Old 07-28-2013, 02:42 PM   #1
silver_echo
Member#: 241296
2002 wrx
aspen white
Default Help with a 2.5 na.
So, vehicle is a 96 legacy wagon, 2.5 quad cam, auto.
Symptom is large hesitation/miss with throttle input at the level to hold speed in a parking lot(~10-15mph). Also, engine is sluggish below 3k rpm.
Codes thrown: map sensor range/performance, catalyst efficiency below threshold, o2 sensor circuit.
Checked cats at local muffler shop, cats are good.
Swapped out map sensor with another one from local wrecking yard(watched live data stream after swapping, functions normal).
History of vehicle: unknown before about 5k ago(purchased with ~220k). Since then, head gaskets replaced with full timing kit, plugs, wires, air filter, pcv valve, tranny work, burned valves replaced, replaced front brakes after caliper slide seized, new fuel filter.
Only other issue known at this time is a minor oil leak from oil cooler.
Any help/knowledge would be appreciated.
silver_echo is offline   Reply With Quote
Old 07-28-2013, 04:15 PM   #2
silver_echo
Member#: 241296
2002 wrx
aspen white
Symptom is not present during cold start warm up.
Old 08-01-2013, 02:03 PM   #3
Mr_Furious
Member#: 298713
1997 Impreza, Wagon
did you change the o2 sensor?
if it's shot when you are in closed loop (low throttle) it will send really erratic signals to the ecu and it will run rich lean rich lean and be gutless.
I had a similar problem and only really saw it after I installed a wideband and guage
Mr_Furious is offline   Reply With Quote
Old 08-02-2013, 02:03 AM   #4
silver_echo
Member#: 241296
2002 wrx
aspen white
I will try it. Found main engine ground wire grounded out to egr tube. Issue got much better. Still just barely there, but a much smaller window of the throttle, and not as bad anymore. Think maybe sensor was damaged by fluctuating power levels.
Old 08-02-2013, 04:38 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
try cleaning ALL of the grounds to the engine and see if that also helps.
yarrgh is offline   Reply With Quote
