Old 08-02-2013, 08:32 AM   #601
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
That looks like the one that I got. It should work pretty good.
JourdanWithaU is online now   Reply With Quote
Old 08-02-2013, 08:43 AM   #602
swanny094
Member#: 296318
06 2.5i Wagon
Obsidian Black Pearl
Okay I'll post pictures of it when I'm all done installing it!
swanny094 is offline   Reply With Quote
Old 08-02-2013, 09:36 AM   #603
swanny094
Member#: 296318
06 2.5i Wagon
Where can I pick up hump couplers? Hardware store?
Old 08-02-2013, 12:18 PM   #604
Bubakanush
Member#: 209975
2016 WRX
LBP
You can try at a local store for the hump couplers, but I got mine from siliconeintakes.com. The local pep boys sells them but for like $22 versus like $11 on that site.
Bubakanush is offline   Reply With Quote
Old 08-22-2013, 04:15 PM   #605
horsetrailer22
Member#: 362782
2010 Impreza 2.5i
For those of you who have had this install for awhile are there any negatives to the hybrid intake?
horsetrailer22 is offline   Reply With Quote
Old 08-22-2013, 04:44 PM   #606
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
My experience: Increased intake noise, noticeable loss of low down torque.
NH8991 is offline   Reply With Quote
Old 08-22-2013, 05:05 PM   #607
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
After resetting the ecu by disconnecting the battery I had all the same characteristics as everyone else. Such as: car wouldn't idle and shut off, low down torque was non existent, etc. After a few days of driving it, the maf rescaled and it drives significantly better. It idles normally, I have no torque loss on lower rpms. I actually notice a slight increase in power (butt dyno) in mid to higher rpms. My mpg's have also increased by 0.5 miles.
Old 08-22-2013, 05:20 PM   #608
horsetrailer22
Member#: 362782
2010 Impreza 2.5i
Idle issues are that common after these installs...?
Old 08-22-2013, 06:39 PM   #609
Thesystem3
Member#: 233014
2008 Impreza Hatch
my car idles very low with it, and it almost sounds like a very low volume diesel idle lol
Thesystem3 is offline   Reply With Quote
Old 08-22-2013, 07:15 PM   #610
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Ive heard of at least a few people having them. It occurs every time I had to disconnect my battery, but after a day or two the maf adjusts to it as well.
Seriously!
Old 08-22-2013, 09:45 PM   #611
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
It shouldn't do that, check for leaks.
It's updating the long term fuel trims, which is not a good sign. Check for leaks and clean the MAF sensor with the proper cleaner.
Old 08-23-2013, 11:46 AM   #612
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Care to explain why it's not good or have a link to where you probably stated this before?
Old 08-23-2013, 01:54 PM   #613
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The MAF scaling should be right so that there's no significant long term fuel trims. If you reset the ECU and things change, that means the post-reset values (all zeros) are enough different than the needed values that you can actually feel the difference. That's a bad thing. The stock MAF scaling is bad, but it's not feel-a-bly bad. So, you've either got an air leak somewhere or your MAF sensor is dirty.
Old 10-10-2013, 01:55 PM   #614
KensImpreza
Member#: 201077
2015 WRX
So what intake are people having the most luck with. Trying to make my way reading all these pages and it seems since the OP intake is no longer available? what else worked good for other people? Mine would be going on an 2008 2.5i
KensImpreza is offline   Reply With Quote
Old 10-11-2013, 12:15 AM   #615
Turnyface
Member#: 330036
2014 WRX Hatch
Buy a wrx
Turnyface is offline   Reply With Quote
Old 10-11-2013, 02:29 AM   #616
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Maybe if you read the thread you would find some answers...
Old 10-11-2013, 02:44 AM   #617
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
What you say?!?! This is NASTYSHACK, no one reads threads here!
Old 10-11-2013, 02:06 PM   #618
ScubyPhilly
Member#: 213303
2009 Impreza 2.5i
Or maybe just go back a page or two, because this question is being answered over and over again...
ScubyPhilly is offline   Reply With Quote
Old 10-11-2013, 02:09 PM   #619
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You think this one is bad, look at the repetition in the original thread about this problem. I think there's over 5000 posts in it now and maaaaybe 20 of them have actual new information. I got so fed up I've taken to answering people with post numbers so they have to go look at the first time we talked about their issue
Old 10-12-2013, 02:31 AM   #620
KensImpreza
Member#: 201077
2015 WRX
Originally Posted by Turnyface View Post
Buy a wrx
Would be nice if I could afford one. You work with what you got
Old 10-12-2013, 02:33 AM   #621
KensImpreza
Member#: 201077
2015 WRX
I read 13 pages worth of this thread and all the links were to eBay searches not specific intakes. Also I asked what worked best because I did take in what I read and there was a mix of systems using the original air box and the whole discussion of mafv recalibration. So maybe if people weren't such jerks about it....
Old 10-12-2013, 04:04 AM   #622
theoutbackdream
Member#: 301179
2013 WRX Limited
If you arent joking please gtfo.
Old 01-26-2014, 01:56 PM   #623
Npalowitch
Member#: 363366
2010 Impreza
SSM
Maybe you've forgotten what was posted here or haven't checked back recently, but he's right. I just got my Subaru and just found this info. I literally read every single post in this entire thread. All the info is old and the links are all dead. The ones that do work are out of stock. Most of the pictures posted dont show up either, adding to the confusion. The more posts you read the more controversy there is about this install.
So he's probably not joking because he's totally correct.
Npalowitch is offline   Reply With Quote
Old 01-26-2014, 02:01 PM   #624
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Speaking as the guy who invented the damned thing, there's only controversy because people are ****ing idiots. Read the real post about the problem. There's a picture there (that won't ever go away) of what you need to achieve. Order anything you can find that will allow you to achieve that. End of story.
Old 01-27-2014, 04:03 AM   #625
theoutbackdream
Member#: 301179
2013 WRX Limited
Hmm, maybe if you look at when I posted that, that was almost 3 months ago. Not to mention, you should read more carefully as I had no issues coming up with the configuration and got all the information needed. So don't come blaming me when you noobs can't read.
Sure, there are issues that go along with the install, but then again, this is a DIY thing. If you can't even Do It Yourself, you should read carefully.
Edit:
You might be an idiot. I just went through the first page again, and found ALL the information needed.
+1
Cold Air Intake on 2008 2.5i AlexU Newbies & FAQs 12 04-22-2012 12:48 PM
Hybrid intakes for the 2.5i '08+ Rotten Tomato Normally Aspirated Powertrain 2 03-10-2010 09:57 PM
87 octane ECONO / STG1 maps and agressive throttle mapping for 2008 2.5i. Rallitek.com Normally Aspirated Powertrain 0 09-15-2009 02:47 PM
Floor LED usable for 2008 2.5i???? jbd0419 Interior & Exterior Modification 4 02-22-2009 10:14 PM
Maintenance Interval Question for 2008 2.5i c-four Impreza Forum 5 07-11-2008 09:54 PM
