Old 07-24-2013, 03:48 PM   #101
puffywill
Member#: 305759
2010 STi
tcoffin
do u have any pic of ur setup behind the tablet? and which obd gauge app are u using? thanks
puffywill is offline   Reply With Quote
Old 07-25-2013, 04:04 AM   #102
Ish9
Member#: 210884
2008 Impreza STI
Have you ran into any issues with your Parrot Mki? I've had mine for a couple of months and recently the remote quit working. Figured it needed a new banter but changing it gave the same results.
Ish9 is offline   Reply With Quote
Old 07-25-2013, 10:57 PM   #103
tcoffin014
Member#: 173734
Sexy White Princess
Originally Posted by puffywill View Post
tcoffin
I cut away some of the sides to shove the stock radio in there then made a little bracket that I epoxied to the case to hold the tablet the right distance out at the bottom. Nothings that secure lol. It rests on the bracket at the bottom and the radio at the top and I snap the bezel back on and it stays in there pretty good. I use the torque pro obd app and also got the race gauges add on. I use a cheap bluetooth dongle I got from amazon
tcoffin014 is offline   Reply With Quote
Old 07-26-2013, 12:09 PM   #104
puffywill
Member#: 305759
2010 STi
thanks for the pic...few more question if you dont mind....
are u seeing a delay in the obd app with the bluetooth dongle? and since i have a navi system, i would need to take the whole unit out? and use something like the parrot mki and a sub to power the door speaker?
Old 07-26-2013, 02:50 PM   #105
tcoffin014
Member#: 173734
Sexy White Princess
Yeah i think the nav is a little bigger so it might not fit back there. There is a slight delay in the gauges which I knew would happen so it doesn't really bother me because I have the stock tach and speedo
Old 07-26-2013, 07:37 PM   #106
heleos
Member#: 240632
2010 STI SE
Just bought the new Nexus 7 today, excited to get it into my 2010 sti
heleos is offline   Reply With Quote
Old 07-26-2013, 11:06 PM   #107
tcoffin014
Member#: 173734
Sexy White Princess
The best part is watching top gear in hi def in your car haha
Old 07-26-2013, 11:57 PM   #108
dirrtydetroit
Member#: 295302
2005 RS Wagon
This is an amazing idea. I saw a guy put a ipad into a dodge pickup and i just had to do it with my car... Mines all ran through bluetooth to my headunit to handle my OBDii scanner, navigation and phone calls/text messages.
Was a dead fit in a 05.
dirrtydetroit is offline   Reply With Quote
Old 08-04-2013, 07:00 PM   #109
awenthol
Member#: 355024
2013 DGM STi Sedan
I did something similar but used the factory brackets (put new holes in them) flush to the front of the head unit...pulled the knobs and cut down the shafts. After that, i trimmed the bezel a bit and called it good.
Am I the only one having problems with GPS?? Don't really want to buy a bluetooth GPS receiver....
awenthol is offline   Reply With Quote
Old 08-05-2013, 10:25 AM   #110
tcoffin014
Member#: 173734
Sexy White Princess
I thought about doing something like that but didn't want to cut too much for when I sell the car so it'll be easier to put the stock radio back in right. My gps works fine. But I always have my phone tethered. I don't know if that has something to do with it
Old 08-05-2013, 12:13 PM   #111
puffywill
Member#: 305759
2010 STi
heleos,
are you planning to put a wireless charging pad behind it and make the Nexus removeable?
Old 08-05-2013, 12:23 PM   #112
Andrew025
Member#: 303408
04 STi
heleos,
I know mine gets pretty toasty just being in the dash and plugged in. I couldn't imagine how much hotter the pad would make it.
Andrew025 is online now   Reply With Quote
Old 08-06-2013, 10:13 PM   #113
9MMSWORD
Member#: 336162
2013 WRX
Satin white pearl
How did you get the knobs off? Mine won't budge.
9MMSWORD is offline   Reply With Quote
Old 08-06-2013, 10:17 PM   #114
awenthol
Member#: 355024
2013 DGM STi Sedan
Turns out the GPS is an issue with the Gen 2 (software, not hardware). Got it working now.
Pull harder
Old 08-06-2013, 10:22 PM   #115
awenthol
Member#: 355024
2013 DGM STi Sedan
Waiting for my JDM bezel to show up, so I had no guilt cutting down the factory one...
Old 08-07-2013, 02:16 AM   #116
9MMSWORD
Member#: 336162
2013 WRX
Satin white pearl
What are all you with the stock radio behind the tablet doing for power? I got a 2.1A car charger with an otg 90 and a USB extension cable but for some reason the tablet won't charge with the USB extension cable any ideas what I can do? Is it the extension cable or the otg cable?
Old 08-07-2013, 10:03 AM   #117
tcoffin014
Member#: 173734
Sexy White Princess
I tapped into power and ground at the radio harness. I think you need a certain type of cable to charge through otg. Do you use the otg for a flash drive or something? If not they make 90 charging cables too which is what I have
Old 08-07-2013, 11:29 AM   #118
9MMSWORD
Member#: 336162
2013 WRX
Satin white pearl
I use the otg to make the 90 because I couldn't find a one piece micro to type A cable.
Old 08-07-2013, 11:51 AM   #119
awenthol
Member#: 355024
2013 DGM STi Sedan
I picked up a Scosche 2.1 Amp USB adapter (pulled it apart and soldered wires straight to the internal wires) and spliced to the radio harness.
Then, I'm using
THISTHIS
right angle cable.
Batt is at 100% by the time I get home every night (15min to work, 15min home, tasker to turn off about everything and slow CPU to a crawl).
Old 08-07-2013, 11:09 PM   #120
Lv4toys
Member#: 338495
2013 XV Crosstrek
Tangerine Orange Pearl
Fabulous thread - it's great to see how people are customizing their subbies. I would love to do something similar to my wife's Crosstrek, but she told me to keep my hand off her car.
Lv4toys is offline   Reply With Quote
Old 08-07-2013, 11:41 PM   #121
tcoffin014
Member#: 173734
Sexy White Princess
Then, I'm using Video Link: http://www.amazon.com/StarTech-com-Micro-USB-Cable-UUSBHAUB3RA/dp/B001AR4NC8/ref=sr_1_2?ie=UTF8&qid=1375886988&sr=8-2&keywords=3+ft+micro+usb+right+angle right angle cable.
How do you slow the cpu with Tasker? Also, how do you turn the screen on with Tasker? The only way I found was telling it to open an app but that doesn't seem to work all the time
Old 08-08-2013, 12:47 AM   #122
awenthol
Member#: 355024
2013 DGM STi Sedan
Are you rooted? I'll see what I can do about uploading my config...not sure if Tasker allows it but I can post my Titanium Backup files. I can also try getting screenshots of the locations of each setting.
It also helps that I removed EVERY unnecessary app.
One last note for people wanting to do this...I bought GMD GestureControl and setup gesture functions for back, menu, home, recents, previous app (and some more, won't bore) so that I could eliminate the status bar and navigation bar--ie, I'm now running full screen for everything. Example, 3 fingers "pinch" goes "Home," two fingers "right" goes "back," etc.
Main apps for me:
Car Home
BT AutoConnect (ensure tablet reconnects to HU after tasker reenables bluetooth)
GMD GestureControl
PlayerPro (looking for better, setup to auto play music after BT connection)
Volume Widget
Tasker
Old 08-08-2013, 11:51 AM   #123
tcoffin014
Member#: 173734
Sexy White Princess
Yeah I'm rooted. I'm running timur's usb rom. It's supposed to give me auto screen on/off with power but for some reason that doesn't work for me so I have to use tasker for that. But sometimes tasker doesn't work right, so idk what's going on
Old 08-11-2013, 09:21 PM   #124
9MMSWORD
Member#: 336162
2013 WRX
Satin white pearl
Then, I'm using THIS right angle cable.
Are you using the 3ft or? Does the longer cable effect charge rate? My 2.1a charger in my car won't even charge it fast enough while I'm using it is that normal?
Old 08-11-2013, 11:14 PM   #125
tico556
Member#: 362086
To OP: How are you getting Nav on your tablet? Is it 3g/4g or something? Or are you using a phone to create a wifi hotspot? Great idea.
tico556 is offline   Reply With Quote
