Old 07-24-2013, 07:59 PM   #1
Pickler
Member#: 301247
09 Impreza 2.5i MT
Default please help, engine knocks bad at ~2500rpm
Hi guys I have a 2009 impreza 2.5i auto with only 40k miles on it. I do all the service and maintenance regularly including Spark plugs (ngk laser platinum). Anyway according to my logs engine knocks bad between 2000-3000rpm under heavy load (full throttle). So much so that IAM drops to zero and engine pulls as much timing as possible which often leads to poor low end power (more like non existent power). BUT I don't hear any knocks or pings. Once I had bad gas in there and I heard some pinging but after that no more. Even still my car pulls timing and reports knocks. my car does have a noisy heatshield/exhaust at low RPMs in hot weather. Am I a victim of false knock? I use premium gas only and car is stock.
Pickler is offline   Reply With Quote
Old 07-25-2013, 11:18 PM   #2
Pickler
Member#: 301247
09 Impreza 2.5i MT
bump...
Old 07-26-2013, 02:58 AM   #3
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
You're still under warranty, so I'm going to say take it to a dealer.
Old 07-26-2013, 07:11 AM   #4
Pickler
Member#: 301247
09 Impreza 2.5i MT
will the dealership accept data logs? how am I going to prove knocking if its not audible?
Old 07-26-2013, 08:39 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Tell them you can feel the car hesitating, like it's pulling timing around 2500rpm.
Have you datalogged any other, similar cars to see how they behave?
Old 07-26-2013, 08:58 AM   #6
Pickler
Member#: 301247
09 Impreza 2.5i MT
yes but that was an acura. it had no issues with knocks despite 15 psi of boost and it built timing slowly but gradually up to redline (no dips or spikes in timing). this car I have been feeling hesitations at 2500 rpm for years. just didnt know what was wrong with it until I got a tactrix cable, and notice knock retards at those exact engine speeds. Dealership always claims the car is fine. This morning on the drive to work while climbing a small hill at 2500rpm timing dropped to 0 degrees. This was with a rich AFR mixture too.
Old 07-26-2013, 09:34 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I think you missed the bit about "similar" - an Acura with an aftermarket turbo setup is not similar to your N/A 2.5i.
So, let me be more specific - have you datalogged another N/A Subaru?
Old 07-26-2013, 09:45 AM   #8
Pickler
Member#: 301247
09 Impreza 2.5i MT
oh sorry but thats why i said 'but' it was an acura lol. and it was factory turbo just over boosted (rdx). I have never seen logs of other NA subarus. seen plenty of turbo subaru logs though. I actually would love to see a log of na subarus on pump gas doing some pulls.
Old 07-26-2013, 09:49 AM   #9
skyx39
Member#: 342299
They can read the ECU and see that the IAM has dropped and any learned knock correction values. They won't need your datalogs if it has been knocking that much.
skyx39 is offline   Reply With Quote
Old 07-27-2013, 11:24 AM   #10
Pickler
Member#: 301247
09 Impreza 2.5i MT
well I just took it to dealer and they dont know what im talking about when I mentioned the IAM.
Old 07-27-2013, 12:43 PM   #11
skyx39
Member#: 342299
They might use a different acronym, but they'll be able to tell of the timing is consistently being pulled. If they seem confused find a new dealer.
Old 07-27-2013, 01:54 PM   #12
Pickler
Member#: 301247
09 Impreza 2.5i MT
that's what i'm doing, i'm looking for a new dealership but there are not much around here. They took my car for a drive and came back saying no knock was present. Went home, hooked up my data logger and instantly read that IAM was at 0.
Old 08-01-2013, 04:14 PM   #13
djemzine
Member#: 361609
2015 WRX CVT
WRB Pearl
Not to worry I am in the same boat, and you can use my car by testing it out with the data logger.
djemzine is offline   Reply With Quote
Old 08-01-2013, 11:41 PM   #14
Pickler
Member#: 301247
09 Impreza 2.5i MT
well i told you yours doesn't ping! nice meeting you today
Old 08-02-2013, 05:18 PM   #15
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
As i've mentioned in other threads, i'm a big advocate of running higher octane gas (at least in my car - 09 2.5i 4EAT), running 89 or 91 (even when it was stock) certainly smoothed out the lumpy feeling it had at low revs under high load (e.g uphill in top gear). I wasn't logging the car back then so I can't comment whether it was pulling timing or not.
Even if you are stock, I definitely recommend getting a tune.
NH8991 is offline   Reply With Quote
