Old 12-12-2012, 01:53 PM   #76
rotian28
Member#: 259164
2003 WRX Wagon
The things that stops me from directly placing my n7 into the dash are these.
1. tethering (iphone:n7) certain apps don't recognize the Bluetooth tether mainly pandora radio app. which is my go to app for music in the car. it does play spotify radio, have not tried other apps yet.
2. Hot/Cold. I live in the northeast where temps can range inside the car from 120+ to -20 very easily. I dont think the n7 will be able to handle the extreme cold or heat. especially the heat.
i love n7 and this setup.
rotian28 is offline   Reply With Quote
Old 12-12-2012, 02:13 PM   #77
luan87us
Member#: 335013
2013 Premium WRX 5dr
Originally Posted by jcolomde View Post
I'll have to find out if ALL the settings get saved on to the ecu.
It is saved on the ECU once you flashed it. There is no need to keep the AP plugged into the OBD gate all the time.
If you go on youtube and look up a show call "Amplified". They have some cool idea to mount tablets into the dash without it staying there permanently.
Old 12-12-2012, 09:01 PM   #78
semiv6
Member#: 340346
2002 wrx
rally blue
awesomeeeeeeee
semiv6 is offline   Reply With Quote
Old 12-13-2012, 04:23 PM   #79
ElectroFetish
Member#: 340533
2013 Impreza Sport
Pearl white
Default awesome!
This is so cool. Never would've thought of that! I'm guessing you just have all your music stored on your nexus? Or are you tethering a connection of some sort and using google play? what if you need to take the tablet out? easily removable? this is great, kudos.
ElectroFetish is offline   Reply With Quote
Old 12-15-2012, 01:21 PM   #80
black thunder
Member#: 210047
im a scooby guru
really
sorry havent been keeping up with this thread
watchespn app ftw?
Originally Posted by konradlip View Post
I love this post. I'm going to do something similar to this. I really don't want to use a radio since it will be an extra battery drainage. I found that a Clarion Equalizer does the job even better than a radio since it have 7v outputs and I don't even use the radio. A good place to mount it will be where the cup holder is. Also to make it look more fancy i would trim the radio bezel so you can see the whole black glass screen of the nexus. This would also bring it closer. I do have a question about the wiring tho. How it the battery holding up? Did the nexus die on you yet?
battery will last a good 4-5 days on normal everyday usage (to and from work) which usually means tethering for music. but as of lately ive stored songs on my tablet through spotify
Is that app accurate? how does it get the readings?
from my experience the app is not that accurate especially with the slow refresh rate. kind of cool to show people but i prefer real gauges. it uses a bluetooth obd2 adapter.
spotify is all stored on the nexus. everything else is streamed and tethered to my phone. tablet is pretty easy to take out. takes like 10 sec
i think the nexus will fair pretty well in extreme temps. i used to have a ipod mounted permanently in my car and it used to face some really extreme cold and hot weather conditions (as much as VA would allow) and it never skipped a beat. i hope the nexus will do the same but im in southern california now so i think ill be ok
black thunder is offline   Reply With Quote
Old 12-20-2012, 01:00 PM   #81
Chunks
Member#: 42499
The app is getting data from the ECU.... it's accurate, however it has a refresh rate of around 300ms.
To say it is inaccurate is simply not true.
Chunks is offline   Reply With Quote
Old 12-20-2012, 04:08 PM   #82
black thunder
Member#: 210047
im a scooby guru
really
thats what i meant. either way its cool but not worth depending on
Old 12-20-2012, 09:40 PM   #83
gundamz2001
Member#: 341198
Do you leave the OBD reader plugged in ? I just got one, was gonna plug/unplug it everytime, but I don't want to ruin the connector.
gundamz2001 is offline   Reply With Quote
Old 12-20-2012, 11:27 PM   #84
black thunder
Member#: 210047
im a scooby guru
really
yea. doesnt get in the way, for me at least.
Old 12-21-2012, 04:09 PM   #85
luan87us
Member#: 335013
wow even the Bluetooth OBD II dongle still takes that long? I was expecting delays but 300ms is a very long delay lol. I was hoping somethign in the double digit at the most.
Old 12-30-2012, 01:32 AM   #86
brasstacks
Member#: 321391
Hmm.. Is there anyway to move the N7 down at all? The position it is in now would bug me to no end!
brasstacks is offline   Reply With Quote
Old 01-03-2013, 03:36 PM   #87
kevinb721
Member#: 188314
wrb
i dont think you can charge and use a usb otg cable for external storage at the same time...its one or the other (unfortunatly). i have a 1TB external drive i would love to use along with this idea. ive been trying to do something like this for a long time. started out with an old laptop running android and a single din flip out VGA screen...was a messy install didnt look professional. love this idea, might start it in the spring. thanks for the thread
kevinb721 is offline   Reply With Quote
Old 01-03-2013, 09:51 PM   #88
Andrew025
Member#: 303408
04 STi
Certain kernels support charging and otg.
Andrew025 is online now   Reply With Quote
Old 02-13-2013, 12:08 PM   #89
davetsbass
Member#: 169729
2002 a6 2.7t
Awesome install. I literally just did the same thing with a Kindle Fire using tetherGPS. My HU is in the glovebox like yours, but I'm looking to mount it somewhere else in the near future as my glovebox handle has been broken for years and it takes two hands to open the glove box.
What are you using for profiles in tasker to save battery? Have you found it possible to control the on/off state of the kindle when charging? I lose about 6% battery overnight with the following settings, but I imagine that someone has come up with a better battery management profile.
When my kindle sees power it turns on wifi and connects to my phones network, GPS, turns the screen on and volume up and opens maps.
When my kindle loses power it turns the screen blackout to 7 seconds, turns off wifi, GPS and quits tetherGPS.
davetsbass is offline   Reply With Quote
Old 07-22-2013, 03:20 PM   #90
Seraph
Member#: 12251
Thinking about doing this for the upcoming nexus. Based on the dimensions of the original nexus, how much of the device is actually behind the bezel? I'm wondering because i'm trying to see if theres some way i can dremel out the bezel a bit to allow for the tablet to sit on a mount and be removable but still be relatively flush looking.
Seraph is offline   Reply With Quote
Old 07-23-2013, 11:27 AM   #91
ScionPower
Member#: 280189
2006 WRX STi
ScionPower is offline   Reply With Quote
Old 08-04-2013, 05:47 PM   #92
awenthol
Member#: 355024
2013 DGM STi Sedan
Any issues with GPS? I skimmed through the thread and didn't see, so if I missed, I apologize.
Just installed a 2013 Nexus 7 in my STi but it can't lock onto GPS....
Waiting for my JDM Double Din Bezel to show
awenthol is offline   Reply With Quote
Old 08-19-2013, 12:10 PM   #93
PiNPOiNT
Member#: 131121
Inspired by this thread I went ahead and did the same thing with my nexus 7. One hiccup though. How do you turn the unit on? Did you wire up something to the power button inside the unit? Or did you use some sort of cheap mechanical solution to press the power button?
If you leave it on all the time it will eventually drain your car battery right?
For those interested. I use the same hyco bar solution (its found in the plumbing section of home depot btw. 87 cents. (you only need 1 bar).
Instead of plank of wood i used a piece of rubber drawer lining which is between the nexus and the hyco bars. and provides it from slipping around or damaging the back of the nexus if i ever want to remove it.
Just can't figure out how to turn the nexus on. Is there a "power on when plugged in" setting in cyanogen mod perhaps?
PiNPOiNT is offline   Reply With Quote
Old 08-19-2013, 01:56 PM   #94
puffywill
Member#: 305759
2010 STi
i'm having the same issue with google map and pandora (internet and iheartradio works fine)
are u using foxfi? might have something to do with jellybean
puffywill is offline   Reply With Quote
Old 08-19-2013, 07:21 PM   #95
WRX_Johnny
Member#: 365881
2013 Wrx Limited
Satin pearl white
Soo bad ass. I wish I didn't have stock nav or I'd do this. Good job!
WRX_Johnny is offline   Reply With Quote
Old 08-19-2013, 07:25 PM   #96
awenthol
Member#: 355024
2013 DGM STi Sedan
You running CyanogenMod? Yes, there's a setting for "wake up on power" and "stay awake while charging." I use tasker to change screen timeout settings and wake the screen/"play" music on "charge."
Some more info in later posts here http://forums.nasioc.com/forums/show....php?t=2459432
I'm using a ROM that utilizes Android WiFi tether w/out it in my plan. Turns out the GPS issue is a Gen 2 Nexus 7 issue...still waiting for a fix.
Old 08-20-2013, 12:31 AM   #97
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
wow that pretty cool, wish i had the guts to tear up my car lol
WhatsASubie is offline   Reply With Quote
Old 08-20-2013, 01:02 AM   #98
AnthonyA182
Member#: 59990
2011 WRX Hatch
Has anyone verified a way to solve the charging issue? N7's are cheap enough that I'd be willing to leave one in the dash permanently provided it could stay charged indefinitely.
Nice install OP
AnthonyA182 is offline   Reply With Quote
Old 08-20-2013, 10:01 AM   #99
awenthol
Member#: 355024
2013 DGM STi Sedan
Nice install OP
I didn't know ow there was an issue? My battery never goes below 95%
Old 08-20-2013, 10:17 AM   #100
Oldbayman
Member#: 364804
2013 STi HB
PBP
Good work and pics.
Oldbayman is offline   Reply With Quote
