave these two wires disconnected correct?
Thanks.
Old 04-05-2013, 06:05 PM   #429
freddyo_0
Member#: 339277
2011 WRX STI Limited
1. I'd say closer to the harness but not by much
2. You can leave those two unused unless you would like to do as others and install a rear view camera for parking.
I ended up reusing the parking brake wire and repurposed most of it for reverse gear sensing and left a decent amount for the bypass.
freddyo_0 is offline   Reply With Quote
Old 04-09-2013, 03:22 PM   #430
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Can anyone confirm the newer Pioneer HU's work with both the SirusXm unit installed along with the Axxess control units?
The Pioneer AVH-X 3500 and similar units are having issues running both things simaltaneously. http://www.amazon.com/Pioneer-AVH-X3...owViewpoints=0
I'd really like to pick one of these up but am afraid this issue won't be resolved.
Not-EWRX is offline   Reply With Quote
Old 04-12-2013, 11:43 PM   #431
foolycooly
Member#: 260545
Finally had time to complete my harness and I'm going to install my AVH-X5500BHS tomorrow.
I assume that the new harness will connect to the factory harness and no other connections from the old head unit will connect to the new unit? In other words, I know that there will be multiple other items to disconnect from the back of the stock unit (stock BT mic, etc.). None of these will plug into the new pioneer, correct?
Old 04-13-2013, 07:49 AM   #432
freddyo_0
Member#: 339277
http://ae64.com/20-pinfwdharness.htm
Old 04-13-2013, 10:59 AM   #433
foolycooly
Member#: 260545
Originally Posted by freddyo_0 View Post
Sorry, I must have misphrased my question. I already have all of the necessary harnesses (including the one you linked) all soldered up and ready to go. I just wanted to confirm that this new completed harness will be the only thing that will be connected to the factory wiring. The other factory connections will just be left loose behind the new unit.
Old 04-13-2013, 01:35 PM   #434
Not-EWRX
Member#: 158043
2013 Wrx Hatch
I ordered the X5500BHS with the Axxess-1 and Sirus all from amazon. We'll see if the problem with the combo working together is present. If so, it's going back and I'm back to the drawing board.
I have a love hate relationship with pioneer. They do some awesome stuff, but they also make incredibly stupid decisions at times. My home receiver is awesome but even an engineer (me) struggles to use it.
Old 04-13-2013, 02:23 PM   #435
foolycooly
Member#: 260545
EDIT: Erm, wow. It would help if I plugged the antenna wire into the back of the new unit--Nevermind!
Old 07-03-2013, 01:28 PM   #436
tnguyen600
Member#: 284699
2013 Impreza WRX STi
Does/did anyone have issues with their Pandora? The icon doesnt show up on the drop down anymore and it isn't highlighted on the home screen.
Any advice?
tnguyen600 is offline   Reply With Quote
Old 08-01-2013, 12:01 PM   #437
CamaroSS
Member#: 30626
2015 STI Base LR
1999 Miata Track Car
Can anyone send me the original bluetooth firmware for the AVH-P4400BH? I had an iPhone so I updated the firmware. I now have a Galaxy S4 and once again the metadata does not display via bluetooth. I assume I need to revert back to the original firmware, but I don't have a copy and can't find it on the net.
CamaroSS is offline   Reply With Quote
Old 08-01-2013, 12:05 PM   #438
CamaroSS
Member#: 30626
2015 STI Base LR
Never mind. Pioneer support just told me that it is impossible to roll the firmware back. So... that SUCKS.
Old 08-01-2013, 02:01 PM   #439
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
What version android? 4.2.x doesn't send it
flyboy1100 is online now   Reply With Quote
Old 08-01-2013, 02:14 PM   #440
CamaroSS
Member#: 30626
2015 STI Base LR
It is 4.2.2. Bummer. Oh well...
Old 08-01-2013, 05:37 PM   #441
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I don't understand why they can't fix it
Old 08-01-2013, 05:52 PM   #442
CamaroSS
Member#: 30626
2015 STI Base LR
He said there was no way to roll the firmware back. I asked if copying the original firmware files back to the unit woupd work and he said no. The only way it will work now is if the updated format is used by my S4.
Old 08-01-2013, 06:07 PM   #443
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
It isn't the s4, afaik they broke that feature in 4.2 and have not fixed it yet. I just don't understand exactly what they did because it worked in pretty much every android version until 4.2
Old 08-11-2013, 12:52 PM   #444
schacal06
Member#: 339093
2013 SUBARU
RALLY BLUE
* Samsung adapter EPL-FU10BEBSTD is required (sold separately), in addition to the Pioneer CD-AH200C Android interface cable kit (sold separately). Visit www.samsung.com, an authorized Samsung dealer, or call 800-757-0280 for more information.
Note: OS versions are for final consumer OS releases only, and do not apply to developer versions or unofficial releases. Only the above devices and OS versions have been tested with AppRadio. Devices and OS versions not listed above should not be used with AppRadio
**i just read that this is needed for some pioneer indash has anyone test it out?**
schacal06 is online now   Reply With Quote
Old 10-15-2013, 01:54 AM   #445
nykid4202002
Member#: 359893
Default Aswc-1
Ok so I have a 440bh as we'll and have the aswc-1 hooked up wiring is triple checked volume up down track up down the mode button is an ATT no Bluetooth buttons and the very bottom voice activation button also does ATT any ideas this thing is driving me batty
nykid4202002 is offline   Reply With Quote
Old 10-15-2013, 01:59 AM   #446
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
The ASWC-1 may need a firmware update. What version does it have? (see last 3 digits of long number on the sticker before the date)
Old 01-29-2014, 12:59 PM   #447
OUTAGAS
Member#: 378302
2014 WRX
Pearl White
Bringing this thread back for a question. Can someone confirm that all the steering wheel controls work? on hook/off hook, voice control, volume up/ down, and channel and mode select? Thanks.
OUTAGAS is offline   Reply With Quote
Old 01-29-2014, 01:09 PM   #448
slowhat
Member#: 304175
2012 WRX Limited
PBP
on hook/off hook yes
voice control no (programmed mine for "ATT" mode)
volume up/ down yes
channel yes
mode yes
slowhat is offline   Reply With Quote
Old 01-30-2014, 04:28 PM   #449
trancehead
Member#: 378808
2014 WRX Hatch
I've been talking to Crutchfield to see what I can do with my 2014 Hatch. Since they don't have access to one they can't confirm that the SB-K926 In-dash Receiver Kit that works with the 2013 will work with a 2014. Can anyone confirm that it will fit?
trancehead is offline   Reply With Quote
Old 01-30-2014, 04:48 PM   #450
slowhat
Member#: 304175
2012 WRX Limited
PBP
isn't the 2014 the same as the 2011-2013? doubt there's any difference.
Clutch "clicking" in 2012 wrx STIDAWG Transmission (AT/MT) & Driveline 7 03-17-2013 12:22 AM
Where to ground in 2012 wrx hatch? slowhat Car Audio, Video & Security 3 02-25-2012 12:35 AM
pioneer avh-p4000 install in 06sti nation1979 Car Audio, Video & Security 25 02-26-2009 02:47 AM
Pictures of Hid's installed in '02 WRX :) paultg New England Impreza Club Forum -- NESIC 7 12-16-2001 05:22 PM
Found out a short throw shifter wasn't installed in my WRX.. cout Bay Area Impreza Club Forum -- BAIC 5 05-03-2001 06:59 PM
